Pan Am PAI 747 display?
Old July 9th 03, 02:48 AM
Dr. Speedbyrd:>
Default Pan Am PAI 747 display?
I downloaded the 747 Pan Am Clipper (PW) from PAI, but can't get it to display. The install
looks correct with the model.pw and texture.paa which I set up with the Pan Am texture, but the
plane just doesn't appear. Any idears?
Thanks,
Old July 12th 03, 09:21 PM
Ron Ginsberg
Thanks,
Couple of suggestions:
1. Bring up the plane in Create A Flight. Does it show OK on the
preview? If so, place it on a runway, go to spot view, and see how it
looks. This checks the model.
2. Did you create a flight plan using it and merge it into your FS2K2 AI
flight schedule? If you are not familiar with the procedures, download
AI Traffic Mover from the usual sources. It includes the decompiler and
compiler necessary to retrieve the current AI schedule, a GUI front end
that lets you edit and merge in your stuff, and a compiler to recreate
the traffic.bgl file. It also includes analysis and scheduling tools
built in. The analysis lets you check the validity of the aircraft,
routes, and other issues. It must be scheduled to show. To see how the
data should look, just download an AI flightplan and look at the various
files.
3. I just downloaded and started using AI Tactical Display. Within an
active flight you can open up this plug-in's window and it shows as
targets the AI in the area. Click on a target and you get data about its
current status. I use it along with visual monitoring to check the
validity of the aircraft flight model. As an example, I had a 757-200
that would taxi on to the runway and stay there forever. AITD showed it
was at full throttle and indicated it was on take-off roll as commanded
by the AI engine. Bad model. I replaced it with a similar version and
all was well again.
4. There are FAQs posted in the Help forum of Project AI. Also get AFCAD
and its FAQ to check-out and modify the virtual airport plan AI uses.
5. It was I think the Jan and Feb issues of Computer Pilot that had very
nioce tutorials on the whole business. AI is complex and I suggest you
get these issues if you are sticking to FS2K2.
Old July 15th 03, 11:05 AM
Dave Pearson
* Dr. Speedbyrd: :
display. The install looks correct with the model.pw and texture.paa which
I set up with the Pan Am texture, but the plane just doesn't appear. Any
idears?
Doesn't appear in the list of available aircraft or doesn't appear in
internal/external views once you've selected the aircraft and started a
flight?
Dave Pearson
http://www.davep.org/
Old July 15th 03, 02:15 PM
Dr. Speedbyrd:>
On 15 Jul 2003 10:05:25 GMT, Dave Pearson wrote:
* Dr. Speedbyrd: :
idears?
flight?
Nope but it's ok. Found Pan Am textures for the default 747 and works just fine.
Little steep on the climb, but all else is good. Thanks.
KX-155 LEDs Steven Barnes Owning 21 July 11th 13 09:04 AM
A-6 Redar Display? Mike Kanze Naval Aviation 0 September 28th 04 01:34 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Airplane / space vehicle display models wanted Aleta Jackson General Aviation 0 May 19th 04 02:17 AM
F-15C countermeasures display. Gene Military Aviation 0 August 5th 03 05:38 PM
