Mounting camera on wing of glider
Old August 27th 14, 05:09 AM posted to rec.aviation.soaring
Sierra Whiskey
Default Mounting camera on wing of glider
http://www.youtube.com/watch?v=PQqq_SDCwnA&sns=em
GoPro, Suction Mount, lots of Tape. Worked Great at high speeds and through the rain.
Old August 27th 14, 08:11 PM posted to rec.aviation.soaring
I second the vote for tape.
For a suction cup mount to work you have to use a really good one that still "sucks" at the maximum altitude you ultimately reach. Judicious use of gaffers tape helps just in case you guess wrong, but with an unsprung suction cup the mount can get wobbly. you can also make a small metal plate with a felt on the bottom and a 1/4-20 bolt sticking out the top for a standard camera screw mount (or affix a GoPro mount if that's what you are using). You can tape this down to practically any reasonably flat surface.
Old August 28th 14, 12:33 AM posted to rec.aviation.soaring
Get a GoPro Hero 3. Great suction cup mounts. Remote control for video or stills using your cell phone or their remote button.
Old September 9th 14, 05:14 AM posted to rec.aviation.soaring
David Kinsell[_2_]
I'd never trust a suction cup by itself. Might work 19 times out of 20,
then you're out a GoPro.
Adhesive mounts for GoPro generally use 3M VHB (very high bond) tape,
intended to be permanent, but can be removed cleanly with difficulty
using heat. See "Parowan Motorglider" on youtube. Next time I think
I'll go with the gaffer's tape over suction cup mount.
Old August 28th 14, 04:38 AM posted to rec.aviation.soaring
Sean Fidler
+1.
I also use the GoPro suction cup and duct tape. This method has not failed me yet. I used to simply not bother with tape and had no problems for roughly 2 years (dozens of flights). Then, I had an unfortunate event where the suction cut let go after a bump on the runway. Fortunately the GoPro was completely fine. Fortunately the GoPro did not fall onto anyone from altitude. After that, I realized that the suction cup alone was irresponsible.. From that point forward I always use plenty of white duct tape in a square pattern making sure do it very tightly with no gaps. Seal tape (or electrical tape) is probably not strong enough nor would it survive rain. The tape needs to be as strong as possible. Duct tape and Gorilla tape seems best and I have never had any issues with it damaging the wing surface (gelcoat or poly).
The duct taped mount method is so strong in fact that I suspect it would survive a decent size bird strike. It is extremely secure. Just make sure that the surface you are taping the mount to is clean and that you are (important) NOT trying to suction onto to an area of the wing (or tail or especially fuselage) that has a lot of curvature. I try to use the flattest possible part of the airfoil, usually 65-85% aft of the leading edge.
Happy filming!
Sean
Old August 28th 14, 07:21 AM posted to rec.aviation.soaring
I'd still recommend Gaffer tape over duct tape. It's not expensive and comes in white. Gaffer tape is a tough, cotton cloth pressure-sensitive tape with strong adhesive properties. It is used in theater, film and television productions as well as any kind of stage work. While related to duct tape, it differs in that it can be removed cleanly because it uses a synthetic petroleum-based adhesive rather than a natural rubber adhesive.
Old August 28th 14, 04:24 PM posted to rec.aviation.soaring
WAVEGURU
Where can we find "gaffer tape"?
Boggs
Old August 28th 14, 04:38 PM posted to rec.aviation.soaring
Vaughn
You find it where you find everything else, Amazon.
http://www.amazon.com/JVCC-GAFF30YD-...s=gaffers+tape
Old August 29th 14, 05:52 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Vaughn wrote, On 8/28/2014 7:38 AM:
The info for the referenced tape uses natural rubber adhesive, but it
also says it " Will not leave adhesive residue behind when removed"
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old August 28th 14, 06:29 PM posted to rec.aviation.soaring
JS
A good place to get gaffer tape or AA/AAA/9V batteries is TMB.
http://www.tmb.com/
If your order doesn't fill the box, they use white socks for filler. Always a hit.
Gaffer tape is to duct tape what Bowlus tape is to cheap electrical tape.
Far superior, but more expensive.
Boggs
Mounting camera on wing of glider [email protected] Soaring 2 August 27th 14 03:05 AM
Use of 'Back up' camera with glider trailer son_of_flubber Soaring 7 January 7th 13 02:44 PM
PowerFlarm mounting question, and an idea for mounting devices brianDG303[_2_] Soaring 2 October 23rd 11 07:51 PM
Very Nice Camera for Glider...Stills or HD Video [email protected] Soaring 17 June 16th 09 11:28 PM
What camera for pictures from a glider cockpit? Eric Greenwell Soaring 34 December 10th 05 07:19 AM
