Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Rotorcraft
How do you do it ( hover )
Old August 22nd 03, 07:26 PM
ABE
Default How do you do it ( hover )
Hey
Can any one in here tale me, or rather explain to me how to hover ??
I have tried it in a R22, but it tilt / turned, every time.
First I hold only the height, then height and pedals and that was OK, but
when
I should hold the stick, the helicopter flip. I have asked around, and the
nearest I have come
To an explanation was that it is a "feeling" you get after 15 - 20 hours??
I am a holder of a PPL fixwing, I hope to fly heli. Some day
How do you do it ????? : )
Anker B.
Denmark.
Old August 22nd 03, 08:37 PM
Gig Giacona
There is NO way anyone is going to be able to explain how to hover in a
message on the Internet. What is your instructor telling you?
"ABE" hvad@saa wrote in message
k...
Hey
when
nearest I have come
Anker B.
Denmark.
Old August 22nd 03, 08:54 PM
Lab
I was also told about that "feeling". It came alltogether somewhere around
10 hours. At the begining of my training I was very stif and imputs were to
strong and unarticulated. It looked like a rodeo.
Good luck!
H.J.
Croatia
k...
Hey
when
nearest I have come
Anker B.
Denmark.
Old August 22nd 03, 11:58 PM
Murphy's law
"ABE" hvad@saa wrote in message . dk...
Hey
when
nearest I have come
Anker B.
Denmark.
You'll get the feeling after like 6hrs and you'll get the hang of it around 10 hrs.
It ain't gonna happen overnight.
Are you trying to learn to hover by yourself?
A CFI can help you to learn the trick.
After that you fly like a dragonfly.
Old August 23rd 03, 01:24 PM
Walter Hawn
Hovering's easy. First, you have to understand how the helicopter flies,
what the controls do in that process, what the helicopter you're flying is
doing at that instant, how to redirect the process with minimal control
changes-and be able to make the control adjustments while you evaluate your
situation and the changes just introduced. It's complex mentally and
physically until- it isn't- anymore.
Practice, practice, and more practice. You'll get through it.
Wally
Old August 23rd 03, 08:47 PM
Hey
You don't just hover, you interpret the dynamics of what is occurring and
once you have done that you then interpret the dynamics of what will occur
and correct for it. You need an open mind for this so forget most of your
fixed wing nature and develop new ones for the helicopter. Read and
understand the dynamics prior to and after each lesson. This will help you
to see what is happening. You should be hovering in a small zone in 5 hours
and within 10 hours you will be holding over an exact spot fairly easy.
Don't concern yourself with just hovering, as your lesson progresses while
learning airspeed control, power management, approaches etc. you will learn
it. Sorry this doesn't explane it exactly but you just can't be told what to
do and be able to do it (in this case). One thing to know is, if someone
else does it, so can you (eventually).
k...
Hey
when
nearest I have come
Anker B.
Denmark.
Old August 23rd 03, 10:07 PM
Mr. MD500
The best advice I had in learning to hover:
1. Look outside the aircraft at the horizon
2. When thinking of control inputs, think of fingertip pressure rather
than movements.
3. To quote my first instructor, "Stop stirring the damn cyclic!"
Old August 24th 03, 02:57 PM
Bart
Most ppl make way too many power changes and way too quickly. Usually
they're behind the machine when they do this too. Since the power
changes require the pilot also make anti-torque and cyclic adjustments
they quickly get into some kind of over-corrective oscillation.
One little trick I learned that seems to help people understand hovering
is to show them that if you set and hold the collective at any given
power setting at a hover and point it into the wind, the helicopter will
just stay at the assigned height +/- a couple feet without any changes
to the collective setting.
Bart
ABE wrote:
Hey
when
nearest I have come
Anker B.
Denmark.
Old August 26th 03, 06:59 PM
ABS
"ABE" hvad@saa skrev i en meddelelse
k...
Hey
Thanks for all the answers / comments
It must be the most difficult thing you can do in a helicopter (I hope)
Thanks to all.
Anker
Denmark
Old August 30th 03, 05:21 AM
Stu Fields
I think that it would be much harder if you get all the controls at one
time. Just the cyclic took me 2hrs. to get the thing to behave. The pedals
didn't add much to the problem or even the collective/ throttle. Just the
dang cyclic. I've since built a little cyclic simulator involving a disc
and a steel ball which helps people understand that they have to anticipate
the movement of the ship and make small corrections. A flight school bought
one of the little simulators for use in their school.
I once gave a neighbor a ride and he tried to hover and of course the thing
took off for an out-of-state zip code and I grabbed it and put it back and
he got on with me and he said: " You are making corrections and I can't
tell why you are doing it" I told him that my butt was telling my hand what
needed to be done. The only way that I know to train the butt is to get
actual seat time in a hovering helicopter.
Stu Fields
k...
Hey
when
nearest I have come
Anker B.
Denmark.
Have you ever seen a C-130 Hercules trying to do a hover over the runway ? Iwan Bogels Naval Aviation 31 December 31st 04 02:52 AM
Have you ever seen a C-130 Hercules trying to do a hover over the runway ? Iwan Bogels Instrument Flight Rules 6 December 18th 04 12:03 AM
Two non-aviation questions Ramapriya Piloting 12 November 10th 04 12:51 AM
STOVL and CTOL from big decks - deconflicting ? John S. Shinal Naval Aviation 15 March 8th 04 04:44 AM
