Hi Calvin,
Yes, I think there is a future for diesels. My main (and probably only) concern is the weight of a diesel versus a standard light-fuel burning IC av-engine. When the weight of a diesel is comparable to a standard IC engine, then you'll have a hum-dinger. the combined weight of engine plus fuel for any significant mission range is already equal or less for a diesel in many cases. The diamond DA40 for example is only 10 kg heavier with the diesel than with a Lycoming, burning 4.9 gal or 15.8kg of Diesel or Jetfuel vs. 8.7 gal or 24.5kg of avgas, both at 152kt. At 122kts the figures are 4.1 gal/13.2kg Diesel vs. 7.2 gal/20.2kg Avgas. So if you plan on staying in the air for more than say 90 Minutes, you can actually carry more payload in the diesel. Yes, in this case the Lycoming IO360 is also slightly more powerful, at least at sea level. But the general idea remains valid: The weight penalty of diesels turns into the opposite, if flying longer missions. Whether it makes sense economically is a different question, and depends strongly on fuel prices and whether you are faced with a choice between the two or considering a replacement. In Europe, when you need a new engine or an overhaul anyway, it's hard to imagine a case where you wouldn't save a large amount of money with a diesel. In the US, especially when you already have a perfectly good engine in your plane, you might not amortize a replacement kit fo a long time. Of course there are other questions, like range (very much pro diesel), reliability (for the diesels yet to be proven), availability of the fuel (so far jetfuel is not available at many small airports, on the other hand the future of leaded avgas is unclear altogether), which every pilot/owner has to answer for himself. regards, Friedrich -- for personal email please remove "entfernen" from my adress |
| Aviation diesels and turbo's | George Ruch | Military Aviation | 2 | September 27th 04 02:00 AM |
| Aviation diesels and turbo's | Fritz | General Aviation | 0 | September 26th 04 11:00 PM |
