Why do Hughes tail rotor blades cost $10,000+ (Barnstormers)
Cam. |
Because people will (have to) pay it.
Bart Cam wrote: Why do Hughes tail rotor blades cost $10,000+ (Barnstormers) Cam. |
I presume that's $US aswell, the best part of $20,000 NZ. You could buy
ten good Toyota Corola's for that over here. When are the Japs gonna start building helis? Cam. |
When the market is more than a hundred thousand units per annum?
"Cam" wrote in message ... I presume that's $US aswell, the best part of $20,000 NZ. You could buy ten good Toyota Corola's for that over here. When are the Japs gonna start building helis? Cam. |
Prouty wrote ~ "The overall airplane lift-to-drag ratio can be 10 to 30,
depending on the configuration, whereas the maximum a helicopter can do is 4 to 6." Cam wrote "When are the Japs gonna start building helis?" Me writes ~ When they brake away from the 60 year Western rotorcraft mindset and improve the L/D ratio, by; - Abolishing the wasteful tail rotor, - Providing Active Twist Blades, which can optimize the L/D ratio at all locations within the disk, - Providing larger, slower rotors, plus a horizontal thruster. Dave J "Cam" wrote in message ... I presume that's $US aswell, the best part of $20,000 NZ. You could buy ten good Toyota Corola's for that over here. When are the Japs gonna start building helis? Cam. |
"Dave Jackson" wrote in message news:ZxJXc.229824$J06.58978@pd7tw2no... Me writes ~ When they brake away from the 60 year Western rotorcraft mindset and improve the L/D ratio, by; - Abolishing the wasteful tail rotor, - Providing Active Twist Blades, which can optimize the L/D ratio at all locations within the disk, - Providing larger, slower rotors, plus a horizontal thruster. Dave J Abolishing the tail rotor? On a single rotor helicopter, that'll be an interesting exercise. MD does have the Notar but it's still putting a fair amoung of power into pressurizing that tail boom. There is no free lunch. There are the multi rotor machines with counterrotating rotor systems (tandom and coaxial) but if that were such a "big" advantage over the conventional single main rotor / tail rotor configuration, I'd have thought there'd be a LOT more of them out there by now. Active Twist rotor bades? That's an interesting concept. It's not one I've heard of before. I've love to see the engineering specs on them! :-) Larger, slower rotors? It's been done. It works Ok but you run into the problem of needing room to swing the blades. Horizontal pusher system? It's also been done. Now we're talking a compound aircraft, or at least the beginnings of one, and an aircraft that's a LOT more complicated and expensive. I think that the modern helicopter designs that are flying today, are flying because they've proven themselves to be amoung the best compromises that can be made between utility, cost, and function. They offer relatively good speed, point to point, for short to medium distances (I'm thinking 500 miles), and can take of and land virtually any place there's enough room to swing the rotors in. If you need faster, or greater distances, it's time to go fixed wing. JMO! Fly Safe, Steve R. |
Steve wrote; "Abolishing the tail rotor? On a single rotor helicopter,
that'll be an interesting exercise" Me writes; Agreed. Laterally located twin main rotors will be required. Interestingly, Sikorsky proposed the following single rotor concept 2 years ago, but its feasibility is questionable. ref. http://www.UniCopter.com/1281.html __________________ Steve wrote; "There are the multi rotor machines with counterrotating rotor systems (tandem and coaxial) but if that were such a "big" advantage over the conventional single main rotor / tail rotor configuration, I'd have thought there'd be a LOT more of them out there by now." Me writes; The tandem still lives, in fact, Boeing has proposed a side-by-side for future heavy lift craft. Unquestionably, the two best and most promising rotorcraft configurations at the dawn of helicopter flight were the Side-by-side and the Intermeshing. Then Germany lost the war. Additional reasons can be found at; http://www.synchrolite.com/B280.html ________________ Steve wrote; "Active Twist rotor blades? That's an interesting concept. It's not one I've heard of before. I've love to see the engineering specs on them! :-)" Me humbly submits; http://www.UniCopter.com/1101.html ________________ Steve wrote; "Larger, slower rotors? It's been done. It works Ok but you run into the problem of needing room to swing the blades." Me apologizes. Should have said; ' significantly larger chord'. ________________ The tilt-rotor may shoulder its way into a market located between that of the helicopter and that of the airplane. But, I strongly believe that a potentially much larger market exists for helicopters, if the conceptual focus can be redirected toward laterally located twin main rotor configurations. IMHO, Igor took helicopters in the wrong direction. Dave J. "Steve R." wrote in message ... "Dave Jackson" wrote in message news:ZxJXc.229824$J06.58978@pd7tw2no... Me writes ~ When they brake away from the 60 year Western rotorcraft mindset and improve the L/D ratio, by; - Abolishing the wasteful tail rotor, - Providing Active Twist Blades, which can optimize the L/D ratio at all locations within the disk, - Providing larger, slower rotors, plus a horizontal thruster. Dave J Abolishing the tail rotor? On a single rotor helicopter, that'll be an interesting exercise. MD does have the Notar but it's still putting a fair amoung of power into pressurizing that tail boom. There is no free lunch. There are the multi rotor machines with counterrotating rotor systems (tandom and coaxial) but if that were such a "big" advantage over the conventional single main rotor / tail rotor configuration, I'd have thought there'd be a LOT more of them out there by now. Active Twist rotor bades? That's an interesting concept. It's not one I've heard of before. I've love to see the engineering specs on them! :-) Larger, slower rotors? It's been done. It works Ok but you run into the problem of needing room to swing the blades. Horizontal pusher system? It's also been done. Now we're talking a compound aircraft, or at least the beginnings of one, and an aircraft that's a LOT more complicated and expensive. I think that the modern helicopter designs that are flying today, are flying because they've proven themselves to be amoung the best compromises that can be made between utility, cost, and function. They offer relatively good speed, point to point, for short to medium distances (I'm thinking 500 miles), and can take of and land virtually any place there's enough room to swing the rotors in. If you need faster, or greater distances, it's time to go fixed wing. JMO! Fly Safe, Steve R. |
| VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 06:03 AM |
| Citizens for Honest Fighter Pilots - Anyone in Lt Bush's Moody AFB UPT Class | Roger Helbig | Military Aviation | 5 | August 13th 04 06:15 PM |
| Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 10:40 PM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
| God Honest | Naval Aviation | 2 | July 24th 03 05:45 AM | |
