Here's an article:
http://www.newscientist.com/news/news.jsp?id=ns99996073 So if plasma reduces jet noise, then can it reduce turbine noise? There are gyroplanes like the one made by Groen Bros, and also the old Fairy, which used ramjets on the rotortips to boost rpm and lift during takeoff, but this caused terrible noise problems. Could this plasma noise-deadening approach make the ramjet rotor-assist more practical and feasible? |
Conventional turbo-shaft engines aren't quieter with these thecnology because it
noise has different origin (the turbine blades in some ways), the case of the ramjets is differnt, in this case the technology is aplicable, but not easy to "fine tune", and the plasma machines hads lows MTBF. This is not the only way to reduce the noise of the engines, other techonology is the active noise canceling using small piezo electric flaps on the gas stream, this could be used into the engines and on the rotors (Boeing Vertol and Eurocopter are working on it right now, GE and P&W also does research on this technology). Regards, JAngel "sanman" escribió en el mensaje om... | Here's an article: | | http://www.newscientist.com/news/news.jsp?id=ns99996073 | | So if plasma reduces jet noise, then can it reduce turbine noise? | | There are gyroplanes like the one made by Groen Bros, and also the old | Fairy, which used ramjets on the rotortips to boost rpm and lift | during takeoff, but this caused terrible noise problems. Could this | plasma noise-deadening approach make the ramjet rotor-assist more | practical and feasible? |
Cherokee Strobe Noise | Jonathan Goodish | Owning | 20 | November 2nd 04 02:42 AM |
Funny noise update | Peter Duniho | Piloting | 1 | July 1st 04 02:58 PM |
Plasma Reduces Jet Noise (Turbines?) | sanman | Home Built | 1 | June 27th 04 12:45 AM |
Prop noise vs. engine noise | Morgans | Piloting | 8 | December 24th 03 03:24 AM |
Getting rid of turbines. (grin) | ArtKramr | Military Aviation | 15 | December 6th 03 05:25 AM |
