This must be an obscure area because googling it didn't bring up anything in
usenet. Be that as it may the O-300 we are presently doing a top on has more than .110" dry valve clearance under the rocker toe on several of the valves. That reading is the clearance between the rocker arm toe and the top of the valve stem when the hydraulic lifter has been completely collapsed. However, the hydraulic units are Superior's, and so are the cylinders. So I'm wondering if we are going to have to go to longer pushrods, since the Continental Overhaul Manual calls for limits of .030" to .110" dry valve clearance. Anybody here got any ideas? What I'm hoping (probably in futility) is that the limits are greater with Superior hydraulic units. If not we'll have to go to the next oversize set of pushrods and our budget is already busted all to hell. TIA and bless you. |
" jls" wrote: This must be an obscure area because googling it didn't bring up anything in usenet. Be that as it may the O-300 we are presently doing a top on has more than .110" dry valve clearance under the rocker toe on several of the valves. That reading is the clearance between the rocker arm toe and the top of the valve stem when the hydraulic lifter has been completely collapsed. However, the hydraulic units are Superior's, and so are the cylinders. So I'm wondering if we are going to have to go to longer pushrods, since the Continental Overhaul Manual calls for limits of .030" to .110" dry valve clearance. Anybody here got any ideas? What I'm hoping (probably in futility) is that the limits are greater with Superior hydraulic units. If not we'll have to go to the next oversize set of pushrods and our budget is already busted all to hell. TIA and bless you. Nope -- the dry valve limits affect valve opening and wear. It sounds as if you need longer pushrods. |
If you have access to a lathe, the pushrods can be made. I made a few on
my E225. One thing to remember is that the rocker arms typically are not 50/50, so getting a 0.020 longer pushrod does not change the clearance by 0.020, it may be more. If you measure all the clearances, quite often you can mix and match to get in spec with all pushrods. Dave Orval Fairbairn wrote: In article , " jls" wrote: This must be an obscure area because googling it didn't bring up anything in usenet. Be that as it may the O-300 we are presently doing a top on has more than .110" dry valve clearance under the rocker toe on several of the valves. That reading is the clearance between the rocker arm toe and the top of the valve stem when the hydraulic lifter has been completely collapsed. However, the hydraulic units are Superior's, and so are the cylinders. So I'm wondering if we are going to have to go to longer pushrods, since the Continental Overhaul Manual calls for limits of .030" to .110" dry valve clearance. Anybody here got any ideas? What I'm hoping (probably in futility) is that the limits are greater with Superior hydraulic units. If not we'll have to go to the next oversize set of pushrods and our budget is already busted all to hell. TIA and bless you. Nope -- the dry valve limits affect valve opening and wear. It sounds as if you need longer pushrods. |
![]() "dave" wrote in message news:BhJbc.67700$K91.157113@attbi_s02... If you have access to a lathe, the pushrods can be made. I made a few on my E225. One thing to remember is that the rocker arms typically are not 50/50, so getting a 0.020 longer pushrod does not change the clearance by 0.020, it may be more. If you measure all the clearances, quite often you can mix and match to get in spec with all pushrods. Dave I think you're right, Dave and thanks. There's .080" to play with because the dry valve lash limits are not less than .030" nor more than .110". I'll measure each arm of the rocker from the fulcrum and see what kind of ratio we get there and play around with the lash a little. There are just four which are out of limits, i. e., more than .110". And the next size pushrod is .030" overlength. Four of those should do it. Orval Fairbairn wrote: In article , " jls" wrote: This must be an obscure area because googling it didn't bring up anything in usenet. Be that as it may the O-300 we are presently doing a top on has more than .110" dry valve clearance under the rocker toe on several of the valves. That reading is the clearance between the rocker arm toe and the top of the valve stem when the hydraulic lifter has been completely collapsed. However, the hydraulic units are Superior's, and so are the cylinders. So I'm wondering if we are going to have to go to longer pushrods, since the Continental Overhaul Manual calls for limits of .030" to .110" dry valve clearance. Anybody here got any ideas? What I'm hoping (probably in futility) is that the limits are greater with Superior hydraulic units. If not we'll have to go to the next oversize set of pushrods and our budget is already busted all to hell. TIA and bless you. Nope -- the dry valve limits affect valve opening and wear. It sounds as if you need longer pushrods. |
is already busted all to hell. TIA and bless you. They aren't all that expensive. Try Fresno Airparts. Cheers: Paul NC2273H |
![]() "Paul Anton" wrote in message ... not we'll have to go to the next oversize set of pushrods and our budget is already busted all to hell. TIA and bless you. They aren't all that expensive. Try Fresno Airparts. Cheers: Paul NC2273H Thanks, Paul, and you're right. Fresno has them for $22.50 as opposed to $85 apiece from another source. |
" jls" wrote: "Paul Anton" wrote in message ... not we'll have to go to the next oversize set of pushrods and our budget is already busted all to hell. TIA and bless you. They aren't all that expensive. Try Fresno Airparts. Cheers: Paul NC2273H Thanks, Paul, and you're right. Fresno has them for $22.50 as opposed to $85 apiece from another source. Have you tried El Reno Aviation? I believe that the O-290 uses the same pushrods as the O-435. Both engines use the same pistons, cylinders, rods, valve train. |
Q: Disecting a cut-off valve? | Michael Horowitz | Home Built | 0 | March 6th 04 01:47 PM |
OK, all you limeys: 4 beautiful chromium-plated valve covers for Continental O-200 | jls | Home Built | 5 | February 10th 04 05:36 PM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 07:48 AM |
Fuel Selector Valve | Jay | Home Built | 5 | November 15th 03 11:16 PM |
