Hi guys,
Unlike the elevators and rudder that change an aircraft's pitch and yaw with no other secondary effect, why does the banking of wings by the use of ailerons not just roll an aircraft but also produces a turn (yaw)? Logically, one would expect an aircraft to keep going straight ahead even if the pilot banked the aircraft left or right. Where does the turning effect come from? Is there a website you know of that can teach me such basics, without having to bug you? ![]() Cheers, Ramapriya |
yaw with no other secondary effect, why does the banking of wings by the use of ailerons not just roll an aircraft but also produces a turn (yaw)? Logically, one would expect an aircraft to keep going straight ahead even if the pilot banked the aircraft left or right. Where does the turning effect come from? Is there a website you know of that can teach me such basics, without having to bug you? ![]() Cheers, Ramapriya Rudder most definitely adds roll as a secondary effect. In fact, I use rudder to momentarily keep the wings level when I'm changing maps, etc. At low speeds, when the ailerons are not that effective, rudder can be much more effective. As to the aileron, think of the relative wind on the wings. With an aileron dropped (looking like a flap), there will be increased drag. Of course the other one goes up, but I don't think the resultant force is equal on both wings. Thus, yaw results. While it seems intuitive to me, I probably don't have the best explanation, so can anyone else elaborate? Adam N7966L Beech Super III |
With an aileron dropped (looking like a flap), there will be increased drag. Of course the other one goes up, but I don't think the resultant force is equal on both wings. Thus, yaw results. Brian, are you stating that this yaw causes the turn?, actually this is adverse yaw and resists the turn. Come, lets step into my flying laboratory, the Grob 103, and we'll explore that interesting concept called adverse yaw. BT |
![]() "BTIZ" wrote in message news:K97jd.86842$bk1.136@fed1read05... As to the aileron, think of the relative wind on the wings. With an aileron dropped (looking like a flap), there will be increased drag. Of course the other one goes up, but I don't think the resultant force is equal on both wings. Thus, yaw results. Brian, are you stating that this yaw causes the turn?, actually this is adverse yaw and resists the turn. Come, lets step into my flying laboratory, the Grob 103, and we'll explore that interesting concept called adverse yaw. BT Inside rudder will most definitely produce bank which will produce turn exactly as Brian said it would. There is a difference between adverse and complimentary yaw. Actually, there will be no adverse yaw if inside rudder alone is used to induce complimentary yaw. Only aileron application into a bank with no inside rudder will produce adverse yaw. If complimentary yaw (inside rudder) is used with no aileron, the speed difference between the retreating inside wing and the forward moving outside wing will cause bank, which will be a direct secondary result of the complimentary yaw being produced. In other words, insider rudder will most definitely produce bank as a secondary effect and as such will produce turn...assuming no anti turn control input is present. Dudley Henriques International Fighter Pilots Fellowship for email; take out the trash |
I was always under the impression that in most light a/c, the dominate
rolling effect from 'inside' rudder is the result of dihedral (or alternatively, sweep back). RC modelers are pretty adept at setting up aircraft for 'pure' yaw from rudder input - no dihedral, symmetrical layout, etc. Or setting up aircraft to bank and turn without ailerons - lots of didedral. Though I'd agree that the "forward motion of the outside wing" explanation accurately predicts the rolling effect from rudder input that occurs on most a/c - which is ok for training purposes. "Dudley Henriques" snip If complimentary yaw (inside rudder) is used with no aileron, the speed difference between the retreating inside wing and the forward moving outside wing will cause bank, which will be a direct secondary result of the complimentary yaw being produced. In other words, insider rudder will most definitely produce bank as a secondary effect and as such will produce turn...assuming no anti turn control input is present. Dudley Henriques International Fighter Pilots Fellowship for email; take out the trash |
![]() "Maule Driver" wrote in message om... I was always under the impression that in most light a/c, the dominate rolling effect from 'inside' rudder is the result of dihedral (or alternatively, sweep back). RC modelers are pretty adept at setting up aircraft for 'pure' yaw from rudder input - no dihedral, symmetrical layout, etc. Or setting up aircraft to bank and turn without ailerons - lots of didedral. Though I'd agree that the "forward motion of the outside wing" explanation accurately predicts the rolling effect from rudder input that occurs on most a/c - which is ok for training purposes. I would agree with this completely. Dihedral contributes heavily to the lateral stability of the aircraft if sideslip is present to be sure. The prime contribution of dihedral is in the development of a stable rolling moment with sideslip, which is consistent with what most of us are saying. The problem with answering many questions in aerodynamics is that there isn't one single example or answer that will suffice. (Lift is a PRIME example of this. ) Anyone trying to explain lift in a simple sentence will find a slew of missing data soon to follow :-) The problem in aerodynamics is that in much of what is happening, several explanations are in force physically together at one instant in time. The way we look at dihedral in the flight test community is primarily as it's effect on the lateral stability scenario which relates with sideslip present to relative wind, differential in angle of attack, changes in lift raising a windward wing producing stability. I think we're both on the same page, and dealing with the same effect since all of what we're discussing is present in complimentary yaw IF dihedral is present. Now, if we inject an airplane into this equation like a Cessna 195 for example.......... :-)))) Dudley Henriques International Fighter Pilots Fellowship for email; take out the trash |
Dudely.. he said turning by banking only.. he said nothing of "inside
rudder" at least not the way I read it BT "Dudley Henriques" wrote in message news ![]() "BTIZ" wrote in message news:K97jd.86842$bk1.136@fed1read05... As to the aileron, think of the relative wind on the wings. With an aileron dropped (looking like a flap), there will be increased drag. Of course the other one goes up, but I don't think the resultant force is equal on both wings. Thus, yaw results. Brian, are you stating that this yaw causes the turn?, actually this is adverse yaw and resists the turn. Come, lets step into my flying laboratory, the Grob 103, and we'll explore that interesting concept called adverse yaw. BT Inside rudder will most definitely produce bank which will produce turn exactly as Brian said it would. There is a difference between adverse and complimentary yaw. Actually, there will be no adverse yaw if inside rudder alone is used to induce complimentary yaw. Only aileron application into a bank with no inside rudder will produce adverse yaw. If complimentary yaw (inside rudder) is used with no aileron, the speed difference between the retreating inside wing and the forward moving outside wing will cause bank, which will be a direct secondary result of the complimentary yaw being produced. In other words, insider rudder will most definitely produce bank as a secondary effect and as such will produce turn...assuming no anti turn control input is present. Dudley Henriques International Fighter Pilots Fellowship for email; take out the trash |
![]() "BTIZ" wrote in message news:Lphjd.90058$bk1.21776@fed1read05... Dudely.. he said turning by banking only.. he said nothing of "inside rudder" at least not the way I read it BT I admit the question is a little vague to say the least. I think I might have got caught up in that "turn"(yaw) thing and read it to mean complimentary yaw producing turn as a secondary effect. I read it as asking several things that were not exactly correct in premise to begin with! For example; "Unlike the elevators and rudder that change an aircraft's pitch and yaw with no other secondary effect," I have a bit of a problem with this premise before even getting into the "question" :-) Then we have this; "why does the banking of wings by the use of ailerons not just roll an aircraft but also produces a turn (yaw)? " I read his context as aileron being used and producing turn which in the turn (inside context) would be complimentary yaw.....which of course wouldn't be the secondary effect of using aileron to begin with.........are you following this........cause I'm getting lost!!! :-))) The parenthesis (yaw) opens up a whole deck of cards since banking the airplane with just aileron would produce adverse yaw; not complimentary yaw, and it will also as a secondary effect after adverse yaw had stabilized, produce turn if not held back with anti turn controls. It's puzzling the way he worded it really. I'm not sure really what he was asking at this point!! :-) Anyway, the answer for uncoordinated turn entry using various isolated control inputs would be if aileron alone....adverse yaw followed by turn after stabilization and vector split; and inside rudder alone; turn as bank is introduced as the secondary and the lift vector splits. You are completely right of course about dihedral effect! Anyway....I think I'll leave this for you guys to play with. I'm going to bed!! :-) Have a good one, Dudley |
"The Weiss Family" wrote in message ...
Unlike the elevators and rudder that change an aircraft's pitch and yaw with no other secondary effect, why does the banking of wings by the use of ailerons not just roll an aircraft but also produces a turn (yaw)? Logically, one would expect an aircraft to keep going straight ahead even if the pilot banked the aircraft left or right. Where does the turning effect come from? Is there a website you know of that can teach me such basics, without having to bug you? ![]() Cheers, Ramapriya Rudder most definitely adds roll as a secondary effect. In fact, I use rudder to momentarily keep the wings level when I'm changing maps, etc. At low speeds, when the ailerons are not that effective, rudder can be much more effective. As to the aileron, think of the relative wind on the wings. With an aileron dropped (looking like a flap), there will be increased drag. Of course the other one goes up, but I don't think the resultant force is equal on both wings. Thus, yaw results. While it seems intuitive to me, I probably don't have the best explanation, so can anyone else elaborate? Adam N7966L Beech Super III Because when the wing is level, the lift is up. When the wing is banked to the right, the lift is also tilted to the right pulling the plane in the direction. Same for the left. Bryan |
Thus, yaw results. While it seems intuitive to me, I probably don't have the best explanation, so can anyone else elaborate? Tilting of the lift vector also results in a turn. |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Phoenix AIM-54A (QUESTION) | Krztalizer | Naval Aviation | 10 | February 23rd 04 07:22 AM |
Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 09:40 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
Basic Stupid Newbie Questions... | John Penta | Military Aviation | 5 | September 19th 03 05:23 PM |
