My Decathlon is in annual right now, and needs some repairs to the original
dope-on-Ceconite finish. Our new A&P doesn't have much experience with fabric work, so he sought advice from others. I'm feeling uneasy about the answers he got. A couple of questions for those with paint and fabric experience: 1. Wag Aero sent us Poly-tak cement and poly-fiber tape to make the patches, and poly-fiber products to paint over it. Why would they do that? Will this work? I understood that mixing systems was bad, and voided the STC. 2. The belly fabric is soaked through from an old oil leak. I mean really soaked through. The dope is sloughing off the bottom, and 2 inspection rings have fallen off. I feel we should recover the fuselage, but my partner wouldn't go for it. We're going to try cleaning the belly out by washing the inside with mineral spirits, stripping the outside with MEK, and then repainting with poly-fiber. Does this have a chance in hell of working? 3. Assuming this doesn't work, our next step is to try reskinning the belly only. Looking at the fuselage, it looks like it was covered using the envelope method. Just a guess, but it doesn't look like it's fastened to the lower longerons with anything but fabric tension. When we cut the back half of the belly skin off, what is to stop the fabric on the sides of the aircraft from pulling up towards the top? Any advice on how to make this repair work? 4. While stripping a few areas with MEK, I ran across some small areas of paint repairs that were obviously not done with dope. The paint coat was shiny and thin. Instead of dissolving in the MEK, these paint areas disintegrated into little bits of crumbling film. Excuse the gross analogy, but the paint behaved not unlike the way your skin peels after a bad sunburn. What kind of paint could this be? Is it enamel or urethane? Thanks, Ed |
Gunk was invented to de-grease fabric airplanes. You can wash down with
mineral spirits but Gunk converts to a water wash off. Take your pick of use both ending with the Gunk. "Ed" wrote in message om... My Decathlon is in annual right now, and needs some repairs to the original dope-on-Ceconite finish. Our new A&P doesn't have much experience with fabric work, so he sought advice from others. I'm feeling uneasy about the answers he got. A couple of questions for those with paint and fabric experience: 1. Wag Aero sent us Poly-tak cement and poly-fiber tape to make the patches, and poly-fiber products to paint over it. Why would they do that? Will this work? I understood that mixing systems was bad, and voided the STC. 2. The belly fabric is soaked through from an old oil leak. I mean really soaked through. The dope is sloughing off the bottom, and 2 inspection rings have fallen off. I feel we should recover the fuselage, but my partner wouldn't go for it. We're going to try cleaning the belly out by washing the inside with mineral spirits, stripping the outside with MEK, and then repainting with poly-fiber. Does this have a chance in hell of working? 3. Assuming this doesn't work, our next step is to try reskinning the belly only. Looking at the fuselage, it looks like it was covered using the envelope method. Just a guess, but it doesn't look like it's fastened to the lower longerons with anything but fabric tension. When we cut the back half of the belly skin off, what is to stop the fabric on the sides of the aircraft from pulling up towards the top? Any advice on how to make this repair work? 4. While stripping a few areas with MEK, I ran across some small areas of paint repairs that were obviously not done with dope. The paint coat was shiny and thin. Instead of dissolving in the MEK, these paint areas disintegrated into little bits of crumbling film. Excuse the gross analogy, but the paint behaved not unlike the way your skin peels after a bad sunburn. What kind of paint could this be? Is it enamel or urethane? Thanks, Ed |
Ed...
Take the plane to someone who knows what they're doing... Can't mix Ceconite and Poly Fiber... 2 Completely different systems... Poly Fiber paints are really a liquid vinyl... Totally different than dope... John Price CFII/AGI/IGI http://home.att.net/~jm.price "Ed" wrote in message om... My Decathlon is in annual right now, and needs some repairs to the original dope-on-Ceconite finish. Our new A&P doesn't have much experience with fabric work, so he sought advice from others. I'm feeling uneasy about the answers he got. A couple of questions for those with paint and fabric experience: 1. Wag Aero sent us Poly-tak cement and poly-fiber tape to make the patches, and poly-fiber products to paint over it. Why would they do that? Will this work? I understood that mixing systems was bad, and voided the STC. 2. The belly fabric is soaked through from an old oil leak. I mean really soaked through. The dope is sloughing off the bottom, and 2 inspection rings have fallen off. I feel we should recover the fuselage, but my partner wouldn't go for it. We're going to try cleaning the belly out by washing the inside with mineral spirits, stripping the outside with MEK, and then repainting with poly-fiber. Does this have a chance in hell of working? 3. Assuming this doesn't work, our next step is to try reskinning the belly only. Looking at the fuselage, it looks like it was covered using the envelope method. Just a guess, but it doesn't look like it's fastened to the lower longerons with anything but fabric tension. When we cut the back half of the belly skin off, what is to stop the fabric on the sides of the aircraft from pulling up towards the top? Any advice on how to make this repair work? 4. While stripping a few areas with MEK, I ran across some small areas of paint repairs that were obviously not done with dope. The paint coat was shiny and thin. Instead of dissolving in the MEK, these paint areas disintegrated into little bits of crumbling film. Excuse the gross analogy, but the paint behaved not unlike the way your skin peels after a bad sunburn. What kind of paint could this be? Is it enamel or urethane? Thanks, Ed |
IMHO strip the dope from a completely oil free margin all around. Cut
away the oil soaked area (pay attention to any fastening methods. Clean the structure thoroughly. Then afix Ceconite along the clean margin according to the Ceconite manual, tighten with a steam iron and refinish with dope. Do not try and wash away the crud from the Ceconite interior surface. Barry A&P .. My Decathlon is in annual right now, and needs some repairs to the original dope-on-Ceconite finish. Our new A&P doesn't have much experience with fabric work, so he sought advice from others. I'm feeling uneasy about the answers he got. A couple of questions for those with paint and fabric experience: |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
