Socata 235E with O-540 b4b5 problem
Old September 18th 14, 08:54 AM posted to rec.aviation.soaring
Alexey Sharadkin
Default Socata 235E with O-540 b4b5 problem
Hello
new user of O-540 here.
O-540 engine, 25 hours after OH
New spark plugs. oil - 20w50.
Fuel - 92
The problem in the following:
The temperature on the ground about 20C, cylinder temp on tow 205 C, all towing in max mode.
Towing to the release - ok.
While descending cylinder temperature drops to 130-140 C degrees.
Landing, move throttle to 2000 rpm to fire the spark plugs, all is ok.
At take-off after about 20 seconds of max.rpm start very loud claps.
Also goes vibration - unwind the screws that secure the hood.
They disappear after 30-40 seconds of towing, when the temperature of the cylinder goes up to 200 degrees.
Through trial and error found a way - after landing I change mixture to LOW to raise the exhaust temperature to the maximum, heated cylinders
to 180-190, then claps less and they will disappear faster.
But this takes time, and am not sure that this is good for the rapid heating of the engine.
Can you recommend something?
Some other considerations?
Old September 18th 14, 01:16 PM posted to rec.aviation.soaring
Chris Rollings[_2_]
What airspeed and power setting are you using for the descent?
At 07:54 18 September 2014, Alexey Sharadkin wrote:
Hello
Fuel - 92
towing in max mode.
LOW
Old September 18th 14, 02:18 PM posted to rec.aviation.soaring
Alexey Sharadkin
2000 rpm, 180 km\h
Old September 18th 14, 02:31 PM posted to rec.aviation.soaring
Dan Daly[_2_]
2000 rpm, 180 km\h
http://www.helium-group.com/wp-conte...POH-Tables.pdf says minimum fuel grade is 100/130. Discussion at http://www.pprune.org/private-flying...540-mogas.html suggests detonation and per-ignition problems with 92. Have you tried it with 100LL and compared how it runs?
Old September 20th 14, 07:31 AM posted to rec.aviation.soaring
Alexey Sharadkin
For O540 B4B5 minimum fuel grade 80\87.
Old September 20th 14, 09:37 AM posted to rec.aviation.soaring
James Thomson[_2_]
content/uploads/2010/04/Lycoming-POH-Tables.=
http://www.pprune.or=
g/private-flying/419030-lycoming-io540-mogas.html suggests
detonation and
p=
compared
how=
it runs?
I suspect your problem may be the fuel. What is the specification of
your fuel? Lycoming Service Instruction SI1070S does not approve
any 92 grade aviation fuel. They approve automotive fuels with an AKI
(average of MM and RM octane ratings) at least 93 for the 0-540-B.
Check the SI for more advice.
Old September 21st 14, 12:10 PM posted to rec.aviation.soaring
On Thursday, September 18, 2014 3:54:36 AM UTC-4, Alexey Sharadkin wrote:
Hello
Fuel - 92
Higher density altitudes in the summer - the higher the density altitude, the lower the octane required to suppress detonation (that's why Colorado has 85 octane as regular, lower is 87...). You were probably on the edge.
Again, have you tried 100LL to see if that cures the problem?
Old September 22nd 14, 12:24 PM posted to rec.aviation.soaring
Alexey Sharadkin
Not yet... ****ty weather.
Will try for sure, just dont fully understand the idea...
But - will try
Socata Rallye 235C - towing operation experiences Artur Rutkowski Soaring 11 August 1st 14 01:14 PM
Socata TBM-700 Glenn[_2_] Aviation Photos 0 August 19th 07 08:07 AM
Socata Trinidad Glenn[_2_] Aviation Photos 0 August 7th 07 10:19 AM
FS: '84 Socata Trinidad T. Wood Aviation Marketplace 0 July 9th 04 02:30 PM
1984 Socata TB20 Trinidad T. Wood Aviation Marketplace 0 April 26th 04 08:38 PM
