I guess my question is simply put this way, do you cut power
immediately before touching down? If not, when? I suppose a carrier landing would be an extreme. Only curious. Thank you. |
Well, my power is off at touch down.
When I cut the power depends. Normally I keep some power during final to prevent a too steep descent, my flaps are very effective speed brakes. Sometimes I need a steep descent so I cut the power early and dive Stuka-like to the runway. -Kees. |
Every landing is different and you may or not carry power to touchdown,
or you may cut power while still on the downwind leg. Sometimes you have to add power after you have touched down like with some planes on skis. The snow slows you down so fast you have to add power to get a strong airflow over the elevator to keep it down instead of nosing over. A carrier landing is done with full takeoff power in case of a "bolter" or missed wire and you have to take off immediately. When the pilot feels the sudden deceleration from a confirmed wire, he/she chops the power and the rest of the landing process proceeds. |
Bob
Of course you're right...I didn't explain myself very clearly did I! Semper Fi Rocky |
I cut the power anywhere from immediatly after taking off (Aborted
Takeoff) to just after taxing off the runway(Soft Field Landing) In my Glider I cut the power typically at about 2000' AGL(Release from the Towplane). It usually takes me about 3 hours to get around to actually landing. I power aircraft I normally cut the power on downwind abeam my touch down point and they try to adjust my configuration (Flaps), glide path and airspeed to land at a specified spot on the Runway without having to add power again. But I use a different techniques for Short and Soft Field landings. Brian CFIIG/ASEL |
This is the only way I was taught to land.
"Brian" wrote in message oups.com... I cut the power anywhere from immediatly after taking off (Aborted Takeoff) to just after taxing off the runway(Soft Field Landing) In my Glider I cut the power typically at about 2000' AGL(Release from the Towplane). It usually takes me about 3 hours to get around to actually landing. I power aircraft I normally cut the power on downwind abeam my touch down point and they try to adjust my configuration (Flaps), glide path and airspeed to land at a specified spot on the Runway without having to add power again. But I use a different techniques for Short and Soft Field landings. Brian CFIIG/ASEL ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= East/West-Coast Server Farms - Total Privacy via Encryption =--- |
It entirely depends on what you're trying to do with each landing. Standard
landing, wind no factor, I cut power on downwind and glide all the way in. Strong headwind on landing, I'll carry a little power to extend the glide. If I want to stay high for some reason, I'll cut power later in the pattern. There have been times in the Taylorcraft when I've not cut power until on final, still at 1000 feet, and managed to put her down on the numbers. So, really, the question as it stands doesn't have much meaning beccause there are so many variables. Shawn "John Doe" wrote in message ... I guess my question is simply put this way, do you cut power immediately before touching down? If not, when? I suppose a carrier landing would be an extreme. Only curious. Thank you. |
On Thu, 20 Jan 2005 16:46:00 GMT, "ShawnD2112"
wrote: Standard landing, wind no factor, I cut power on downwind and glide all the way in. Me too. Carb heat goes on as soon as I enter the downwind, and the power comes off when I am abreast my landing spot. I advance the throttle at least once on each leg for a couple seconds. If I need power on final, I add it and give myself a D for that landing. If I glide right in, I give myself a C. If I have to slip, it's a B. An A is awarded only for a perfect wheelie. In any event, it's a glide from abreast the landing spot. Never tried it on a carrier ![]() -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
![]() John Doe wrote: I guess my question is simply put this way, do you cut power immediately before touching down? If not, when? Depends on the type of landing. If I'm trying to make a soft landing, I will carry power until after I'm solidly down. I'll do the same for landings in strong crosswinds. If I'm trying for a short field landing, I'll cut the power several hundred feet up, increase power at about 20' AGL, and cut it again just before touchdown. George Patterson The desire for safety stands against every great and noble enterprise. |
Gliding, Vintage Book 1932 Motorless Flight FA | Sarah Mc. | Aviation Marketplace | 0 | November 5th 04 11:40 PM |
Gliding Vintage Book 1932 Motorless Flight FA | Sarah Mc. | General Aviation | 0 | November 5th 04 01:09 AM |
Vietnam War chopper to touch down in Livermore | Otis Willie | Military Aviation | 0 | February 18th 04 11:49 PM |
Looking to get in touch with a "Thud Driver" | Jarrod Cunningham | Military Aviation | 0 | September 6th 03 05:59 AM |
I am looking to get in touch with cessna 340 owners | endre | Owning | 0 | July 28th 03 02:03 PM |
