Rotating Beacon
Old July 17th 04, 06:36 PM
steve
Default Rotating Beacon
HELP!! I have an old 28 vdc Grimes Rotating Beacon with an all red
cover that does not work anymore. It appears the motor
(Barber-Coleman)is missing a brush and spring. Does anyone know where
I can get another motor? If not, then does anyone know where I can get
another rotating beacon? Exact model not a problem just one that WORKS
and will fit into a hole that is approximately 4" in diameter. Is
there any website that offers any info as to what the components are
and 'do'? Any and all help will be greatly appreciated.......
Old July 18th 04, 06:50 AM
Gyroplanes
Avlite Aviation in PasoRobles, CA (advertises in Trade A Plane) has surplus
parts for grimes products.
A warning to you about potential "sticker shock" I understand the motor alone
might be in excess of $500.00.
Our Mitsubishi and Barons use a Grimes oscillating beacon (two bulbs that
wiggle back and forth) The overhaul on this beacon is around $1000.00.
Insanity.
Your round beacon can probably be replaced by a (relatively) low cost strobe
light replacement. They are readily available.
The beacon you have appears frequently on ebay and usually goes real cheap.
Hope I've been some help, Tom
Counter rotating propellers Raoul Military Aviation 24 September 21st 04 05:59 AM
B-52 crew blamed for friendly fire death Paul Hirose Military Aviation 0 March 16th 04 12:49 AM
Rotating Beacon vs. Flashing Beacon Mike Rapoport Owning 16 February 6th 04 11:05 PM
replacement rotating beacon for 64 piper cherokee Patrick Mathews Owning 2 October 1st 03 01:55 PM
Marker Beacon Tones Ron Natalie Owning 1 July 4th 03 03:27 PM
