Why do gyros use tilt head rather than swashplate
Old July 21st 03, 10:21 AM
Phillip
Default Why do gyros use tilt head rather than swashplate
Would a gyro with a swashplate ( just for pitch control) fly any different
(better,worse) than using a tilt type rotor head? Just more complex?
Also, I've seen some photos of early kit helicopters that appear to have
just a tilting head (no way to auto-rotate ?). Isn't this a bit of a death
wish? Does a helicopter need to have collective pitch for anything other
than auto-rotaion?
Silly questions, but it's a late night.
Old July 22nd 03, 01:52 AM
Phillip
"Rhodesst" wrote in message
Power adjustments. Wally
Power adjustments? I don't see the difference a swashplate over a tilt
head
for cyclic control would make to a gyros rotor system. Care to explain
further?
OTOH, I think that sport gyros today use the tilt rotor hub because it's a
very
simple design, and it works very well. No swashplate and associated
linkages,
not to mention the fact that there's no need for individual feathering
hinges
on the rotor blades themselves. Much less to go wrong and/or maintain.
JMO,
Fly Safe,
Steve R.
The K.I.S.S. formula at it's best.
So why not on a helicopter? (Like those old kits I mentioned). I'm assuming
because you'd lose auto-rotation?
Old July 23rd 03, 12:07 AM
Paul Baechler
head
further?
very
linkages,
hinges
JMO,
Fly Safe,
Steve R.
The basic principle of autogyro flight is auto-rotation. What you'd lose
is a simple, practical way of controlling powered flight.
Paul Baechler
Old July 22nd 03, 02:43 AM
Phil Miller
Just more complex. The net effect would be the same. Increase the angle
of attack 90 degrees before desired disc upward movement, decrease AoA
90 degrees before. Gyroscopic precession then makes the desire movement
happen.
than auto-rotaion?
Helicopter collective increase/decreases pitch angle of all blades
collectively and thereby increases/decreases lift. Pull collective up,
go up. lower collective, go down. It's a bit more complex than that, but
I'll leave that to the experts here.
Phil
Definitions of a pilot - No. 1
The average pilot, despite the sometimes swaggering exterior,
is very much capable of such feelings as love, affection,
intimacy and caring.
These feelings just don't involve anybody else.
US Navy Times
Old July 22nd 03, 05:09 AM
Phil Miller
On Tue, 22 Jul 2003 10:43:27 +1000, Phil Miller
happen.
Woops. After.
than auto-rotaion?
Phil
Phil
"Me fail english? That's unpossible!"
Ralph Wiggum
Old July 22nd 03, 03:08 AM
Stan Gosnell
"Phillip" wrote in
appear to have just a tilting head (no way to auto-rotate
?). Isn't this a bit of a death wish? Does a helicopter
need to have collective pitch for anything other than
auto-rotaion?
Helicopters depend on collective pitch for control of power -
they have no other way to fly. Without collective pitch, you
can't get off the ground, or change power, or get back on the
ground in one piece.
Regards,
Stan
Old July 22nd 03, 04:02 AM
Guy Alcala
Stan Gosnell wrote:
"Phillip" wrote in
auto-rotaion?
IIRC, at least the first Piasecki helo and maybe the first Hiller
lacked collective pitch. Lift was controlled by the throttle
(which controlled the engine and thus rotor rpm), and they seemed
to have flown just fine. There are clearly advantages to the
collective system as later models all included it, but it's not
as if a helo has to have one to fly.
Guy
Old July 22nd 03, 04:55 AM
Phillip
"Guy Alcala" wrote in message
Stan Gosnell wrote:
"Phillip" wrote in
auto-rotaion?
Guy
I guess what I wondered was , other than a need to auto-rotate, a tilt
system would work on a helicopter the same as a gyro? Yes I know
auto-rotation is needed...I'm just wounding if the concept is the same.
That's what these kits mentioned (it's been a long time), you added power
to go up, remove power to come down...seems simple enough. Don't think I'd
like the idea of no collective control for auto-rotation.
Old August 3rd 03, 11:24 AM
Stephen Austin
The only problem with the A&S was a severe limitation on the operation at
the local field because of noise restrictions - it sure was a loud bird.
Hmm, at Farrington Airpark? I think someone was pulling your leg. I've never
heard of any noise restrictions there. It's kind of in the boondocks anyway.
And, for that matter, there is a stock car track about one hundred yards from
the strip (the strip actually began life as a drag strip until Don bought it).
Anyway all those cars are one heck of a lot louder than an 18A.
Stephen Austin
Austin Ag Aviation
Charleston, Missouri
Old August 3rd 03, 02:54 PM
Michael Pilla
"Stephen Austin" wrote in message
never
anyway.
from
it).
Stephen Austin
Austin Ag Aviation
Nope. My A&S 18A lesson was in NJ, but I forget the town. Even though the
airstrip was in the Western (less populated portion of the state - rural,
actually), the local residents were the highly paid, city-commuter types
(NYC) and, apparently both vocal and influential. The 18A clearly was
louder than the other planes (typical spam can range, plus a goodly amount
of low-powered Cubs, Champs, etc.) - it definitely stood out during ops.
Michael Pilla
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 06:07 PM
Bothersome Phillips Head Screws Larry Smith Home Built 48 January 10th 04 05:26 AM
Aviano thanks base guardians as Puerto Rican guardsmen head home Otis Willie Military Aviation 0 September 1st 03 03:24 AM
Child head set Dennis O'Connor Piloting 7 July 15th 03 02:55 PM
Citabria with gyros Bob Esser Piloting 6 July 9th 03 01:03 AM
