How does one land upside down following a PT3?
Old June 21st 14, 12:18 AM posted to rec.aviation.soaring
son_of_flubber
Default How does one land upside down following a PT3?
According to article: Released 100-200 feet AGL. Minor injuries to pilot.
http://www.shropshirestar.com/news/2...crash/4147432/
The photo show tail boom broken behind wings. Tail and wings and nose appear intact. Speculations on how the pilot landed like this?
Old June 21st 14, 12:30 AM posted to rec.aviation.soaring
Andy[_1_]
High energy ground loop?
Andy (GY)
Old June 21st 14, 12:51 AM posted to rec.aviation.soaring
Paul T[_4_]
pilot.
Andy (GY)
Mainly winch at the Myndd.
Wing drop at start of winch launch- glider cartwheeled? Spun off failed
launch? Turning low off failed launch - wing clipped ground - glider went
inverted? Who knows -but it time the accident report will tell us.
Old June 21st 14, 01:02 AM posted to rec.aviation.soaring
waremark
Speculation that winch launch commenced with elevator not connected.
Old June 21st 14, 01:28 PM posted to rec.aviation.soaring
GM
If the CG is within the allowable range, most gliders with a CG hook actually perform a fairly decent winch launch w/o elevator input.
We don't have any real info so everything about this accident is pure speculation.
Uli
Old June 25th 14, 11:55 PM posted to rec.aviation.soaring
Frank Whiteley
Which would perhaps lead to a steep climb, stall/spin and rotation in a near vertical attitude resulting in an inverted impact, usually fatal. Happened on auto launch in Georgia several years ago with an all-flying tail stall on a Phoebus C. Pilot hurt but survived.
Recognized hazard in winch launching whatever the cause. Like all accidents, preventable.
Frank Whiteley
Old June 21st 14, 05:58 AM
POPS POPS is offline
Member
First recorded activity by AviationBanter: Dec 2010
It's super simple ... you land on your roof .... geez
Old June 22nd 14, 02:59 AM posted to rec.aviation.soaring
son_of_flubber
But how do one land inverted without breaking wings, nose, or tail AND walk away?
I'm more interested in well-dissected historical cases where this has happened, than in this particular undocumented accident.
Old June 24th 14, 04:48 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
This is a serious question then?
It's not possible to "land" (i.e. in a controlled fashion) a glider inverted. Wing incidence, camber and dihedral are all against you. If you were to try this, the glider would touch down on the tail with the nose pitched rather high and the fuselage would drop hard on the cockpit, still with significant forward speed. It's a call-911 event. And there probably won't be any need to hurry.
When someone crawls out of a wreck that stops inverted, it's because the glider flopped on its back at the end of some sort of tumble and it happened to do so in a relatively gentle fashion. It's not a high percentage play.
T8
Old June 25th 14, 02:29 AM posted to rec.aviation.soaring
son_of_flubber
On Tuesday, June 24, 2014 10:48:14 AM UTC-4, Evan Ludeman wrote:
If you were to try this (ed. landing inverted), the glider would touch down on the tail with the nose pitched rather high and the fuselage would drop hard on the cockpit, still with significant forward speed.
Then maybe the fuselage would break behind the wings, thus dissipating a great deal of energy and the pieces would come to rest relatively intact like in the photo of the Long Mynd landing. I conclude that 'flying the glider' until it stops is the better option even if the glider is inverted.
When someone crawls out of a wreck that stops inverted, it's because the glider flopped on its back at the end of some sort of tumble and it happened to do so in a relatively gentle fashion....
Tumbling a glider in 'a relatively gentle fashion' is a possibility??
Related: Does anyone know of a case where a glider was flipped inverted on turn to final in rotor-in-pattern conditions? I'm curious because I got thrashed severely on turn to final a few weeks ago.
Do Australians eat 'Upside down cake'? Michael Baldwin, Bruce[_2_] Products 19 November 9th 07 07:50 PM
USAir 'S' Upside Down Digital Voices Aviation Photos 9 April 3rd 07 09:15 AM
IL2 Forgotten Battles Displays upside down LeonardR Simulators 15 June 4th 05 09:55 PM
How to fly upside down and on time NewsBOT Simulators 2 April 5th 05 02:48 PM
Upside down flag Mike Keown Naval Aviation 12 August 19th 03 01:01 AM
