Has anyone seen wheelbarrowing occur? Prima facie, it appears too
improbable (ludicrous almost) a thing to happen but even the FAA Airplane Flying Handbook copy that I have mentions it! Also, while the ways of performing a flare is mentioned at many places, the reason for a flare is conspicuously absent everywhere. Just why is a flare needed vis-a-vis a 3-point landing? After all, birds just come in and sit, without having to flare... Ramapriya |
Hi Ramapriya,
Ok, I'm game. It's Christmas morning here and I just work up. You really need to start taking flight lessons. You have way too much interest in all this to let it go to waste. I'll answer your last question (topic) first, since it is also related to your first question (topic) about 3 point landings. Wheel barrowing (also known as porpoising) is a phenomenon which can occur when you land flat, or on the nose wheel first, in tricycle gear aircraft. It happens, I've seen it performed perfectly a few times by student and non-student pilots. If in fact you saw the pilot do this, then you witnessed poor pilot technique, regardless of the aircraft he was flying. Landing flat and especially landing on the nose wheel first is an invitation to wheel barrow, not to mention that the nose gear is not designed to withstand the forces generated on it from such a landing. Take a look at any tricycle gear aircraft and compare the main gear to the nose gear and it becomes quite obvious as to why you want to land on the mains first. Wheelbarrowing (porpoising) can quickly damage or destroy an aircraft if not recovered from immediately. This is but one of the reasons for the 'flare' you questioned, along with the fact that the flare is also a means of slowing the aircraft down, thus eventually going from flying speed, to stall speed, to wont fly anymore hit the ground and roll out speed. If you look at birds very closely, especially in slow motion video, you will see that they do indeed flare just before landing. Watch their wings closely. A bit of a mention about 3 point landings. Technically there is no such thing as a 3 point landing in a tricycle gear aircraft. What you saw is referred to as 'landing flat or a flat landing'. A 3 point landing is when referring to a tail wheel aircraft that lands on the mains and tail simultaneously, or even the mains and then the tail touches a second later. Now on to your second post. "3 more questions" 1. A crosswind is a crosswind, regardless of whether you are taking off or landing. The wind is still coming from 'across' the runway rather than straight down the runway. The procedure 'simplified' is apply whatever rudder is required to keep the nose pointed straight down the centerline, with ailerons deflected into the wind. As speed increases it will require less and less rudder and aileron. 2. If you 'tilt' the wing too much you certain can, and pilots have had engine strikes. But it takes quite an impressive bank to do so. If it requires that much of a 'tilt' or bank, then what that is telling you is that the crosswind is too much for that aircraft in it's current configuration. The same can be said for not having enough rudder to keep the nose going straight down the runway. If it's a really significant crosswind, then it's much easier for the novice to discern that it really does require a combination of both rudder and aileron to land. 3. You slip the aircraft by cross controlling. i.e opposite rudder and aileron. I sudden draft, or gust, can blow an aircraft a 'off-center' regardless of whether they are slipping or not. It's just a matter of experience, training and anticipating and then going around if you don't like what you're seeing. Every pilot on this form has different thresholds as to what type of winds and gust are acceptable to them, and what type of sight picture they're comfortable with before they tuck tail and perform a go around. Hope that answered your questions appropriately in my half asleep state. But heck, that's how I fly half the time anyway. PJ ============================================ Here's to the duck who swam a lake and never lost a feather, May sometime another year, we all be back together. JJW ============================================ "Ramapriya" wrote in message ups.com... Has anyone seen wheelbarrowing occur? Prima facie, it appears too improbable (ludicrous almost) a thing to happen but even the FAA Airplane Flying Handbook copy that I have mentions it! Also, while the ways of performing a flare is mentioned at many places, the reason for a flare is conspicuously absent everywhere. Just why is a flare needed vis-a-vis a 3-point landing? After all, birds just come in and sit, without having to flare... Ramapriya |
"PJ Hunt" wrote
I'll answer your last question (topic) first, since it is also related to your first question (topic) about 3 point landings. PJ, note that Ramapriya's questions deal primarily with jet transports. Wheel barrowing (also known as porpoising) Wheel-barrowing and porpoising are NOT the same. Wheel-barrowing always results from a too-high speed on the ground and the airpane's attitude remains relatively stable in a nose too-low attitude. Porpoising results from landing on the nose wheel in a nose-low attitude resulting in the airplane rebounding into a nose-high attitude and then repeating this "porpoising" maneuver. Wheel-barrowing can also occur during takeoff when one attempts to hold the airplane on the ground after normal take- off speed. 2. If you 'tilt' the wing too much you certain can, and pilots have had engine strikes. Jetliner takeoff wings-level to avoid this situation. The same can be said for not having enough rudder to keep the nose going straight down the runway. That's what the nose-wheel steering is for. 3. You slip the aircraft by cross controlling. Never done in jetliners...too uncomfortable for the passengers. Bob Moore CFI ATP B-707 B-727 |
I've never seen a bird land without flaring. Don't know where you got that,
but they most certainly do flare. I used to have an ultralight and when I was fast taxi testing it, I noticed that the back wheels got light first. It turned out it was somewhat out of rig, but there was really nothing I could do about it. Once I got sort of good in the thing, I used to let the back wheels come up on takeoff and rolla long on the nosewheel for a while until it would catch a little bump and then I'd pull the nose up. Not reall a wise thing to do, in retrospect, but it was fun and got a lot of looks from whoever might be watching. Also did a fairly nasty (no damage-but embarassing) late roundout in my Tripacer once. It resulted in a pretty good bounce which I had to correct with power for a good landing. They can get ugly quick if you don't react right or, preferably, just go around and try again. mike regish "Ramapriya" wrote in message ups.com... Has anyone seen wheelbarrowing occur? Prima facie, it appears too improbable (ludicrous almost) a thing to happen but even the FAA Airplane Flying Handbook copy that I have mentions it! Also, while the ways of performing a flare is mentioned at many places, the reason for a flare is conspicuously absent everywhere. Just why is a flare needed vis-a-vis a 3-point landing? After all, birds just come in and sit, without having to flare... Ramapriya |
A student busted one of our 150s years ago by wheelbarrowing it. He'd
tried to land twice before, both times too fast and high, and had to go around. This time he was going to land no matter what, and that's when it happened. A good landing starts on downwind. Get the airplane properly positioned, at the right speed and glidepath, start the roundout when still out of ground effect to prevent floating from excessive speed, and touch down on the mains with the nose high. Not as easy as it sounds. Dan |
In article . com, Ramapriya wrote:
Has anyone seen wheelbarrowing occur? Prima facie, it appears too improbable (ludicrous almost) a thing to happen but even the FAA Airplane Flying Handbook copy that I have mentions it! Haven't seen it myself, but it does happen. It's a result of trying to force the airplane onto the runway before it's ready. The nose winds up touching down first. This is bad for several reasons. One of which is that the nose is ahead of the plane's center of gravity, making it directionally unstable. One result of which is the infamous ground loop. Tailwheel airplanes have the same CG/stability issues, so when you hear about ground loops, it's usually associated with them. Also, while the ways of performing a flare is mentioned at many places, the reason for a flare is conspicuously absent everywhere. Just why is a flare needed vis-a-vis a 3-point landing? After all, birds just come in and sit, without having to flare... You don't spend much time watching birds, do you? They do flare. It's not that there's an rule requiring airplanes to flare, it just falls out naturally as you transition from a gliding descent into level flight just above the runway. The idea is to touch down onto the runway at very little (almost zero) sink rate. HTH, Morris |
"Ramapriya" wrote
Also, while the ways of performing a flare is mentioned at many places, the reason for a flare is conspicuously absent everywhere. Just why is a flare needed vis-a-vis a 3-point landing? After all, birds just come in and sit, without having to flare... The flare reduces the rate of descent for a smooth touchdown. Normal rate of descent during approach is probably 500-800 fpm and one would really like to touchdown at less than 100fpm. Of course, the flare also keeps one from putting too much stress on the relatively weaker nosewheel. Note that jets landing on an aircraft carrier do not flare. Bob Moore |
In article , Bob Moore wrote:
"Ramapriya" wrote Note that jets landing on an aircraft carrier do not flare. Jets do not land on carriers. They make controlled crashes. Morris (yeah, old joke, but someone had to say it) |
On Sat, 25 Dec 2004 18:35:35 -0600, Journeyman
wrote: In article , Bob Moore wrote: "Ramapriya" wrote Note that jets landing on an aircraft carrier do not flare. Jets do not land on carriers. They make controlled crashes. Morris (yeah, old joke, but someone had to say it) I've heard it said that Navy pilots basically fly the airplane into the carrier. |
