Remember it takes a college degree to fly a plane, but only a high school diploma to fix one: After every flight, UPS pilots fill out a form, called a gripe sheet, which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight. Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by UPS pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers. By the way, UPS is the only major airline that has never, ever, had an accident.... P: Left inside main tire almost needs replacement. S: Almost replaced left inside main tire. P: Test flight OK, except auto-land very rough. S: Auto-land not installed on this aircraft. P: Something loose in cockpit S: Something tightened in cockpit P: Dead bugs on windshield. S: Live bugs on back-order. P: Autopilot in altitude-hold mode produces a 200 feet per minute descent S: Cannot reproduce problem on ground. P: Evidence of leak on right main landing gear. S: Evidence removed. P: DME volume unbelievably loud. S: DME volume set to more believable level. P: Friction locks cause throttle levers to stick. S: That's what friction locks are for. P: IFF inoperative in OFF mode. S: IFF always inoperative in OFF mode. P: Suspected crack in windshield. S: Suspect you're right. P: Number 3 engine missing. S: Engine found on right wing after brief search P: Aircraft handles funny. (I love this one!) S: Aircraft warned to straighten up, fly right and be serious. P: Target radar hums. S: Reprogrammed target radar with lyrics. P: Mouse in cockpit. S: Cat installed. And the best one for last P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer. S: Took hammer away from the midget. Be realistic. Expect a Miracle. |
On Thursday, November 27, 2014 1:58:09 PM UTC-5, wrote:
Remember it takes a college degree to fly a plane, but only a high school diploma to fix one: After every flight, UPS pilots fill out a form, called a gripe sheet, which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight. Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by UPS pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers. By the way, UPS is the only major airline that has never, ever, had an accident.... P: Left inside main tire almost needs replacement. S: Almost replaced left inside main tire. P: Test flight OK, except auto-land very rough. S: Auto-land not installed on this aircraft. P: Something loose in cockpit S: Something tightened in cockpit P: Dead bugs on windshield. S: Live bugs on back-order. P: Autopilot in altitude-hold mode produces a 200 feet per minute descent S: Cannot reproduce problem on ground. P: Evidence of leak on right main landing gear. S: Evidence removed. P: DME volume unbelievably loud. S: DME volume set to more believable level. P: Friction locks cause throttle levers to stick. S: That's what friction locks are for. P: IFF inoperative in OFF mode. S: IFF always inoperative in OFF mode. P: Suspected crack in windshield. S: Suspect you're right. P: Number 3 engine missing. S: Engine found on right wing after brief search P: Aircraft handles funny. (I love this one!) S: Aircraft warned to straighten up, fly right and be serious. P: Target radar hums. S: Reprogrammed target radar with lyrics. P: Mouse in cockpit. S: Cat installed. And the best one for last P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer. S: Took hammer away from the midget. Be realistic. Expect a Miracle. Without aircraft maintenance, pilots would just be pedestrians with a big watch, cool sunglasses and a leather jacket |
All very witty and amusing, but I've seen them all before over several
decades, attributed to other sources. UPS mechanics didn't invent them At 00:54 28 November 2014, Dan Marotta wrote: Since when did UPS install targeting radar? Do they intercept and shoot down FedEx planes? BTW, this used to be attributed to USAF squawk sheets... On 11/27/2014 11:55 AM, wrote: Remember it takes a college degree to fly a plane, but only a high school diploma to fix one: After every flight, UPS pilots fill out a form, called a gripe sheet, which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight. Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by UPS pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers. By the way, UPS is the only major airline that has never, ever, had an accident.... P: Left inside main tire almost needs replacement. S: Almost replaced left inside main tire. P: Test flight OK, except auto-land very rough. S: Auto-land not installed on this aircraft. P: Something loose in cockpit S: Something tightened in cockpit P: Dead bugs on windshield. S: Live bugs on back-order. P: Autopilot in altitude-hold mode produces a 200 feet per minute descent S: Cannot reproduce problem on ground. P: Evidence of leak on right main landing gear. S: Evidence removed. P: DME volume unbelievably loud. S: DME volume set to more believable level. P: Friction locks cause throttle levers to stick. S: That's what friction locks are for. P: IFF inoperative in OFF mode. S: IFF always inoperative in OFF mode. P: Suspected crack in windshield. S: Suspect you're right. P: Number 3 engine missing. S: Engine found on right wing after brief search P: Aircraft handles funny. (I love this one!) S: Aircraft warned to straighten up, fly right and be serious. P: Target radar hums. S: Reprogrammed target radar with lyrics. P: Mouse in cockpit. S: Cat installed. And the best one for last P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer. S: Took hammer away from the midget. Be realistic. Expect a Miracle. -- --- Dan Marotta |
On 11/27/2014 11:14 PM, Chris Rollings wrote:
All very witty and amusing, but I've seen them all before over several decades, attributed to other sources. UPS mechanics didn't invent them By the way, UPS is the only major airline that has never, ever, had an accident.... In the further interest(s) of accuracy: UPS Flight 1354, Aug 2013... I'll be leaving now, my anal work here is done. Bob W. |
Well that's a load of porky pies isn't it. |
| Thread Tools | |
| Display Modes | |
| Another way to enjoy wave | kd6veb | Soaring | 3 | January 2nd 09 11:48 PM |
| If you enjoy UseNet you might read this... | Ronnie Baker | Aviation Photos | 5 | June 28th 08 10:40 PM |
| A story most pilots will understand, and enjoy | [email protected] | Piloting | 8 | June 30th 07 08:56 PM |
| A few thoughts I think most will enjoy. | Chris W | Piloting | 2 | December 4th 06 07:04 PM |
| Enjoy your achievements as well as your plans. | Martin | Piloting | 1 | February 10th 04 01:35 AM |
