I'm not aware of any tip-jet helicopters that have made it into
production. Please correct me if I'm wrong. At first the idea seems a no-brainer, no torque to counter, no gearbox, should result in a lighter & thus more efficient aircraft. I suppose the devil is in the details. Is the problem with tip-jets the rotor hub? Either you have to pass fuel or hot gas through the rotor hub to the blades. I guess sealing a rotating assembly with hot gases flowing through may be a non-trivial problem? But that shouldnt be a problem for jets-at-the-tips type designs, fuel would not be hot enough to damage seals. Perhaps there is a inherant flaw in the jets-at-the-tips style design? I've seen videos of the Hughes heavy lift helicopter that directed the output of a couple of turbojets(/fans ?) through the blades. I thought that design was successful, it was more a matter of funding that it wasnt put into production, am I wrong? Jeremy Thomson |
On 23 Jul 2003 20:40:11 -0700, (Jeremy Thomson)
wrote: I'm not aware of any tip-jet helicopters that have made it into production. Please correct me if I'm wrong. Didn't go into production, but an interesting read nonetheless http://www.asra.org.au/rotordyn.htm Some other stuff I found via Google http://www.calpoly.edu/~wpatters/helo.html and http://avia.russian.ee/vertigo/hiller_crane-r.html and http://avia.russian.ee/vertigo/hiller_hj-1-r.html and http://www.germanvtol.com/wnffolder/sidewnf.html I know a guy that is building one of these http://www.rqriley.com/gluharef.html Phil -- Pfft...english! Who needs that? I'm never going to England. Homer J. Simpson |
I can't say it was successful in terms of production, but I did see it fly.
Go to: http://www.intora-firebird.com/main.htm Scooter "Jeremy Thomson" wrote in message m... I'm not aware of any tip-jet helicopters that have made it into production. Please correct me if I'm wrong. At first the idea seems a no-brainer, no torque to counter, no gearbox, should result in a lighter & thus more efficient aircraft. I suppose the devil is in the details. Is the problem with tip-jets the rotor hub? Either you have to pass fuel or hot gas through the rotor hub to the blades. I guess sealing a rotating assembly with hot gases flowing through may be a non-trivial problem? But that shouldnt be a problem for jets-at-the-tips type designs, fuel would not be hot enough to damage seals. Perhaps there is a inherant flaw in the jets-at-the-tips style design? I've seen videos of the Hughes heavy lift helicopter that directed the output of a couple of turbojets(/fans ?) through the blades. I thought that design was successful, it was more a matter of funding that it wasnt put into production, am I wrong? Jeremy Thomson |
Brantly Nuts wrote:
There have been at least 2 tip-jet type helicopters to reach type certification and production. Sud Ouest So.1221 Djinn, about 150 produced. http://avia.russian.ee/vertigo/snias_jinn-r.html Kolibri H-3, about 10 produced. http://avia.russian.ee/vertigo/nhi_kolibri-r.html It says version #1 "was written off through ground resonance". Maybe due to something like a fuel imbalance through the blades, because 2-blade rotors don't suffer from ground resonance. Do they? |
"Rocky" wrote in message om... (Jeremy Thomson) wrote in message om... I'm not aware of any tip-jet helicopters that have made it into production. Please correct me if I'm wrong. The french had one in the 60's called a Djin. I saw one flying in South Africa where they were trying to adapt it for agricultural flying in the Cape Province. It was never very popular nor successful. The Djiin was a very successful crop spraying aircraft in the UK and France. During the sixties and early seventies a group of them from the company SEPATOM (I think) started the year working their way up from the south of France spraying vines with Bordeaux mixture. Then they came to the UK and sprayed the potatoes in Lincolnshire and Lancashire with Maneb. About '72 BEAS Helicopters, Oxford, bought eight of them and used them for a good few years before they switched to Bell 47s. They were cheap to run and easy to fly but eventually shortage of spares grounded them. Starting them was great fun, if you were fit. They had a great big handle out the side to wind up the turbine! No electric start you see, in fact no electric's! Slatts |
Jeremy Thomson wrote: I'm not aware of any tip-jet helicopters that have made it into production. Please correct me if I'm wrong. Where does the Hiller YH-32 fit in then? http://www.museumofflight.org/collec...lay.html?ID=59 http://avia.russian.ee/vertigo/hiller_hoe-1-r.html rm |
Ken's right - tip jet designs seem like a great idea - no transmission,
minimal antitorque (you still have a small amount of friction torque and you have to have some form of yaw control) - but tip jet drive is incredibly inefficient. I researched these a number of years ago, as a young engineer. I remember a quote about the YH-32, to the effect that its major success was it's ability to turn fuel into noise. Dan Hollenbaugh Ken Sandyeggo wrote in message . .. I think that the general concensus is that they all proved extremely noisy and consumed an inordinate quantity of fuel, 2 factors that have limited their success and further development. Ken J. - Sandie A. Geaux |
| *White* Helicopters??!!! | Stephen Harding | Military Aviation | 13 | March 9th 04 08:03 PM |
| Taiwan to make parts for new Bell military helicopters | Otis Willie | Military Aviation | 0 | February 28th 04 01:12 AM |
| Sikorsky S-76C helicopters for sale | richlady | Military Aviation | 0 | August 21st 03 06:43 AM |
| FA: The Helicopters Are Coming | The Ink Company | Aviation Marketplace | 0 | August 10th 03 06:53 PM |
| OH-58 for Civilian use | pp | Rotorcraft | 10 | July 17th 03 08:53 PM |
