I am in need of a Winter 57mm ASI (0 - 160 kts.)Not enough room in the panel so have to take out the 80mm.
Hi,
I have new Winter 7423 airspeed indictors in stock. You can see details and order he http://www.cumulus-soaring.com/winter.htm#W-7423 Best Regards, Paul Remde Cumulus Soaring, Inc. _____________________________________ wrote in message ... I am in need of a Winter 57mm ASI (0 - 160 kts.)Not enough room in the panel so have to take out the 80mm. |
On Monday, July 21, 2014 7:23:30 PM UTC-7, Chris Aniol wrote:
I am in need of a Winter 57mm ASI (0 - 160 kts.)Not enough room in the panel so have to take out the 80mm. I should have said " used " |
Spring Cleaning Early: Dell Streak 5 pkg, Winter Vario 57mm, more | Evan Ludeman[_4_] | Soaring | 2 | December 31st 12 12:14 AM |
Winter 57mm Altimeter | Ventus2NZ | Soaring | 9 | November 21st 11 10:49 PM |
Winter 57mm Altimeter for sale | Juanman | Soaring | 0 | May 13th 10 08:06 PM |
Wanted: 57mm B40 | John C | Soaring | 0 | May 8th 10 02:24 AM |
Need A 57mm Borgelt B40 | [email protected] | Soaring | 2 | March 14th 05 03:22 AM |
