Help using tablet to transfer files to OLC
Old September 2nd 14, 04:40 PM posted to rec.aviation.soaring
Default Help using tablet to transfer files to OLC
I have just acquired a Toshiba tablet and was hoping to use it as means to transfer log files to OLC. Seems that there is a problem between the files I now successfully put on a flash drive and use my laptop to send to OLC; something to do with the tablet working on a different format.
Bearing in mind that I am digitally challenged, has anyone sorted this out? So please in plain language. And thanks!
Howard
Old September 3rd 14, 12:55 AM posted to rec.aviation.soaring
Jim:
Many thanks! I will try this tomorrow, when hope to fly. Will report back on the grounds that if a computer illiterate like me can make it work anybody can.
Howard
Howard
Old September 8th 14, 01:14 PM posted to rec.aviation.soaring
Naviter Info
Not sure how many are aware of the possibility that we created together with OLC:
1. Copy your file to your Android phone or tablet any way you can (Howare already can do it apparently)
2. Run SeeYou on your tablet (it's available through Google Play and complimentary if you already have an active SeeYou subscription)
3. Open the flight in SeeYou on your tablet/phone.
4. Press the Menu button then choose "Upload to..", OLC will be one of the choices.
5. Enter your OLC username and press "Share".
OLC then mandates another step in the process which however is quite easy to complete even on a small smartphone.
This works great, I use it all the time.
Cheers,
Andrej Kolar
glider pilots use
http://www.naviter.com/
Howard
Old September 8th 14, 03:52 PM posted to rec.aviation.soaring
Dan Marotta
Having neither wifi in my hangar nor a data plan on my Android phone, I
copy my igc file from my 302 to my phone via XCSoar and Bluetooth (K6
BT) and then move it to my Dropbox. When I come in range of a wifi the
file is placed in the cloud and, when I start my laptop at home, the
file is automatically downloaded to the laptop. I then go to the OLC
website and upload.
There are so many ways...
Dan Marotta
Cheers,
Andrej Kolar
glider pilots use
Howard
GPS, Wx for Tablet PC Wiz Piloting 4 May 24th 07 06:11 PM
Using a tablet PC when airborne? Victor J. Osborne, Jr. General Aviation 4 December 16th 04 10:49 PM
Transfer of IGC files from LX5000 to pocketPC Marc Teugels Soaring 1 January 16th 04 02:56 PM
Homebrew EFB from Tablet PC Leland Vandervort Owning 7 August 10th 03 07:28 PM
Homebrew EFB from Tablet PC blanche cohen Piloting 0 August 9th 03 06:00 AM
