Hughes 369D/500D
How do you tell the difference between Hughes 369D and 500D from the
outside? Does any one know if that Hughes (TC's) helicopter appeared in Magnum P.I.'s TV shows a 369D or a 500D? -- kent |
There's no difference. 369 was the manufacturer's model series and on the
type certificate. "500" was the marketing name. "Kent Shih" wrote in message ... How do you tell the difference between Hughes 369D and 500D from the outside? Does any one know if that Hughes (TC's) helicopter appeared in Magnum P.I.'s TV shows a 369D or a 500D? -- kent |
I believe the original 500 was a C model and had 4 main rotor blades and
a C18 Allison engine. The D model has 5 blades and a C20 Allison. They are both type 369 helicopters. I believe Magnum used a D model. Gary Jim Burt wrote: There's no difference. 369 was the manufacturer's model series and on the type certificate. "500" was the marketing name. "Kent Shih" wrote in message ... How do you tell the difference between Hughes 369D and 500D from the outside? Does any one know if that Hughes (TC's) helicopter appeared in Magnum P.I.'s TV shows a 369D or a 500D? -- kent |
Does the C model have the V shape tail rather than the T shape tail?
kent In message LFb6c.8297$Bg.409@fed1read03, Gary Knutson wrote: I believe the original 500 was a C model and had 4 main rotor blades and a C18 Allison engine. The D model has 5 blades and a C20 Allison. They are both type 369 helicopters. I believe Magnum used a D model. Gary Jim Burt wrote: There's no difference. 369 was the manufacturer's model series and on the type certificate. "500" was the marketing name. "Kent Shih" wrote in message ... How do you tell the difference between Hughes 369D and 500D from the outside? Does any one know if that Hughes (TC's) helicopter appeared in Magnum P.I.'s TV shows a 369D or a 500D? -- kent -- kent s |
Yes.
"kent s" wrote in message ... Does the C model have the V shape tail rather than the T shape tail? kent In message LFb6c.8297$Bg.409@fed1read03, Gary Knutson wrote: I believe the original 500 was a C model and had 4 main rotor blades and a C18 Allison engine. The D model has 5 blades and a C20 Allison. They are both type 369 helicopters. I believe Magnum used a D model. Gary Jim Burt wrote: There's no difference. 369 was the manufacturer's model series and on the type certificate. "500" was the marketing name. "Kent Shih" wrote in message ... How do you tell the difference between Hughes 369D and 500D from the outside? Does any one know if that Hughes (TC's) helicopter appeared in Magnum P.I.'s TV shows a 369D or a 500D? -- kent -- kent s |
Similar Threads | ||||
Would the AH-6J (Little Bird make a good, low cost, helicopter for force protection? | John Hairell | Military Aviation | 7 | May 19th 04 01:04 AM |
Hughes Helicopters | Kent Shih | Rotorcraft | 1 | January 17th 04 05:38 PM |
Hughes racer record 352mph 1935 | Chris W | Home Built | 6 | August 10th 03 09:57 PM |
Hughes Racer Replica Lost | Wayne Sagar | Home Built | 9 | August 10th 03 01:45 PM |
Hughes Racer down | MJC | Home Built | 5 | August 6th 03 06:10 AM |
