(Greenwavepilot, the OP, just posted this over on rec.aviation.student)
You are missing something. I typed the wrong temperature. The overnight low was 30*F, not 40. So, it WAS below freezing for a period of time. So one mystery is solved. Now about those black wings at night... Montblack |
Thanks for bringing this over Montblack. I really wish I would have
caught my typo because I think it pulled away from my main point/question, which is, "What is the difference in thermal conductivity (as it relates to ice/icing conditions) between a composite wing and an aluminum wing." Obviously, at certain extreme temperatures and conditions (NH in January), both an aluminum and composite wing may act similarly, or in other words, the therrmal conductivity/icing differences may not be distinguishable. But in marginal temperatures and conditions, (like SC in February), those differences MAY be quite distinguishable, as the experience I posted, and may be a point of concern for composite drivers. Or I may be completely bonkers. But the only logical explanation I could reason/infer from my experience was that the thermal conductivity differences between aluminum and fiberglass were to blame. This probably breaches usenet protocol, but I shall reprint my original post from r.a.student that Montblack refers to below, with the temperature typo corrected. "I am training in a Diamond DA-20 C1, incidentally, the only composite airplane on my flight schools ramp. I am flying in upstate SC. This morning, at 8:15 the top surfaces of the wings on the C1 were iced significantly, as was the nose and fuselage (tail boom). Outside air temp was 41*F/Overnight low was 30*F. Plane is tied-down, morning sun was directly on wing surfaces, no intervening shadows. My lesson was delayed, of course. Curious, I checked the other planes on the ramp-all of which are aluminum. NONE had icing on any surface. Through a very unscientific "hand touch" test I determined the composite surfaces "felt" much colder than the aluminum surfaces. I would be very interested in learning more about the heat/cold transfer dynamics of aluminum versus composites. Pure speculatin' though, I would bet from my limited experience that the composite will ice faster or retain ice longer than similarly exposed aluminum. But, there's always someone who knows more about it than me-so maybe they will chime in. So, I did some research and found the following thermal conductivity values (Note these figures are for a standard temperature of 25*C): Aluminum, Pure=237 watts/meter*Kelvin Fiberglass, Paper Faced=.046 watts/meter*Kelvin So, what I should have inferred from my non-aviation experience with these materials is confirmed by the above thermal conductivity values. That is, aluminum is a good heat conductor-it can either gain or lose heat very quickly. Fiberglass on the other hand is a good insulator. It does not lose or gain heat very rapidly. Thus once "set" at a temperature, it will tend to remain there longer than aluminum. Therefore versus fiberglass the aluminum surfaces will cool to icing temperatures faster, and conversely will heat to non-icing temperatures faster. The composite will cool more slowly, but once cooled, will retain that temperature much longer, meaning like I discovered this morning, my composite plane will/may be iced when the Cessnas, Pipers and Mooneys won't. During the preflight "Hand Checking Of All Surfaces" has added meaning for a composite driver (especially one like me who has scheduled 8am lessons so that I can at least pretend there is a usable workday left ![]() WPR Student Pilot" |
On 11 Feb 2005 13:50:34 -0800, "greenwavepilot"
wrote in . com:: Therefore versus fiberglass the aluminum surfaces will cool to icing temperatures faster, and conversely will heat to non-icing temperatures faster. Yes, exactly. The composite will cool more slowly, but once cooled, will retain that temperature much longer, meaning like I discovered this morning, my composite plane will/may be iced when the Cessnas, Pipers and Mooneys won't. Consider also, the mass of composite v aluminum necessary to achieve the same strength. I'd guess the composite skin thickness exceeds that of the aluminum skin. |
The composite materials are used as insulation in certain cases. Think
of fiberglass. Next, look at the paint used for the a/c in question. The composites are painted below the surface while the metal a/c have painted surfaces. Now, given the insulative qualities of the composites, and the surface area with which to "absorb" energy (heat), the aluminum a/c will shed ice much faster when placed in a heated hanger than will a composite. Now if you place a fan in that heated hanger, the composite will de-ice at a faster rate. OTOH - at altitude and with air speed, I do not know if the composite will ice faster than the aluminum, because the aluminum is not (well, I wouldn't think it) as smooth as the composite. So water has something to adhere to which will start the process (talking about rime). Because of the smoothness of the wing, I don't know, and have no experience with clear ice and its ability to stick to the wing. But because my step-son is close to test flying his Vari-eze (I think that is the one he is building), we may be able to find out by this time next year. So you other composite drivers, how about practical experience? Later, Steve.T PP ASEL/Instrument |
![]() "Steve.T" wrote: The composite materials are used as insulation in certain cases. Think of fiberglass. Fiberglass, in and of itself, is not a particularly good insulator. When it's spun into a sort of glass wool and traps a lot of small air bubbles, that changes. The air *is* a good insulator. George Patterson He who would distinguish what is true from what is false must have an adequate understanding of truth and falsehood. |
![]() "George Patterson" wrote in message ... "Steve.T" wrote: The composite materials are used as insulation in certain cases. Think of fiberglass. Fiberglass, in and of itself, is not a particularly good insulator. When it's spun into a sort of glass wool and traps a lot of small air bubbles, that changes. The air *is* a good insulator. Depends on how you look at it. In the long-wavelength infrared spectra the atmosphere is virtually transparent. In that regard, air is an excellent conductor since it poses no resistance to thermal radiation. And it is the radiation that accounts for the type of heat loss involved in these discussions, not conduction. So it is the thermal emissivity of the wing surface that really matters -- not the molecular conductivity. |
On Sat, 12 Feb 2005 05:18:37 GMT, "Casey Wilson" N2310D @ gmail.com
wrote in NkgPd.2805$uc.202@trnddc01:: So it is the thermal emissivity of the wing surface that really matters -- not the molecular conductivity. If the molecular conductivity is unimportant, once the surface changes temperature, how does the rest of the material change temperature without conduction? |
![]() "Larry Dighera" wrote in message ... On Sat, 12 Feb 2005 05:18:37 GMT, "Casey Wilson" N2310D @ gmail.com wrote in NkgPd.2805$uc.202@trnddc01:: So it is the thermal emissivity of the wing surface that really matters -- not the molecular conductivity. If the molecular conductivity is unimportant, once the surface changes temperature, how does the rest of the material change temperature without conduction? Go back and read it in context. I didn't say there was no conduction. What I said was (in different words) that conduction is not the process of the wing surface losing thermal energy. Here, I'll put it in another term so you can do some more nit picking: Because the atomosphere is transparent in certain important wavelengths, the heat of the wing is being sucked into outer space. |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Naval Aviation | 0 | April 29th 04 08:09 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | General Aviation | 0 | April 29th 04 08:09 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Military Aviation | 0 | April 29th 04 06:45 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Home Built | 0 | April 29th 04 06:43 PM |
FA: Raytheon Thermal Imaging Camera - Very Nice! | Michael J. | Military Aviation | 0 | April 21st 04 11:23 PM |
