I'm looking for a simple flight planning program or link to do some long
cross country, short leg vfr flying. Something simple, without weight and balance computation or having to put in fuel burn and power setting. Don't need any graphics. Just a flight log type that uses an airport database. There was once an online flight planner that would produce a cross-country log with route, heading, and airports just by putting in maximum legs, average airspeed, and max altitude. It would compute the route making allowances or detours for moa and longest legs for fuel stops. This was great for planning an ultralight type cross-country. It wouldn't tilt if you didn't put in all the info. It would work with the info you put in, if it was enough. I think the online site went commercial or to a commercial program. I would buy it if I could find it. I know this has been asked before, but a Google search did not produce the answer I was looking for. I know how to plan without it. It would be a convenience tool to get started planning. The reason I mention this is that some of these type questions got to be 100 plus answers on how to plan a flight, all of which had nothing to do with the topic. Thanks in advance for the help. Marc remove x and next four before at |
AOPA's online flight planner is about as easy as they come to use, and does
more than you want. If you're not an AOPA member you should be. -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney (Or Kerry, for that matter) to love America "marc" wrote in message ... I'm looking for a simple flight planning program or link to do some long cross country, short leg vfr flying. Something simple, without weight and balance computation or having to put in fuel burn and power setting. Don't need any graphics. Just a flight log type that uses an airport database. There was once an online flight planner that would produce a cross-country log with route, heading, and airports just by putting in maximum legs, average airspeed, and max altitude. It would compute the route making allowances or detours for moa and longest legs for fuel stops. This was great for planning an ultralight type cross-country. It wouldn't tilt if you didn't put in all the info. It would work with the info you put in, if it was enough. I think the online site went commercial or to a commercial program. I would buy it if I could find it. I know this has been asked before, but a Google search did not produce the answer I was looking for. I know how to plan without it. It would be a convenience tool to get started planning. The reason I mention this is that some of these type questions got to be 100 plus answers on how to plan a flight, all of which had nothing to do with the topic. Thanks in advance for the help. Marc remove x and next four before at |
Thanks, Bob. I really don't want to do too much more. I don't want to join
an organization to use the program, but I would like to buy it if I could find it. When I mean simple, I didn't mean I am mentally challenged in flight planning. I just wanted the convenience of the program. Marc cmsel/instruments "Bob Chilcoat" wrote in message ... AOPA's online flight planner is about as easy as they come to use, and does more than you want. If you're not an AOPA member you should be. -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney (Or Kerry, for that matter) to love America "marc" wrote in message ... I'm looking for a simple flight planning program or link to do some long cross country, short leg vfr flying. Something simple, without weight and balance computation or having to put in fuel burn and power setting. Don't need any graphics. Just a flight log type that uses an airport database. There was once an online flight planner that would produce a cross-country log with route, heading, and airports just by putting in maximum legs, average airspeed, and max altitude. It would compute the route making allowances or detours for moa and longest legs for fuel stops. This was great for planning an ultralight type cross-country. It wouldn't tilt if you didn't put in all the info. It would work with the info you put in, if it was enough. I think the online site went commercial or to a commercial program. I would buy it if I could find it. I know this has been asked before, but a Google search did not produce the answer I was looking for. I know how to plan without it. It would be a convenience tool to get started planning. The reason I mention this is that some of these type questions got to be 100 plus answers on how to plan a flight, all of which had nothing to do with the topic. Thanks in advance for the help. Marc remove x and next four before at |
I have exactly what you need. It's called NavMate. It does run in a DOS
window, but does a very good job. It's available from the FAA at: http://www.faa.gov/FSDO/ORL/fltpln.htm Enjoy, R "marc" wrote in message ... I'm looking for a simple flight planning program or link to do some long cross country, short leg vfr flying. Something simple, without weight and balance computation or having to put in fuel burn and power setting. Don't need any graphics. Just a flight log type that uses an airport database. There was once an online flight planner that would produce a cross-country log with route, heading, and airports just by putting in maximum legs, average airspeed, and max altitude. It would compute the route making allowances or detours for moa and longest legs for fuel stops. This was great for planning an ultralight type cross-country. It wouldn't tilt if you didn't put in all the info. It would work with the info you put in, if it was enough. I think the online site went commercial or to a commercial program. I would buy it if I could find it. I know this has been asked before, but a Google search did not produce the answer I was looking for. I know how to plan without it. It would be a convenience tool to get started planning. The reason I mention this is that some of these type questions got to be 100 plus answers on how to plan a flight, all of which had nothing to do with the topic. Thanks in advance for the help. Marc remove x and next four before at |
On Sat, 2 Oct 2004 21:51:30 -0400, "RSwanson"
wrote: It's available from the FAA at: http://www.faa.gov/FSDO/ORL/fltpln.htm Interesting site, but why so many different flight planning programs? |
![]() "marc" wrote in message ... I'm looking for a simple flight planning program or link to do some long cross country, short leg vfr flying. Something simple, Take a look at Airnav, it is my favorite: http://www.airnav.com/ Click on aviation fuel, and then plan a flight with fuel stops |
Why donīt you take a look at www.pocketfms.com. Does much more than you
want, but can also be used by simply keing in departure and arrival. It is graphical also, but you do not have to look at that part of the screen, do you? It will run on a PC or PocketPC. And itīs FREE! TMG "marc" wrote in message ... I'm looking for a simple flight planning program or link to do some long cross country, short leg vfr flying. Something simple, without weight and balance computation or having to put in fuel burn and power setting. Don't need any graphics. Just a flight log type that uses an airport database. There was once an online flight planner that would produce a cross-country log with route, heading, and airports just by putting in maximum legs, average airspeed, and max altitude. It would compute the route making allowances or detours for moa and longest legs for fuel stops. This was great for planning an ultralight type cross-country. It wouldn't tilt if you didn't put in all the info. It would work with the info you put in, if it was enough. I think the online site went commercial or to a commercial program. I would buy it if I could find it. I know this has been asked before, but a Google search did not produce the answer I was looking for. I know how to plan without it. It would be a convenience tool to get started planning. The reason I mention this is that some of these type questions got to be 100 plus answers on how to plan a flight, all of which had nothing to do with the topic. Thanks in advance for the help. Marc remove x and next four before at |
Marc,
AOPA's Real Time flightplanner or Duat's Golden Eagle Flight Prep. Both free (the former requires membership, though). The former only works online, as I understand it. Oh, and Bob's right: You should be an AOPA member anyway. -- Thomas Borchert (EDDH) |
As far as I am concern, the best and free one is PocketFMS that could
be download at http://www.pocketfms.com/ . Use it on your PC for fly planing. If you have a pocketPC and a GPS, you have the perfect system. For user of Magellan 315 or yellow SporTrak, they have an aeronautical database. Visit http://pages.videotron.com/smdaoust/gpsnav/ it is for canadian pilots but there is links for american and european pilots. .. On Sat, 02 Oct 2004 18:05:05 GMT, "marc" wrote: I'm looking for a simple flight planning program or link to do some long cross country, short leg vfr flying. Something simple, without weight and balance computation or having to put in fuel burn and power setting. Don't need any graphics. Just a flight log type that uses an airport database. There was once an online flight planner that would produce a cross-country log with route, heading, and airports just by putting in maximum legs, average airspeed, and max altitude. It would compute the route making allowances or detours for moa and longest legs for fuel stops. This was great for planning an ultralight type cross-country. It wouldn't tilt if you didn't put in all the info. It would work with the info you put in, if it was enough. I think the online site went commercial or to a commercial program. I would buy it if I could find it. I know this has been asked before, but a Google search did not produce the answer I was looking for. I know how to plan without it. It would be a convenience tool to get started planning. The reason I mention this is that some of these type questions got to be 100 plus answers on how to plan a flight, all of which had nothing to do with the topic. Thanks in advance for the help. Marc remove x and next four before at |
Merci Michel
"pourquoipas" wrote in message ... As far as I am concern, the best and free one is PocketFMS that could be download at http://www.pocketfms.com/ . Use it on your PC for fly planing. If you have a pocketPC and a GPS, you have the perfect system. For user of Magellan 315 or yellow SporTrak, they have an aeronautical database. Visit http://pages.videotron.com/smdaoust/gpsnav/ it is for canadian pilots but there is links for american and european pilots. . On Sat, 02 Oct 2004 18:05:05 GMT, "marc" wrote: I'm looking for a simple flight planning program or link to do some long cross country, short leg vfr flying. Something simple, without weight and balance computation or having to put in fuel burn and power setting. Don't need any graphics. Just a flight log type that uses an airport database. There was once an online flight planner that would produce a cross-country log with route, heading, and airports just by putting in maximum legs, average airspeed, and max altitude. It would compute the route making allowances or detours for moa and longest legs for fuel stops. This was great for planning an ultralight type cross-country. It wouldn't tilt if you didn't put in all the info. It would work with the info you put in, if it was enough. I think the online site went commercial or to a commercial program. I would buy it if I could find it. I know this has been asked before, but a Google search did not produce the answer I was looking for. I know how to plan without it. It would be a convenience tool to get started planning. The reason I mention this is that some of these type questions got to be 100 plus answers on how to plan a flight, all of which had nothing to do with the topic. Thanks in advance for the help. Marc remove x and next four before at |
Free Flight Planning Software | Dean Wilkinson | Piloting | 20 | September 25th 04 03:38 AM |
Flight Simulator Software - Any Help or Just a Game? | pjbphd | Piloting | 40 | September 23rd 04 04:06 PM |
macintosh flight software | mah | Aviation Marketplace | 0 | December 6th 03 12:42 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
