Howdy,
Just started taking flying lessons (6 hours ground and 7 hours in the air) and I've been reading up on everything like accessories, techniques, etc plus lurking here for a week. During this time, I noticed the difference between military andcivilian headsets, and if I understand correctly, the military headsets are a single plug versus the two plug civilian ones. I've searched the newsgroup for an explanation why the civilian sector hasn't switched to single plug system too? It seems like it would make things easier, less points for failure, etc. I understand that there's a lot of built in support for the existing two plug system, but I'd expect the civilian radios to start having support for both while everyone switched over over a 20 year or so period. Is that the case? Do new radios have both types of plugs? Or is there another reason why civilian headsets use the two plug system? Thanks! |
"Ben Hallert" wrote in message oups.com... Howdy, Just started taking flying lessons (6 hours ground and 7 hours in the air) and I've been reading up on everything like accessories, techniques, etc plus lurking here for a week. During this time, I noticed the difference between military andcivilian headsets, and if I understand correctly, the military headsets are a single plug versus the two plug civilian ones. I've searched the newsgroup for an explanation why the civilian sector hasn't switched to single plug system too? It seems like it would make things easier, less points for failure, etc. I understand that there's a lot of built in support for the existing two plug system, but I'd expect the civilian radios to start having support for both while everyone switched over over a 20 year or so period. Is that the case? Do new radios have both types of plugs? Or is there another reason why civilian headsets use the two plug system? Well, the PL-259 or the PL-55 is exactly the same whether it is used on a military or civilian headset. My military flight helmet used a completely different connector, altogether. But I don't fly the Cessna with a military type helmet. Can you be more specific, like with model numbers? |
Well, my understanding is that military headsets use a single
integrated connector and civilian headsets use two connectors, one for headphone, one for microphone. Is that not correct? |
"Ben Hallert" wrote in message oups.com... Well, my understanding is that military headsets use a single integrated connector and civilian headsets use two connectors, one for headphone, one for microphone. Is that not correct? Yes that is correct. Over here we refer to the single plug connector as a NATO plug. See this link http://www.transair.co.uk/category.a...tegory_ID=1395 |
"Ben Hallert" wrote in message oups.com... Well, my understanding is that military headsets use a single integrated connector and civilian headsets use two connectors, one for headphone, one for microphone. Is that not correct? or even this link http://www.transair.co.uk/category.a...tegory_ID=1355 |
I can tell you that almost all helicopter headsets have a single
connector jack, and so when I fly helicopters with my Lightspeed headset (that has two plugs) I have to use an adaptor. This annoys me. (I started to say "to no end" but - "all" it means is that I have to buy a $30 adaptor and try not to lose it.) So perhaps this is what you're referring to? Dave Blevins On 17 Dec 2004 16:43:03 -0800, "Ben Hallert" wrote: Howdy, Just started taking flying lessons (6 hours ground and 7 hours in the air) and I've been reading up on everything like accessories, techniques, etc plus lurking here for a week. During this time, I noticed the difference between military andcivilian headsets, and if I understand correctly, the military headsets are a single plug versus the two plug civilian ones. I've searched the newsgroup for an explanation why the civilian sector hasn't switched to single plug system too? It seems like it would make things easier, less points for failure, etc. I understand that there's a lot of built in support for the existing two plug system, but I'd expect the civilian radios to start having support for both while everyone switched over over a 20 year or so period. Is that the case? Do new radios have both types of plugs? Or is there another reason why civilian headsets use the two plug system? Thanks! |
Boeing jets (727s at least) also use two jacks, just like spam cans. I use
my Telex 5x5 1R in my Seneca, as well as on the job. wrote in message ... I can tell you that almost all helicopter headsets have a single connector jack, and so when I fly helicopters with my Lightspeed headset (that has two plugs) I have to use an adaptor. This annoys me. (I started to say "to no end" but - "all" it means is that I have to buy a $30 adaptor and try not to lose it.) So perhaps this is what you're referring to? Dave Blevins On 17 Dec 2004 16:43:03 -0800, "Ben Hallert" wrote: Howdy, Just started taking flying lessons (6 hours ground and 7 hours in the air) and I've been reading up on everything like accessories, techniques, etc plus lurking here for a week. During this time, I noticed the difference between military andcivilian headsets, and if I understand correctly, the military headsets are a single plug versus the two plug civilian ones. I've searched the newsgroup for an explanation why the civilian sector hasn't switched to single plug system too? It seems like it would make things easier, less points for failure, etc. I understand that there's a lot of built in support for the existing two plug system, but I'd expect the civilian radios to start having support for both while everyone switched over over a 20 year or so period. Is that the case? Do new radios have both types of plugs? Or is there another reason why civilian headsets use the two plug system? Thanks! |
of all the posts.. I have not seen an answer as to why.. but simply
confirming that they indeed are different. Military headsets have a different microphone impedance and different headset capabilities.. microphones have to be right on the lips to pick up the voice, so as not to pick up the aircraft noise. I few military for twenty years, had my "issue" helmet and headset, and also my civilian headset for personal flying. I tried the adapter at one time, by with my military headset in a civil setting, the mic would not work and only one side of the speakers. Maybe they are different because the military did not want to mess with two cords? two jacks? and many times I've had to swap headset to helmet and cannot see where the plug in is to swap out but had to go by feel. Why mess with two different sized plugs when one will do. Many "civil" aircraft allowed a hand mic and public speaker combination so you did not have to wear a headset, to do that would require two plugs, one mic, one speaker. Or an intercom panel switch to allow you to select the speaker output. BT "Ben Hallert" wrote in message oups.com... Howdy, Just started taking flying lessons (6 hours ground and 7 hours in the air) and I've been reading up on everything like accessories, techniques, etc plus lurking here for a week. During this time, I noticed the difference between military andcivilian headsets, and if I understand correctly, the military headsets are a single plug versus the two plug civilian ones. I've searched the newsgroup for an explanation why the civilian sector hasn't switched to single plug system too? It seems like it would make things easier, less points for failure, etc. I understand that there's a lot of built in support for the existing two plug system, but I'd expect the civilian radios to start having support for both while everyone switched over over a 20 year or so period. Is that the case? Do new radios have both types of plugs? Or is there another reason why civilian headsets use the two plug system? Thanks! |
Maybe most folks here don't remember the days when we flew with microphones
only. There was no provision for headsets and we didn't wear 'em. When headset came to general aviation (probably because we were all going deaf) they had to provide another receptacle for the ear phones. That socket had to be a different diameter so the two couldn't be confused or mixed up. Rod "BTIZ" wrote in message news:MdZwd.104$iD.82@fed1read05... of all the posts.. I have not seen an answer as to why.. but simply confirming that they indeed are different. Military headsets have a different microphone impedance and different headset capabilities.. microphones have to be right on the lips to pick up the voice, so as not to pick up the aircraft noise. I few military for twenty years, had my "issue" helmet and headset, and also my civilian headset for personal flying. I tried the adapter at one time, by with my military headset in a civil setting, the mic would not work and only one side of the speakers. Maybe they are different because the military did not want to mess with two cords? two jacks? and many times I've had to swap headset to helmet and cannot see where the plug in is to swap out but had to go by feel. Why mess with two different sized plugs when one will do. Many "civil" aircraft allowed a hand mic and public speaker combination so you did not have to wear a headset, to do that would require two plugs, one mic, one speaker. Or an intercom panel switch to allow you to select the speaker output. BT "Ben Hallert" wrote in message oups.com... Howdy, Just started taking flying lessons (6 hours ground and 7 hours in the air) and I've been reading up on everything like accessories, techniques, etc plus lurking here for a week. During this time, I noticed the difference between military andcivilian headsets, and if I understand correctly, the military headsets are a single plug versus the two plug civilian ones. I've searched the newsgroup for an explanation why the civilian sector hasn't switched to single plug system too? It seems like it would make things easier, less points for failure, etc. I understand that there's a lot of built in support for the existing two plug system, but I'd expect the civilian radios to start having support for both while everyone switched over over a 20 year or so period. Is that the case? Do new radios have both types of plugs? Or is there another reason why civilian headsets use the two plug system? Thanks! |
"Rod Madsen" wrote in message .. . Maybe most folks here don't remember the days when we flew with microphones only. There was no provision for headsets and we didn't wear 'em. When headset came to general aviation (probably because we were all going deaf) they had to provide another receptacle for the ear phones. That socket had to be a different diameter so the two couldn't be confused or mixed up. I belive Rod has hit the nail on the head. Unfortuatly, I couldn't hear it. |
| Updated List of Military Information-Exchange Forums | Otis Willie | Naval Aviation | 0 | November 29th 04 03:16 AM |
| 22 Aug 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | August 24th 04 07:47 AM |
| 22 Aug 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | August 24th 04 07:46 AM |
| bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 05:26 PM |
| 12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 13th 03 12:01 AM |
