Anyone upgraded a O-235-C 6.5 CR 100HP Lycoming using L2C 115HP 9.5 Pistons/Cyl?
If so is it bolt on or is there machining involved? Any better alternatives? I've heard someone sells high-comp pistons in the 10.5 CR range. Thanks! |
LyCon, in Visalia, (sp?) CA, sells custom pistons at whatever
compression ratio you want. I am interested in LyCon's pistons for my Conti E225. My stock pistons is 7:1 and LyCon told me that they can make a set for me with 8.6 to 1 as in IO-470N, or higher CR if I want. Does anyone have used LyCon's high CR pistons? Do you need to increase fuel flow or chang inition timing with higher CR pistons? |
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? | Ron | Home Built | 2 | February 24th 04 04:34 PM |
Lycoming Sued | jls | Home Built | 0 | February 13th 04 02:01 PM |
Weight of Lycoming O290 | Ray Toews | Home Built | 1 | December 21st 03 11:56 PM |
Lycoming 320 and EAA Light Sport Aircraft ? | Dave Jackson | Home Built | 29 | October 20th 03 01:20 AM |
lycoming gaskets & parts | Paul | Home Built | 2 | October 17th 03 03:49 PM |
