Crop duster missing
Old November 8th 04, 09:26 PM
Len
Default Crop duster missing
Not trying to be alarmist, just thinking that all of us GA folks can
keep an eye out for something odd-
http://www.eaa.org/communications/eaanews/advisory.pdf
Len
PP-SEL
Old November 9th 04, 06:13 AM
NW_PILOT
"Len" wrote in message
Len
PP-SEL
Install hidden security switches to prevent unauthorized startup of
aircraft???? how could you hide a switch on an airplane wouldn't you need a
337 and a description on the switch ware it's going to be placed?
Old November 9th 04, 06:12 AM
BTIZ
sure.. I think you would... but that would be buried in the aircraft maint
logs..
I don't think the thief pilot would know where to look...
also remember this is TSA... they do not know anything about aircraft..
maint requirements or paper work... look at the fiasco they just unleashed
with 49CFR1552
They are still writing waivers and interpretations on what they really meant
to cover.
BT
"NW_PILOT" wrote in message
Len
PP-SEL
a
Old November 9th 04, 03:11 PM
G.R. Patterson III
logs..
Of course they would, 'cause the FAA would require that you install a large red
placard telling you to turn it on before flight.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
Old November 9th 04, 03:32 PM
Jay Masino
with 49CFR1552
I guess they don't know anything about cutting the P-leads and hand
propping, either.
__!__
Jay and Teresa Masino ___(_)___
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old November 9th 04, 04:03 PM
G.R. Patterson III
propping, either.
I really doubt that that's an issue on the Pawnee. Or most of the other aircraft with
which the TSA is concerned.
George Patterson
Old November 9th 04, 05:00 PM
Jay Masino
aircraft with which the TSA is concerned.
Yea. Of course, it's sometimes hard to tell which are the "aircraft with
which the TSA is concerned"
__!__
Old November 9th 04, 07:27 PM
George
"NW_PILOT" wrote in message ...
Len
PP-SEL
and immediately falls apart when some-one does a conversion onto that machine.
Remember the ground switch on the PA22 ??????
Old November 11th 04, 12:25 AM
SelwayKid
Len
PP-SEL
Yes a 337 is required but only the local FAA office has the info as to
the location. Most aerial application aircraft don't require a key to
either get into, or to start. Hidden master switches are quite common
now and especially for the expensive turbine aircraft. Pretty easy to
get in for a million dollars on the newer turbine spray planes.
For the most part security on spray aircraft is pretty tight in that
they are normally on a private strip and strangers stick out like a
sore thumb. A spray plane is not attractive to smugglers because of
its low speed and limited fuel. Most of them get stolen for the
component parts like engine, GPS, SATLOC,or perhaps particular parts
like wings, etc.
In nearly 40 years of crop dusting/spraying worldwide I don't recall
hearing of more than a couple spray planes ever being stolen.
Helicopters are a different story....
Ol Shy & Bashful
Old November 9th 04, 01:51 PM
CV
The aircraft in the picture doesn't quite look like a Pawnee
to me. Is the picture flattened out a bit perhaps or is it
really some other model ?
CV
Presidewnt reagan's Missing Man Formation tony Piloting 45 June 16th 04 11:00 AM
missing man formation for Reagan Paul Hirose Military Aviation 1 June 14th 04 12:50 AM
Is it time to arm crop duster pilots as well as airline pilots? Larry Dighera Piloting 12 April 6th 04 08:47 PM
Search for missing plane C J Campbell Piloting 2 March 4th 04 01:42 AM
Ellery Queen and the Case of the Missing Magneto Gear Teeth MikeremlaP Owning 3 July 26th 03 03:01 AM
