$450 buff and wax at region two (mifflin)
Old May 12th 14, 08:30 PM posted to rec.aviation.soaring
Andrew Brayer
Default $450 buff and wax at region two (mifflin)
During the region two contest in Mifflin next week I advertising a buff and wax job to professional standards during a rain day, rest day, or over the course of a few evenings. I am skilled and knowledgeable in sailplane maintenance. If you are interested, please contact me in either a private message or email me directly at brayera (at) gmail.com
Thank you!
-ND
Old May 12th 14, 08:47 PM posted to rec.aviation.soaring
son_of_flubber
Having attempted this myself, I'm sure that this is a good value at $450, but being out of your area and thinking about doing this myself again this year, I'm wondering how much time a professional would allocate to buffing and waxing a painted glass glider (no gel coat damage)? I just waxed the wings last summer by hand and I got discouraged because it took me so long. If I knew how long it would take you, I might not feel so inept spending so much time (or I would feel really inept and seek professional help.)
Old May 12th 14, 09:17 PM posted to rec.aviation.soaring
Few people that don't do this regularly have the tools needed to do it in an effective amount of time. a reasonable answer to your question is that it very much depends on condition coming in. Most favorable, skilled person, correct tools, and good starting condition, could be as little as 2 hrs/wing. It goes up from there. It can go to 10 times that for a bad starting point.
It is tiring, boring, and discouraging, but the results can be nice.
UH
Old May 12th 14, 09:35 PM posted to rec.aviation.soaring
Andrew Brayer
UH
that's because you're not pumping jackson browne through your headphone hank
if you want it to go fast i recommend listening to rush.
but he's correct. It's alot more work than most people think, especially true if done right.
Old May 12th 14, 09:45 PM posted to rec.aviation.soaring
John Carlyle
Andy,
I sent a "reply to author" message to you, but apparently you didn't get it. Could you please drop me a line at jcarlyle at verizon dot net ? Thanks!
-John, Q3
Old May 12th 14, 09:49 PM posted to rec.aviation.soaring
Papa3[_2_]
I was going to respond the same way Andy :-) I find that the playlist has a direct impact on both speed and quality. Right now, I'm finding some up-tempo alt-rock can work wonders. Killers, Vampire Weekend, MGMT, and some throwbacks like Breeders, Camper Van Beethoven, and even some Ramones and Cheap Trick work great. Figure between 10 and 15 tracks per wing per side depending on starting condition.
In all seriousness... I first learned from a combination of Bruce Conrad (who worked several years at SH) and Richard Kellerman (his local disciple). Having worked in a machine shop before was a help, but it's definitely not something I'd try without first watching, then being watched, by someone who knows. A shredded trailing edge or aileron makes $450 look positively cheap.
P3
UH
Old May 12th 14, 11:08 PM posted to rec.aviation.soaring
son_of_flubber
Just so. The previous owner of my glider buffed the paint right off the trailing edge of the elevator. As far as UV protection, I'm pretty safe if I stay with new microfiber rags and elbow grease, but that will not repair the overall scratched surface that I bought. It seems rather easy to mess up. I think I will take it to a pro next winter to restore the surface... sailboat people have told me that it would not be too hard to bring back.
Old May 16th 14, 02:14 AM posted to rec.aviation.soaring
Thank you!
-ND
jeezes
Old December 21st 14, 01:57 AM posted to rec.aviation.soaring
Mark628CA
It is amazing to me how an aircraft like a typical 'glass 15 meter span glider- a "small aircraft" in every sense of the term can suddenly start looking as large as a 747 when you grab a bucket and sponge. And once you take hold of the buffer, wax and haystack of rags, it turns into an Airbus 380!
Don't forget to do the bottom!
Old December 21st 14, 01:20 PM posted to rec.aviation.soaring
HGXC[_3_]
I have sealed and waxed my glider twice in the last two years. I usually do it before i store it for the winter. It took me longer the first time but this year i guess i spent 12 hours. I have a polisher, I work slow and there are a couple small areas i do twice. My Ventus is 30 years old and has the original gelcoat and the gelcoat is in very good condition considering the age of the glider. If I had a pro locally I would pay every three years to get a expert job. What can I say...its a labor of love.
Regarding the Buff... Jess Lurkin[_4_] Aviation Photos 0 February 17th 13 08:45 PM
Mifflin Region 2 Contest SPOT map links Frank Paynter[_2_] Soaring 0 May 20th 11 02:51 AM
Region 2 - Mifflin Contest Briefing has been updated QT[_2_] Soaring 2 May 20th 09 02:39 AM
BUFF art ---- centerplace Aviation Photos 0 January 10th 08 07:06 PM
BUFF art -- centerplace Aviation Photos 0 January 10th 08 07:01 PM
