Hello, I am back.
http://www.geocities.com/abhi_yaan I built this action device for generating unidirectional force for reactionless propulsion of body. As everybody knows, loss of matter is the problem with Newton's third law of motion. We have sources of energy like sun out there in space. But we just can't use solar power to give thrust to spaceship. There should be some mechanism to use pure energy to give thrust to a body without pushing or expelling any reaction mass. So I built this device and yesterday tested this device. I used two rod, wooden platform as rolling seat. I put this rolling seat on cot and using this device I succeeded moving the cot on ground. The device is working because I have not pushed or expellled any mass to push the cot. I was sitting on rolling seat on cot. So the device works. But today, I noticed that I am sitting on this rolling seat on cot and pulled one end of cot with just "my both hands" with *sudden surge of force* and cot moved on floor. This should not happen. If I pull the cot slowly, it will not move. I also noticed that even without rolling seat, simply sitting on cot, if I give sudden surge of force to cot, cot moves on floor. Due to friction of my body with cot, this should not happen. Believe me, I have pushed the cot for about a feet on ground just sitting on rolling platform on cot. I didn't used any reaction mass. I thought that something is wrong and I must return to basic. If I pull wall, wall also pulls me. In reality, due to friction of our leg with ground, our body seldom moves towards wall. But if we use frictionless surface or rolling surface, then if we pull wall, wall also pulls our body. Tested by millions. I am standing on this rolling platform. If I pull wall slowly, wall also pulls me and my whole body moves towards wall. But if I pull the wall towards me with "sudden surge of force", then even if I am standing on rolling platform, my body does not move at all. This is 26th month thinking on Newton's third law of motion day and night. I have suffered so much. What the hell is going on? We can propel a body without pushing/expelling any reaction mass and we can do it by simply giving "sudden surge of force by our hand" to a body. That body gains momentum and due to momentum of that body, we, source of sudden surge of force, also moves in direction of motion of body because of momentum of that body. No loss of matter, no expulsion of reaction mass. Solution to Newton's third law of motion: *Sudden Surge of Force*? -Abhi. ===================================== http://www.geocities.com/abhi_yaan |
Jeet wrote:
Hello, I am back. http://www.geocities.com/abhi_yaan I built this action device for generating unidirectional force for reactionless propulsion of body. [snip] Your ignorance, incompetence, and psychosis are not of interest to the world at large. Quite the contrary. You are not even an interesting laughingstock. You see yourself this way, http://www.mazepath.com/uncleal/effete6.jpg The entire remainder of the planet sees you this way, http://www.mazepath.com/uncleal/effete3.png -- Uncle Al http://www.mazepath.com/uncleal/ (Toxic URL! Unsafe for children and most mammals) http://www.mazepath.com/uncleal/qz.pdf |
Jeet wrote:
Hello, I am back. http://www.geocities.com/abhi_yaan I built this action device for generating unidirectional force for reactionless propulsion of body. Really? As everybody knows, loss of matter is the problem with Newton's third law of motion. I wouldn't call it a problem. We have sources of energy like sun out there in space. But we just can't use solar power to give thrust to spaceship. Why not? You just put out a sail that reflects photons backwards. That will push you forward. The photons are reacting. The sun doesn't have to. John Anderson |
On 18 Nov 2004 15:29:25 -0800, (Jeet)
wrote: Hello, I am back. http://www.geocities.com/abhi_yaan I built this action device for generating unidirectional force for reactionless propulsion of body. As everybody knows, loss of matter is the problem with Newton's third law of motion. We have sources of energy like sun out there in space. But we just can't use solar power to give thrust to spaceship. There should be some mechanism to use pure energy to give thrust to a body without pushing or expelling any reaction mass. So I built this device and yesterday tested this device. I used two rod, wooden platform as rolling seat. I put this rolling seat on cot and using this device I succeeded moving the cot on ground. The device is working because I have not pushed or expellled any mass to push the cot. I was sitting on rolling seat on cot. So the device works. But today, I noticed that I am sitting on this rolling seat on cot and pulled one end of cot with just "my both hands" with *sudden surge of force* and cot moved on floor. This should not happen. If I pull the cot slowly, it will not move. I also noticed that even without rolling seat, simply sitting on cot, if I give sudden surge of force to cot, cot moves on floor. Due to friction of my body with cot, this should not happen. Believe me, I have pushed the cot for about a feet on ground just sitting on rolling platform on cot. I didn't used any reaction mass. I thought that something is wrong and I must return to basic. If I pull wall, wall also pulls me. In reality, due to friction of our leg with ground, our body seldom moves towards wall. But if we use frictionless surface or rolling surface, then if we pull wall, wall also pulls our body. Tested by millions. I am standing on this rolling platform. If I pull wall slowly, wall also pulls me and my whole body moves towards wall. But if I pull the wall towards me with "sudden surge of force", then even if I am standing on rolling platform, my body does not move at all. This is 26th month thinking on Newton's third law of motion day and night. I have suffered so much. What the hell is going on? We can propel a body without pushing/expelling any reaction mass and we can do it by simply giving "sudden surge of force by our hand" to a body. That body gains momentum and due to momentum of that body, we, source of sudden surge of force, also moves in direction of motion of body because of momentum of that body. No loss of matter, no expulsion of reaction mass. Solution to Newton's third law of motion: *Sudden Surge of Force*? -Abhi. ===================================== http://www.geocities.com/abhi_yaan Oh, God. How's the implant? |
| Hardware and software for motion platform | [email protected] | Home Built | 0 | November 4th 04 11:57 PM |
| Weeks Solution and Weeks Special | Mirco | Aerobatics | 0 | October 2nd 04 05:11 PM |
| OPINIONS: THE SOLUTION | ArtKramr | Military Aviation | 4 | January 7th 04 11:43 PM |
| Low Cost Motion Simulators For PC Games!!!! | Mark Barry | Military Aviation | 0 | December 19th 03 04:37 AM |
| Full motion home flight simulator. | The Enlightenment | Naval Aviation | 10 | November 25th 03 01:36 PM |
