I am trying to create a Restricted Area Navpoint with an "R" Attribute, ceiling altitude, and radius so my GPS-NAV can alert me if I invade that space.. The old MS-DOS software allowed creation of such a Navpoint but the subsequent Aero Explorer does not. The .dat file structure appears to be:
ID #,Latitude,Longitude,Elevation,Attributes,Name,Tex t Presumably ceiling altitude and radius would follow additional commas, but in what order or where in the line? |
Can't answer your question other than to tell what I do. I load the restricted areas as a turn-point, like RRR Reno with a note "avoid by 12 s/m". The RRR tells me it is a restricted area, not a turn-point and I monitor the area as I pass by. This has saved me several times. I remember once when the "get-home-thermal" was .5 miles outside the restricted area and the thermal was drifting towards the restricted area, by monitoring the distance, I was able to work the thermal up to get-home altitude!
Gp Patriots! JJ |
See my new post: Running Cambridge GPS-NAV DOS Program on Windows
Cambridge file conversions for OLC (yet again) | Steve Leonard[_2_] | Soaring | 9 | July 6th 14 02:29 PM |
Trouble transferring file from Cambridge 302 | [email protected] | Soaring | 9 | May 13th 09 12:36 AM |
Cambridge .dat waypoint file spec | David | Soaring | 1 | September 27th 04 04:19 AM |
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 | Nathan Whelchel | Soaring | 4 | July 5th 04 11:22 PM |
IGC File Fix for Cambridge GPS NAV? | Jim Vincent | Soaring | 6 | March 27th 04 08:03 PM |
