Diesel engine
Old April 25th 04, 06:28 PM
Bryan
Default Diesel engine
Has anyone been able to find the weight on the VW V10 diesel engine? This
engine produces 550 lb/ft of torque at 2000 rpm and 310 hp at 3750 rpm.
Sounds like a great candidate for aircraft to me.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.663 / Virus Database: 426 - Release Date: 4/20/2004
Old April 25th 04, 06:39 PM
Pete Schaefer
What's the continuous rated power? Peak power numbers are meaningless for
aircraft.
"Bryan" wrote in message
Old April 25th 04, 07:05 PM
Bryan
I have need been able to find any real specs on this engine except that it
has an aluminum black with steel reinforcement and sleeves. Should be light
for the available power. Might be able to go without gear reduction just
using a prop shaft with thrust bearings coupled directly to the crank or
flywheel.
"Pete Schaefer" wrote in message
news:8JSic.32612$IW1.1418846@attbi_s52...
aircraft.
This
Old April 25th 04, 07:16 PM
Pete Schaefer
Sure, but you might find that it can only handle 50% continuous power (or
less), which would put it way behind what, say, a DeltaHawk can do. Unless
you have a ton of money, time, and aircraft engine development
experience................
light
flywheel.
Old April 25th 04, 07:25 PM
Bryan
Good points! I have no idea how to find out what the continuous rated power
would be on this engine. I would love to have a DeltaHawk engine but as you
put it, I do not have a ton of money. I was leaning heavily toward the
Mazda rotary, looks like the way to as there are many flying already and
components are available.
Thanks
news:ngTic.32866$IW1.1433613@attbi_s52...
Unless
it
light
just
flywheel.
Old April 26th 04, 12:25 AM
Pete Schaefer
I'm curious as to what kind of airframe you're considering putting something
like this in? Something fast, I'd assume. Also, something non-aerobatic.
Some kind of fast cruiser?
You might want to contact some people at VW to see if you can get some
detailed info on the engine. It could very well turn out that it would make
a great airplane engine, but there are a ton of unknowns at this point. How
would you go about examining the suitability of the engine for aviation use?
You're looking at a very non-trivial problem. Better know how to speak some
German, too.
I've watched the Mazda B13 thing closely over the last couple of years.
There are some interesting possibilities there, but none of the good options
look very cheap. You'll still spend a lot of time wringing the engine out
on the ground before you can gain enough confidence that you've done all
your homework. Granted, doing a homebuilt, you'll spend a bunch of your
time doing engine integration no matter what. Just gotta make sure to have
a sound approach to engine risk-reduction if you're going a non-standard
route. That means knowing the risks and being able to plan for them.
BTW: This summer, I'm starting work on an RV-8A. I'm tentatively penciling
in a DeltaHawk 180HP inverted V-4. I'm encouraged by their progress over
the last year. However, I won't hesitate to change my plans if some big
gotchas emerge with their design. Their first production run starts soon.
I figure they get to have two more years of maturity on the design before I
order mine. It's gonna cost a bunch, but I feel there is a resonably
controllable risk factor going with an engine that new.
power
you
Old April 26th 04, 05:13 PM
Jay
Hi Pete,
What factors dictate the difference between max and continuous rated
power? The main one I can think of is the ability to remove waste
heat. And of course a diesel produces less waste heat per unit HP
than a spark ignition engine.
Regards
"Pete Schaefer" wrote in message news:8JSic.32612$IW1.1418846@attbi_s52...
aircraft.
Old April 26th 04, 11:20 PM
L.D.
Jay wrote:
Hi Pete,
Regards
aircraft.
I always thought the difference between max and continuous rated hp was
its ability to not self destruct at a low or reasonable TT. Lots of
factors come to play here. Example, an engine that is rough at higher
rmp would, from lack of better words, shake it's self apart. You know
the faster it turns the more centrifical force. The harder it rubs the
faster it will ware. Of course heat is a factor also, the faster it
turns, the more fuel you putting through there, the hotter it gets. It
also gets hotter from rubbing harder. If you turn the engine from an
external power source, it will build up heat and the faster you turn it
the hotter and that is with no internal combustion. Now I know that heat
wouldn't ruin an engine, but it adds.
Old April 27th 04, 03:40 AM
Pete Schaefer
Heat is usually the big one. How you get rid of it is critical, of course.
Dave Driskoll (DH) can probably tell us all more about this. One of the
things that is really cool about the DeltaHawk engines is that they are
designed to be run continuously at max (pretty sure about this.....Dave, are
you there?). That's a lot of full-time horses.
"Jay" wrote in message
om...
Hi Pete,
Old April 27th 04, 04:26 AM
Richard Lamb
That't what it takes for aircraft ops.
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 04:46 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
