Trying to download the latest firmware for Oudie...
Naviter says DON'T use version 5.12, use 5.19. Yet the version on its download and updater links is to .... 5.12. Where did I go wrong. |
Hi Mark,
I used the Oudie Updater program on my PC to upgrade my Oudie 2 to version 5.19 just now. http://www.naviter.com/products/oudie-updater/ Best Regards, Paul Remde _____________________ wrote in message ... Trying to download the latest firmware for Oudie... Naviter says DON'T use version 5.12, use 5.19. Yet the version on its download and updater links is to .... 5.12. Where did I go wrong. |
http://www.naviter.com/install-the-l...are-for-oudie/
If you don't fancy using the updater tool click on the link - Download latest firmware for Oudie 2 which will download a file called UpdateOudie.exe copy this onto your Oudie flashdrive or SD card (doesn't matter which) and start the oudie, which will show the update process and ask if you want to continue updating from your current version to 5:19 click yes and that's it. The update process will complete and rename the .exe file to UpdateOudie.old Just updated my oudie this way today. Cheers Matt |
I updated mine to 5.19 last night using the updater program. No issues.
BillT |
At 18:25 30 May 2014, Paul Remde wrote:
I used the Oudie Updater program on my PC to upgrade my Oudie 2 to version 5.19 just now. http://www.naviter.com/products/oudie-updater/ Also worked for me this morning. |
On Monday, June 2, 2014 4:55:31 AM UTC-5, Z Goudie wrote:
At 18:25 30 May 2014, Paul Remde wrote: I used the Oudie Updater program on my PC to upgrade my Oudie 2 to version 5.19 just now. http://www.naviter.com/products/oudie-updater/ Also worked for me this morning. up to 5.20 now apparently, to fix a bug when using the keyboard to select waypoints in a task. i think i might just wait until the fall to update... |
On Monday, June 2, 2014 9:18:43 AM UTC-7, Tony wrote:
Also worked for me this morning. up to 5.20 now apparently, to fix a bug when using the keyboard to select waypoints in a task. i think i might just wait until the fall to update... Just used the updater and got 5.20.001 bumper |
On Monday, June 2, 2014 10:08:47 AM UTC-7, bumper wrote:
On Monday, June 2, 2014 9:18:43 AM UTC-7, Tony wrote: Also worked for me this morning. up to 5.20 now apparently, to fix a bug when using the keyboard to select waypoints in a task. i think i might just wait until the fall to update.... Just used the updater and got 5.20.001 bumper I ran into a problem running the updater: I got the message "Must be run as a system administrator", or some such. After searching the net to figure out how to elevate myself to a system administrator (damn you, Microsoft!), I figured out a workaround. Open the Download folder, right click ousetup.exe, and select "Run as system administrator". Tom |
You didn't go wrong mark, except to fail to understand that all gliding
software is flawed and unreliable. Whilst I could never write anything of this complexity, its also clear to me that my neighbor's teenager could. He's working in his parents' garage at all hours, and between playing his damn drums, I suspect he is actually the one writing the software I'm buying. At 14:22 30 May 2014, wrote: Trying to download the latest firmware for Oudie... Naviter says DON'T use version 5.12, use 5.19. Yet the version on its download and updater links is to .... 5.12. Where did I go wrong. |
Oudie IGC | Dave Springford | Soaring | 4 | November 12th 13 08:52 PM |
Used Original Version Oudie for Sale | Paul Remde | Soaring | 2 | May 20th 13 01:08 AM |
Used Oudie (original version) for sale | Paul Remde | Soaring | 0 | September 13th 12 08:59 PM |
Oudie and 302 | Stephen[_3_] | Soaring | 9 | November 2nd 11 05:07 AM |
