As a CFI, if I give training for a private applicant in a J-3, I'm
legal, but to give training for a sport pilot applicant I must get an endorsement in my log book for that airplane and have 5 hrs PIC??? http://www.aopa.org/sportpilot/cfi_certification.pdf Appropriate Category and Class Ratings in LSA (5 hours PIC make and model within a "set" of aircraft additional Category and Class Privileges Endorsed in Logbook) |
I do not believe this is correct.. this would only be the case if you were
only qualified to instruct at the sport pilot level as a Sport Pilot CFI. Then you would need the 5hrs.. moving from one "sport pilot airplane" to another. FAR61, Subpart K, applies to instructors with Sport Pilot ratings, read 61.429, it states that as a FULL CFI, you can exercise the privileges of 61.413 (sport pilot cfi) without further showing of proficiency in the aircraft category and class (airplane SEL), you can't go teach weight shift. To teach in an additional category or class, glider or weight shift etc, you need to follow 61.419. As a FULL FLEDGED CFI, at the FULL COMMERCIAL AIRPLANE level, you can teach a "sport pilot" applicant to the sport pilot level, following the guidance in FAR 61 Subpart J, in a Light Sport Aircraft - Airplane (J3 Cub) So, if I read this correctly, I can take an Airplane CFI, qualify him in gliders at the SP level, and then qualify him to teach in gliders at the SP level. But this same new SP CFI cannot fly or instruct in high performance gliders, he is limited to LSA level gliders and he cannot instruct above the SP Level. SGS 2-33, and SGS 1-26 examples. I am a Commercial rated Glider CFI (FULL CFI). I reviewed the pamphlet from AOPA and I reviewed FAR61 Subpart J and K, and no where did I read the 5hr minimum PIC limitation. Any one have any other thoughts on this? BT "Robert M. Gary" wrote in message oups.com... As a CFI, if I give training for a private applicant in a J-3, I'm legal, but to give training for a sport pilot applicant I must get an endorsement in my log book for that airplane and have 5 hrs PIC??? http://www.aopa.org/sportpilot/cfi_certification.pdf Appropriate Category and Class Ratings in LSA (5 hours PIC make and model within a "set" of aircraft additional Category and Class Privileges Endorsed in Logbook) |
Interestingly, I just got the 2005 FARs. Under the priv's of a CFI (not
sport pilot) it lists all the certificates/ratings you can give training for. Sport pilot is not one of them. 61.193 Also, I assume there will be a new AD 61-65D with all these new endorsements -Robert |
read it again Robert... my copy of 2005 FAR 61.193 says:
"authorized within limitations of the instructors rating (airplane, glider, rotorcraft, instrument (my added)), to give instruction and endorsements that are required for or related to:" a) Student Certificate b) Pilot Certificate c) Flight Instructor d) Ground Instructor e) Aircraft rating f) Instrument rating So... para (b) does not specify , Recreational, Private, Commercial, or Sport Pilot, it says Pilot Certificate.. and para (e) does not specify Light Sport Aircraft... it says.. AIRCRAFT.. which means what ever the CFI holds a rating for. BT "Robert M. Gary" wrote in message oups.com... Interestingly, I just got the 2005 FARs. Under the priv's of a CFI (not sport pilot) it lists all the certificates/ratings you can give training for. Sport pilot is not one of them. 61.193 Also, I assume there will be a new AD 61-65D with all these new endorsements -Robert |
Ah, I think you're right. Thanks!
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Sport Pilot cuts off special issuance at the knees | Juan~--~Jimenez | Home Built | 40 | August 10th 04 02:19 PM |
| sport pilot humor | Occom | Home Built | 0 | April 9th 04 05:22 PM |
| Self fly hire in the US | Nigel | Piloting | 25 | March 28th 04 10:20 AM |
| WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 04:01 PM |
