Question on fuel consumption
Old October 21st 04, 07:39 AM
Shemp McGurk
Default Question on fuel consumption
The government routinely publishes a list of miles-per-gallon
consumption ratings for all cars sold in the U.S.
Does anyone know whether such a list exists for aviation?
I'm looking for a list of fuel consumption ratings for:
- private jets
- commercial jets.
....AND, if such a list exists, a per-passenger fuel consumption by
type of aircraft.
I thank you in advance for your answers...
Old October 21st 04, 10:35 AM
Cub Driver
Zero Six Hotel burns four gallons an hour on average, if that helps
all the best -- Dan Ford
email: (put Cubdriver in subject line)
Warbird's Forum
www.warbirdforum.com
Piper Cub Forum www.pipercubforum.com
the blog www.danford.net
Old October 21st 04, 01:46 PM
Peter R.
.... during it's fifty nm journey in a no wind situation. ;-)
Peter
Old October 22nd 04, 11:16 AM
Cub Driver
Actually, the fuel burn is the same whether the wind is blowing or
not.
It's true that with a 20-knot wind the outbound journey will take a
bit longer than the return. (20-knot winds hereabouts almost always
come from the NNW, which is where I am generally going.)
Warbird's Forum
Old October 22nd 04, 01:17 PM
Peter R.
not.
I was trying to make a joke about the Cub's no wind ground speed.
Peter
Old October 22nd 04, 01:30 PM
Peter R.
not.
Whoops, I left off this
Peter
Old October 21st 04, 06:55 PM
C Kingsbury
"Shemp McGurk" wrote in message
om...
Nope. Too many variables. Winds, air temperature, and payload all affect
this pretty significantly, particularly in jets. Not to mention the huge
variety of airframe/engine combos out there.
- private jets
- commercial jets.
type of aircraft.
If you don't need a precise number, look at the aircraft's range with
maximum fuel and its fuel capacity. You can get this from the manufacturers'
websites. Jets typically think about fuel consumption in pounds, so keep in
mind there are about 6 pounds of Jet-A to the gallon.
Regarding weight, there are a few numbers you can look at: MGTOW (max gross
takeoff weight), empty weight, and "payload with full fuel." If they don't
list how much fuel it carries for maximum range, look at the weights.
Generally speaking, fuel weight will equal MGTOW minus empty weight minus
full fuel payload.
FYI, I once ballparked a Gulfstream V's fuel consumption as something like 1
gallon per mile, and a 747-400's as 6 gallons per mile.
If there's a specific scenario you're trying to examine (i.e. Learjet versus
Hummer H2) I suggest asking that question specifically. Odds are someone
here will be able to provide far more precise numbers than I could.
Also, you might try calling a local jet charter operator. They can surely
give you numbers for the planes they operate.
Best,
-cwk.
Old October 22nd 04, 03:30 AM
Icebound
"C Kingsbury" wrote in message
ink.net...
manufacturers'
in
Avgas is 6 pounds, but I think Jet Fuel is 6.5
http://www.fs.fed.us/im/directives/f...5709.16_30.txt
Old October 22nd 04, 05:25 AM
Shemp McGurk
"C Kingsbury" wrote in message link.net...
om...
- private jets
- commercial jets.
type of aircraft.
full fuel payload.
Actually, your Gulfstream V comparison with the 747-400 is exactly the
kind of thing I'm looking for: the per-passenger miles-per-gallon on a
private jet versus the per-passenger miles-per-gallon on a commercial
jet.
And from the example you give above, it's about what I thought it
would be: a 747 with, say, 300 passengers is consuming 6 gallons per
mile and a Gulfstream with, say, 10 passengers is consuming 1 gallon
per mile, the per-passenger miles-per-gallon is WAY higher with the
private jet than with the commercial jet.
Yes?
Best,
-cwk.
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 06:13 PM
Declared "minimum fuel" O. Sami Saydjari Instrument Flight Rules 14 April 4th 04 02:43 AM
Repairing Plastic Instrument Panel Overlay Jeff P Owning 22 January 29th 04 06:42 PM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Owning 0 January 26th 04 07:48 AM
Why did Britain win the BoB? Grantland Military Aviation 79 October 15th 03 03:34 PM
