Looking for good brake masters for homebuilt project.
Old March 28th 04, 06:17 AM
clare @ snyder.on .ca
Default Looking for good brake masters for homebuilt project.
Just wondering if anyone has a good set of used brake masters
gathering dust that they'd like to sell reasonably. Needed for 2
seater side-by side using 6" Cessna wheels and brakes. Prefer 4 cyls
for full dual control, but either a pair of integral reservoir or
external reservoir cyls would be a start.
Need to ship to Ontario Canada - Canadian source preferred but not
essential.
Thanks.
Old March 28th 04, 04:57 PM
Emerauder
clare @ snyder.on .ca wrote in message
Look into fabricating a mechanical linkage to tie the pedals together for
dual control instead of using four cylinders. IMO, this has several
advantages:
1. lighter weight (possibly).
2. fewer fittings and connections to leak.
3. a LOT easier to bleed the air out of the system.
4. two less cylinders to malfunction and maintain.
Rich S.
Old March 28th 04, 07:55 PM
On Sun, 28 Mar 2004 06:57:46 -0800, "Emerauder"
advantages:
Rich S.
Thought of that - if a tandem it would be a no-brainer.
I doubt the linkage could be built "much" lighter, if at all, than a
second set of cyls.
It would be much more complex, with more chance of failure.
Bleeding bottom up solves the bleeding problem.
Old March 28th 04, 09:11 PM
Del Rawlins
In clare @ snyder.on .ca
B&B aircraft supply has new surplus Gerdes long stroke master cylinders
available, and the price was $95/pair when I bought a set last summer.
These are the cylinders recommended for use with the Bearhawk, which is
designed to use 6.00-6 Cleveland wheels. They are also identical to the
cylinders used in older Citabrias with heel brakes, right down to the
part number printed on the side. They require a remote reservoir.
B&B Aircraft Supply
PO Box 37
Gardner, KS 66030
(913) 884-5930
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Building the Po' Boy Bending Brake Veeduber Home Built 14 March 1st 04 07:15 PM
