Hi all
Was purusing the Marske flying wing glider website.....pretty cool tooo....look ma, no horizontal stabilizers or computer controls.... http://www.continuo.com/marske/carbon/carbon.html Anyway, he also sells extruded carbon fiber rod....the stuff is amazing! 14 times the tensile strength per pound of 6061 AL and 4 times the stiffness per pound! Now, that sure makes you want to incorporate the stuff into the more critical areas of a composite structure (like the spar cap etc etc...)... The problem is.....your gonna have to incoportate it into your hand laid up epoxy/fiber construction....and I'd always wonder about how much I could expect the strength of my homemade composite material to be.... So, if I was designing using this stuff....I'd probably just use "normal" numbers for homebuilt level composite strengths and throw in some of this stuff for a fudge factor/piece of mind when it came to ultimate strength... Which brings me to my question.....if you are doing homemade carbon fiber layups...and you are reasonably careful in its construction....what kind of real world numbers can you expect for strength and stiffness per pound over aluminum? 2x? 3x? 4 x?..... take care Blll |
![]() (Bob Kuykendall) wrote: Here's a couple of pictures of my Graphlite-strip based wing spar: http://www.hpaircraft.com/hp-24/update_4_dec_02.htm http://www.hpaircraft.com/hp-24/update_21_March_04.htm Bob, I can't quite figure out the structure of your spar shear web from the information on your website. Could you enlighten me please? David O -- http://www.AirplaneZone.com |
Earlier, David O wrote
I can't quite figure out the structure of your spar shear web from the information on your website. Could you enlighten me please? Basically, the spar is female-molded in two C-sections, with an exterior wrap of bias cloth and then the carbon strips and the foam shear web stiffener. The bias cloth is doubled on the back of the C. After they're cured, the two C-sections get bonded back to back. Here's a cross-section diagram of one of the spar C-sections: http://www.hpaircraft.com/hp-24/typical_x-section.GIF That cross-section is pretty much as shown on this Marske page: http://www.continuo.com/marske/carbon/carbon.htm Scroll to the figure titled "typical I-beam spar construction." Also, note that in the photos on the Web site, the spar stub still isn't finished with mating pin provisions or the final shear wraps. There are some pictures of the plug we used to make the spar molds on this Update page: http://www.hpaircraft.com/hp-24/update_3_june_02.htm Thanks, and best regards to all Bob K. http://www.hpaircraft.com |
![]() (Bob Kuykendall) wrote: Earlier, David O wrote I can't quite figure out the structure of your spar shear web from the information on your website. Could you enlighten me please? Basically, the spar is female-molded in two C-sections, with an exterior wrap of bias cloth and then the carbon strips and the foam shear web stiffener. The bias cloth is doubled on the back of the C. After they're cured, the two C-sections get bonded back to back. Here's a cross-section diagram of one of the spar C-sections: http://www.hpaircraft.com/hp-24/typical_x-section.GIF That cross-section is pretty much as shown on this Marske page: http://www.continuo.com/marske/carbon/carbon.htm Scroll to the figure titled "typical I-beam spar construction." Also, note that in the photos on the Web site, the spar stub still isn't finished with mating pin provisions or the final shear wraps. There are some pictures of the plug we used to make the spar molds on this Update page: http://www.hpaircraft.com/hp-24/update_3_june_02.htm Thanks, and best regards to all Bob K. http://www.hpaircraft.com Thanks for the detailed reply. What had me puzzled is the surface denoted by the arrow in the following picture doesn't appear to be glassed. http://www.airplanezone.com/NewsgroupPix/Temp.JPG I'll be out of town for a couple of days. I'll pull the picture when I return. Thanks. David O -- http://www.AirplaneZone.com |
Earlier, David O wrote:
Thanks for the detailed reply. What had me puzzled is the surface denoted by the arrow in the following picture doesn't appear to be glassed. http://www.airplanezone.com/NewsgroupPix/Temp.JPG Ah, thanks, I see now. The denoted area _is_ laminated with fiberglass. The surface texture that the arrow points to is just dust on the surface. The nearby streaks are where the dust got rubbed off. Those spars have been waiting around for quite a while, now - it's been about a year and a half since the parts popped out of the molds in early September 2002. And I've not been known to do much sweeping or dusting around the shop... Thanks again, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
