When I turn on a lot of accessories on my Mooney F '76 I can drop the
bus voltage down to around 13.6. My A&P says 13.6 is normal with accessories on. Does this sound right? -Robert |
"Robert M. Gary" wrote in message oups.com... When I turn on a lot of accessories on my Mooney F '76 I can drop the bus voltage down to around 13.6. My A&P says 13.6 is normal with accessories on. Does this sound right? -Robert At cruise RPM? Sounds like you may have 1 or 2 of the three diodes burnt out in your alternator. Another possibility is that your voltmeter is off. Try checking it with a digital voltmeter, and comparing the two. -- Jim in NC |
Morgans wrote: At cruise RPM? Sounds like you may have 1 or 2 of the three diodes burnt out in your alternator. Another possibility is that your voltmeter is off. Try checking it with a digital voltmeter, and comparing the two. Any RPM between 800 and 2700 gives the same voltage, no change. I normally read the voltage in 4 ways 1) My EDM shows it on the screen 2) My regulator flashes a voltage light on my panel when low 3) My voice annunicator says, "Check bus voltage" and 4) My A&P has been putting his probe all over the place Since I can reproduce this at idle on the ground its easy for the A&P to hook up under the panel. I should also note that... 1) Have a new battery, new master switch, and new regulator 2) I took my regulator and alternator to an aviation electrical overhaul shop. They bench tested the combo at 14v up to 100amp draw. They didn't find any diode issues, but I'm willing to believe they could be wrong. -Robert, M20F '76 |
I guess my question is; do all planes generate about 13.6v with
accessories on? I also teach in a large variety of planes, but none have a volt reader in the panel. |
On 27 Dec 2004 19:15:04 -0800, "Robert M. Gary"
wrote: I guess my question is; do all planes generate about 13.6v with accessories on? I also teach in a large variety of planes, but none have a volt reader in the panel. I'm not a mechanic, but 13.8 volts comes to mind as what I've read on my battery while the engine was running. I'd think .2 volts less under load would be acceptable. You still have 1.6 volts of excess power to charge the battery with so I really wouldn't worry about it. I think sometimes, with the new digital equipment, readings can be more accurate than the tolerances of the old stuff used to build it in the first place. What's the tolerance of your voltage regulator? If it's +/- .5 volts, you've got your answer. My .02. z |
"zatatime" wrote You still have 1.6 volts of excess power to charge the battery with so I really wouldn't worry about it. Actually, the voltage for a lead acid battery should be 12.8 volts, at full charge, not 12 volts. -- Jim in NC |
"Robert M. Gary" wrote: I guess my question is; do all planes generate about 13.6v with accessories on? I also teach in a large variety of planes, but none have a volt reader in the panel. According to AC 43.13-1A -- "The voltage drop in the main power wires from the generation source or the battery to the bus should not exceed 2 percent of the regulated voltage, when the generator is carrying rated current or the battery is being charged at the 5-minute rate. The following tabulation shows the maximum acceptable voltage drop in the load circuits between the bus and the utilization equipment." The table indicates that 1/2 volt is acceptable for a steady load and 1 volt for an intermittent load. This passage is intended to be used to determine whether wiring is properly sized. According to that, you should be seeing at least 13.72 volts at the bus, but as little as 12.72 is acceptable at an appliance that produces a temporary load. George Patterson The desire for safety stands against every great and noble enterprise. |
G.R. Patterson III wrote:
"Robert M. Gary" wrote: a volt reader in the panel. According to AC 43.13-1A -- "The voltage drop in the main power wires from the generation source or the battery to the bus should not exceed 2 percent of the regulated voltage, when the generator is carrying rated current or the battery is being charged at the 5-minute rate. The following tabulation shows the maximum acceptable voltage drop in the load circuits between the bus and the utilization equipment." It's interesting that if I take the alternator and regulator to the bench I can hold 100amp without dropping below 14v. I guess the in-airplane application is a lot different than the bench environement. -Robert |
"Robert M. Gary" wrote: It's interesting that if I take the alternator and regulator to the bench I can hold 100amp without dropping below 14v. I guess the in-airplane application is a lot different than the bench environement. What I posted are the minimal requirements for minimizing voltage drop in the wiring from the regulator to the bus and from the bus to appliances (such as the NAV/COM). The voltage at the regulator on the bench will certainly be different than that measured at the bus. George Patterson The desire for safety stands against every great and noble enterprise. |
G.R. Patterson III wrote: "Robert M. Gary" wrote: a volt reader in the panel. According to AC 43.13-1A -- "The voltage drop in the main power wires from the generation source or the battery to the bus should not exceed 2 percent of the regulated voltage, when the generator is carrying rated current or the battery is being charged at the 5-minute rate. The following tabulation shows the maximum acceptable voltage drop in the load circuits between the bus and the utilization equipment." It's interesting that if I take the alternator and regulator to the bench I can hold 100amp without dropping below 14v. I guess the in-airplane application is a lot different than the bench environement. -Robert |
| Thread Tools | |
| Display Modes | |
| Normal voltage drop | Robert M. Gary | Owning | 19 | January 3rd 05 05:12 AM |
| C182 - Intermittent Alternator | WinstonCup | Owning | 9 | November 12th 04 01:22 AM |
| no RPM drop on mag check | Dave Butler | Owning | 19 | November 2nd 04 03:55 AM |
| Cessna 210 charging problem | John Clonts | Owning | 9 | July 14th 04 04:08 PM |
| Anyone have experience with InterAv alternator | flyer | Home Built | 6 | October 19th 03 04:24 AM |
