too much gyro vacumn?
Old March 29th 04, 01:14 AM
Ray Toews
Default too much gyro vacumn?
I am removing the vac T&B and putting in an electric and thinking of
removing the regulator and then apply full venturi vacumn to the
horizon. Is it possible to over rev a gyro with an outside venturi?
I am doing this because even after a 15 min runup I am several miles
off the runway before the horizon stabilizes, not that great on a nite
takeoff.
Ray
Old March 29th 04, 01:48 AM
Orval Fairbairn
takeoff.
Ray
Vacuum gyros are meant to operate at a specified vacuum level, in order
to maintain their proper RPM. Applying extra vacuum would cause them to
spin too fast and cause premature wear on the bearings.
This is one of many reasons for vacuum pumps, instead of venturis.
Old March 29th 04, 02:58 AM
Bill Daniels
"Orval Fairbairn" wrote in message
news
takeoff.
Ray
Uh..don't think so. There is a vacuum regulator in the system.
I had an emergency vacuum system on my Archer made by Precise Flight that
used full engine manifold vacuum in place of the vacuum pump should it fail
and the regulator still delivered a steady vacuum at 4" H2O. I don't think
a venturi would ever produce as much vacuum as an engine at idle.
Now that I think of it, the pitot/static pressure differential at 80 knots
is 4" of water column - the same as the vacuum instruments need. Over 80
knots, you don't need a venturi, just ram air and a static port outlet - and
filters, of course.
Bill Daniels
Old March 29th 04, 04:59 AM
COUGARNFW
Ray...
Not enough information. You did not mention which venturi...four inch, 8 inch,
9 inch?
Older gyros required 4 or a bit above...and the horizon unit required all of
the volume of flow the four inch could give, so no other device should be
paralleled with it. (a four inch could supply a DG and, through a flow limiter
which you did not mention but might still be there, a T&B)
If an 8 inch or 9 inch venturi, then you either keep the regulator (and measure
that it is set for the gyro you use and what it needs...newer ones like 5.x
rather than the four inches) or ensure early failure of the gyro.
Neal
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 15th 04 11:30 PM
3-seat gyro on video Mr.Twistair Home Built 0 February 5th 04 12:17 PM
Turn and Bank - RC Allen vs Electrical Gyro Corp Kevin Horton Home Built 0 December 1st 03 12:46 AM
Gyro Copter for Sale on EBAY EC155 Pilot Home Built 0 November 1st 03 11:34 PM
I Wanna Build an Aeroplane Badwater Bill Home Built 71 August 19th 03 02:24 PM
