OK, so you fly your 4-cylinder Lycoming to a small airport in cold
weather, and if your plane is like mine (Archer O-360), starting in frigid weather without preheat or an hour in a warm hangar is nearly impossible. I haven't ever flown to an airport where there was not an FBO with a hangar or preheat to bail me out, but now I need to. Question: Is it enough to wrap the blanket around the cowl and plug in the Tanis even though the plane is sitting outside with the cold wind? How often do airports offer this? MV Gossman |
Depending on "how" cold it is, and if the wind is blowing, it could be
enough. I've done it several times without a blanket and without cowl plugs at 20 degrees with out any problems. I would try to park the plane near or in as much shelter as I could find, even pushing it nose first up close to a building to keep the wind out of the cowling or at least facing the plane away from the wind. The blankets will give you the most "bang for your buck". Put a blanket on the cowl, plug up the openings in the cowl and plug in the heater. If you have access to a "trouble light", in addition to the tanis, you could lay the trouble light in the bottom of the cowl for extra heat, just keep it away from the carburetor. (but you mentioned you had an Archer, so unless you feel like removing the entire top half of the cowl, this doesn't seem reasonable) If it's seriously cold, (drastic measures coming soon....) you have the option of draining the oil and taking it with you, heating it up and keeping it warm, then pouring it back in the engine before you leave. There is also a method of carrying a short piece of 3" diameter stove pipe and a large propane torch. Insert the stove pipe over the exhaust pipe, light the torch and insert it in the lower end of the stove pipe, let the heat rise up the pipe through the exhaust system. I think FE Potts used a gasoline blow torch for this method as there was always gasoline available from the tanks. I think he also had a method of using a small Weber grill and some charcoal, setting it under the spinner then draping a blanket clear over the entire cowl to catch all the heat. Drastic but effective and no doubt a bit smelly. I would try to think about what is available at your destination (electricity? propane? fuel oil?) and take what ever kind of heater I could use along with me, then obtain what ever kind of fuel it took at my destination. A piece of scat tube or flexible clothes dryer tube or FE Potts stove pipe can be used to route the heat up through the bottom of the cowl. You could carry a 1500 watt ceramic heater or one of those hot air paint strippers along with you for this purpose, it would also allow you to pre-heat the cabin before you depart. After you get it started, just take it easy and let everything come up to temperature before pushing it to the firewall. Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.799 / Virus Database: 543 - Release Date: 11/19/2004 |
Do a google search of this group.
Honeck did what you are asking last winter in Wisconsin. Mitchel Gossman wrote: OK, so you fly your 4-cylinder Lycoming to a small airport in cold weather, and if your plane is like mine (Archer O-360), starting in frigid weather without preheat or an hour in a warm hangar is nearly impossible. I haven't ever flown to an airport where there was not an FBO with a hangar or preheat to bail me out, but now I need to. Question: Is it enough to wrap the blanket around the cowl and plug in the Tanis even though the plane is sitting outside with the cold wind? How often do airports offer this? MV Gossman |
MV,
Suggestion: go to AVweb (www.avweb.com) click on "columns" and then on "The Pilot's Lounge", scroll down to the piece on cold weather operations. In a nutshell, if you can run an extension cord to the airplane and put a blanket or sleeping bag over the cowl, you should be fine. Most cold weather FBOs will help you if you bring at least 100 feet of extension cord. Allow several hours for the Tanis system to heat things up and use bungees or rope to hold the sleeping bag in place on the cowling and find something to plug the cooling intakes. If possible, because you have an extension cord running to the airplane, set up some sort of heater in the cabin (even a drop cord lightbulb helps and something to heat the battery so it will provide some cranking power. I've used a long extension cord with a three prong plug so that I can plug in the Tanis, a light bulb heater in the cabin (your gyros aren't necessarily accurate if the cabin temp is under 40 degress F, and a lightbulb heater at the battery and master switch solenoid area. If you want a very good book on cold weather ops, get Fred Potts' book on bush flying available at www.fepco.com. All the best, Rick (Mitchel Gossman) wrote in message . com... OK, so you fly your 4-cylinder Lycoming to a small airport in cold weather, and if your plane is like mine (Archer O-360), starting in frigid weather without preheat or an hour in a warm hangar is nearly impossible. I haven't ever flown to an airport where there was not an FBO with a hangar or preheat to bail me out, but now I need to. Question: Is it enough to wrap the blanket around the cowl and plug in the Tanis even though the plane is sitting outside with the cold wind? How often do airports offer this? MV Gossman |
FBO with a hangar or preheat to bail me out, but now I need to. Question: Is it enough to wrap the blanket around the cowl and plug in the Tanis even though the plane is sitting outside with the cold wind? How often do airports offer this? Depends on the airport. Call the airport manager per the AOPA Directory. For example, SSQ (Shell Lake WI) has a warm building, an outside accessible outlet, but bring your own extension cords. We have a posted list of local volunteers to help too. SSQ manager |
the Tanis even though the plane is sitting outside with the cold wind? Sure. We do it all the time. Last year I parked our plane in Wisconsin on the coldest weekend of the year. The temperatures were below zero, and the wind was howling. My oil temps were above 35 degrees at start-up -- considerably lower than the 80 - 90 that the pan and cylinder heaters usually achieve in my hangar, but certainly plenty warm compared to the ambient temperature. Here are some pix from that trip: http://alexisparkinn.com/frigid_january.htm . The blanket is the key. Without a form-fitting, well secured blanket, all of your heat will just blow away. (And don't underestimate the wind. It WILL remove your blanket unless it's velcro'd on securely.) How often do airports offer this? Most Midwestern airports have outside outlets -- but you can't always count on having a long enough extension cord. We carry a 100 foot extension cord whenever we fly in the winter. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
You've got a Tanis and the best it could do at zero degrees was a 35
degree oil temp? That's pathetic. Hard to tell by your pictures but it looks like you've got a Kennon fitted nose mitten there. I have a Kennon as well and at zero degrees my two 50 watt oil pan heaters from Tractor Supply keep the oil at 100F and each CHT/EGT at 80F. Wind is not a factor with the cover, although I always try to park facing into the wind to help the controls. When I go to start the plane it thinks it's the middle of July. Never understood why people **** away hundreds of dollars on a Tanis and then you find out their oil temp is 35F on a zero day. Jay Honeck wrote: Question: Is it enough to wrap the blanket around the cowl and plug in the Tanis even though the plane is sitting outside with the cold wind? Sure. We do it all the time. Last year I parked our plane in Wisconsin on the coldest weekend of the year. The temperatures were below zero, and the wind was howling. My oil temps were above 35 degrees at start-up -- considerably lower than the 80 - 90 that the pan and cylinder heaters usually achieve in my hangar, but certainly plenty warm compared to the ambient temperature. Here are some pix from that trip: http://alexisparkinn.com/frigid_january.htm . The blanket is the key. Without a form-fitting, well secured blanket, all of your heat will just blow away. (And don't underestimate the wind. It WILL remove your blanket unless it's velcro'd on securely.) How often do airports offer this? Most Midwestern airports have outside outlets -- but you can't always count on having a long enough extension cord. We carry a 100 foot extension cord whenever we fly in the winter. |
degree oil temp? That's pathetic. Hard to tell by your pictures but it looks like you've got a Kennon fitted nose mitten there. I have a Kennon as well and at zero degrees my two 50 watt oil pan heaters from Tractor Supply keep the oil at 100F and each CHT/EGT at 80F. Wind is not a factor with the cover, although I always try to park facing into the wind to help the controls. When I go to start the plane it thinks it's the middle of July. Never understood why people **** away hundreds of dollars on a Tanis and then you find out their oil temp is 35F on a zero day. Actually, the nose cover is something Mary made from a cheap sleeping bag, and a bunch of velcro. Cost about $15 bucks, and works great. We were unable to park the plane into the wind, due to the snow, ice, and the position of the one outlet that actually worked. As a result, the sub-zero wind (and it was howling) was able to get under and inside the cover all night long. The fact that the oil was at least 45 degrees above ambient despite all this was fairly remarkable, I thought. Under less severe wind conditions, it easily keeps the engine in the 80s. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 05:12 AM |
Please help -- It's down to the wire | Jay Honeck | Home Built | 12 | July 14th 04 06:05 PM |
Ice meteors, climate, sceptics | Brian Sandle | General Aviation | 43 | February 24th 04 12:27 AM |
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Home Built | 18 | January 20th 04 04:02 PM |
