OK, your patience please. I'm a very novice simmer.
I'm a pilot trying to clean more rust off her instrument skills than I have flight time for, since the birth of my daughter. I'm trying to use MSFS '98 to fly instrument approaches. My husband has it configured with CH products yoke and rudder pedals. I've been flying a Grumman Cheetah someone else modeled and I found on the net, since IRL I fly a Grumman Tiger and it's nice to have the power settings etc etc be fairly close to real life. The questions. 1) Allowing for my sim inexperience, the aerodynamic behavior appears to suck great big rocks. My hat is off to people who have hundreds of hours flying instrument approaches in MSFS to 2/20 standards. In particular, the pitch axis is way too twitchy. A small yoke movement will produce 1000 ft rate on the VSI without large airspeed excursions. IRL, such a rate requires 1) a larger yoke movement 2) the airspeed will be winding up (or down) fast. I thought it might just be the plane, but I tried the stock C182 and it was the same where IRL "way haul away" is the yoke MO in a C182. I tape my wrists when I'm flying one at forward CG. Are there any settings I'm missing which could "tweak" this? Any advice about setting the yoke controls to minimize this? 2) We are missing many local airports from our database (St. Louis area). The big Class D and B airports are there, but the smaller GA airports aren't. Is there a freeware or shareware source for smaller airports for FS '98 3) I would like to look at my ground track and flight profile to see how it compares to the track of the instrument approach. I found the "flight analysis" "course tracking", which is a start. But is there a way to scan back along the course? Or to compare it to a specified ground track? Is there a freeware or shareware product which will do this? (ie allow one to specify a flight path or procedure to be flown, then compare what was flown)? Or at least to display ground-based navaids and features (like runway) at a map height which will allow a decent amount of the track to be displayed? I heard mention of a product called "Nav" by Tim Wright, will this do it? If so what version do we want for FS '98 and where do we obtain it? 4) Slewing. Often where I want to be is a couple miles from a ground-based navaid which I can specify easily as a lat-long. But when I type "y" for slewing, the plane just spins around and around. Doesn't seem to respond to keyboard controls specified for slewing in different directions. Anyone else have this problem and what's the cure? Basically one thing all these questions might amount to is, should we upgrade? We skipped FS 2000 because we heard it was such a system hog. We have a pretty fast, large-memory system now, we just haven't bothered to upgrade. Should we invest in a newer sim and if so, which one? I'd like: 1) realistic flight modeling of a small GA plane, preferably a 4-place Grumman 2) a reasonably realistic and easy to set instrument panel (ie I want to be able to set radios while I'm flying, it's part of what I need to practice, not switch to a different view which blocks the instruments) 3) decent wind modeling 4) a good database of airports and navaids 5) the ability to analyse my ground track and flight profile after the flight. I could care less about "eye candy" scenery or flying fancy planes right now. But, I don't want to pay hundreds of bucks for an IFR sim which doesn't model a plane of similar performance and settings to mine and no chance of a shareware or freeware model, either. And I gotta admit, the spouse is more into "eye candy" and fancy planes when he has time to sit down at the sim. We could upgrade to MSFS 2002 or 2004 but I'd hate to do it if it would mean more airports and better scenery, but the same flight model inaccuracies. The VSI (pitch excursion) aspect of the flight modeling in particular is driving me fairly wild. Thanks for any help, Sydney |
"Sydney Hoeltzli" wrote in message
... 1) Are there any settings I'm missing which could "tweak" this? Any advice about setting the yoke controls to minimize this? Use the trim, if you aren't already. Also, I think you ought to be able to adjust the control sensitivity somewhere in the game settings (sorry I'm not more specific...'98 was a while ago ![]() 2) We are missing many local airports from our database (St. Louis area). The big Class D and B airports are there, but the smaller GA airports aren't. Is there a freeware or shareware source for smaller airports for FS '98 Don't know. FS2002 has all US airports though. 3) I would like to look at my ground track and flight profile to see how it compares to the track of the instrument approach. I found the "flight analysis" "course tracking", which is a start. But is there a way to scan back along the course? Don't know exactly. The flight recorder in FS2000/2002 (again, can't recall if it's in FS98) allows you to go forward and backward on the flight. I think it might also show a route that was entered in the GPS, for comparison to a specific ground track. 4) Slewing. Often where I want to be is a couple miles from a ground-based navaid which I can specify easily as a lat-long. But when I type "y" for slewing, the plane just spins around and around. Doesn't seem to respond to keyboard controls specified for slewing in different directions. Anyone else have this problem and what's the cure? I haven't seen this. Slewing works as advertised for me. Have you double-checked your key assignments to make sure they didn't get munged somehow? Basically one thing all these questions might amount to is, should we upgrade? We skipped FS 2000 because we heard it was such a system hog. We have a pretty fast, large-memory system now, we just haven't bothered to upgrade. FS2000 *was* a huge system hog. FS2002 is much better. We could upgrade to MSFS 2002 or 2004 but I'd hate to do it if it would mean more airports and better scenery, but the same flight model inaccuracies. The VSI (pitch excursion) aspect of the flight modeling in particular is driving me fairly wild. Not knowing exactly what problems you're having, I can't tell you whether you'll see the same thing in FS2002/04. However, while the airplanes certainly aren't exactly like the real thing, I have not noticed either of the problems you've seen. What does the altimeter show you when the VSI is acting up? Maybe the VSI is just inaccurately simulated (shouldn't be using it as your primary reference anyway, due to the lag in the instrument). The one caveat I can think of is that there are often hassles getting planes made for older versions of MSFS to work with newer versions. You should probably try to verify that you know of a working Cheetah/Tiger model before you bother upgrading. I guess all of the above isn't really that much help. Sorry I didn't have better... Pete |
On Tue, 22 Jul 2003 13:56:13 GMT, Sydney Hoeltzli
wrote: OK, your patience please. I'm a very novice simmer. I'm a pilot trying to clean more rust off her instrument skills than I have flight time for, since the birth of my daughter. I'm trying to use MSFS '98 to fly instrument approaches. My husband has it configured with CH products yoke and rudder pedals. I've been flying a Grumman Cheetah someone else modeled and I found on the net, since IRL I fly a Grumman Tiger and it's nice to have the power settings etc etc be fairly close to real life. snipped Aircraft input realism can vary significantly from plane to plane, but your observation regarding pitch control is a good one. That is the single most difficult motion to get right. That being said, it is not hopeless. First, I would recommend upgrading if your machine is capable enough. I don't recall how much of a resource hog '98 was. 2000 was bad and 2002 showed a big improvement. Microsoft is just about to release 2004 so you may want to wait. Upgrading will solve the airport issue. I believe that the flight models are better also, although the improvement is marginal. There are ways to edit the flight model values but I've never done that so I'll leave that to others. But be aware that the option is there to tweak the planes characteristics. I control my fine pitch adjustments with trim. I have two of the buttons on my yoke programmed for trim up and trim down. That way I can tap the button once or twice to get a more realistic change in pitch. This is counter to the mantra "don't fly the plane with the trim wheel" but it works. We have to make compromises as there are differences between flying a computer and flying a real plane. I have been using Flight Simulator since it was first produced by SubLogic in the early eighties but I only got my PP ticket earlier this month. From that perspective, I can tell you that there are a number of things that are easier in the real plane than they are on the sim. Another suggestion that I have is to search for aftermarket planes for the sim. I know that's a problem for the Grumman because I tried to find one a while back to show my CFI (she has one). I also downloaded many 152s to use while I was training. One of those, and only one, provided me with a flight model that was acceptable. It is very possible that you will find and aftermarket plane that performs more realistically than any of the default planes. Good luck. Rich Russell |
Richard Russell wrote in message . ..
First, I would recommend upgrading if your machine is capable enough. I don't recall how much of a resource hog '98 was. 2000 was bad and 2002 showed a big improvement. Microsoft is just about to release 2004 so you may want to wait. Upgrading will solve the airport issue. I believe that the flight models are better also, although the improvement is marginal. There are ways to edit the flight model values but I've never done that so I'll leave that to others. But be aware that the option is there to tweak the planes characteristics. OK...where would I find info on how to do this? Anyone know? Do I need a special Airplane Designer program to do it? I control my fine pitch adjustments with trim. Me, too. But the yoke is still so sensitive that it's very difficult to obtain small rates of climb and descent (100 fpm) to adjust altitude excursions, or to adjust the rate of descent on an ILS. I tried turning down the sensitivity of the yoke, but I'm not sure that helped. It may actually have made the problem worse -- I have to push a bit harder to get any change, and the window between "some change" and "huge change" seems narrower, if this makes sense. Another suggestion that I have is to search for aftermarket planes for the sim. I know that's a problem for the Grumman because I tried to find one a while back to show my CFI (she has one). We have 2 Cheetahs and a Tiger. I've been flying one of the Cheetahs because it's better than the Tiger on the pitch excursions, but acting on your advice I'll try the other Cheetah and see if it's better. It would be great if I could tweak the Cheetah I'm using, though. It has Narco Nav radios, which are convenient as one doesn't have to bring up a seperate radio stack to change frequencies. I've been checking to see if there are aftermarket Grummans available for 2002 (or upcoming 2004) and so far No Joy, anyone know of one? Doubtless I don't know the best places to check....is it possible to convert planes from '98 to 2002/4? Does 2002/4 take care of the flight trace/profile view problem? Thanks! Sydney |
![]() Sydney Hoeltzli schrieb: OK, your patience please. I'm a very novice simmer. I'm a pilot trying to clean more rust off her instrument skills than I have flight time for, since the birth of my daughter. I'm trying to use MSFS '98 to fly instrument approaches. My husband has it configured with CH products yoke and rudder pedals. I've been flying a Grumman Cheetah someone else modeled and I found on the net, since IRL I fly a Grumman Tiger and it's nice to have the power settings etc etc be fairly close to real life. The questions. 1) Allowing for my sim inexperience, the aerodynamic behavior appears to suck great big rocks. My hat is off to people who have hundreds of hours flying instrument approaches in MSFS to 2/20 standards. In particular, the pitch axis is way too twitchy. A small yoke movement will produce 1000 ft rate on the VSI without large airspeed excursions. IRL, such a rate requires 1) a larger yoke movement 2) the airspeed will be winding up (or down) fast. I thought it might just be the plane, but I tried the stock C182 and it was the same where IRL "way haul away" is the yoke MO in a C182. I tape my wrists when I'm flying one at forward CG. Are there any settings I'm missing which could "tweak" this? Any advice about setting the yoke controls to minimize this? Go into the setings and reduce the elevator sensitivity. 2) We are missing many local airports from our database (St. Louis area). The big Class D and B airports are there, but the smaller GA airports aren't. Is there a freeware or shareware source for smaller airports for FS '98 You might look at one of the sites like www.avsim.com for freeware scenery for FS98, or just Google FS98 Scenery GA. 3) I would like to look at my ground track and flight profile to see how it compares to the track of the instrument approach. I found the "flight analysis" "course tracking", which is a start. But is there a way to scan back along the course? Or to compare it to a specified ground track? Is there a freeware or shareware product which will do this? (ie allow one to specify a flight path or procedure to be flown, then compare what was flown)? Or at least to display ground-based navaids and features (like runway) at a map height which will allow a decent amount of the track to be displayed? I heard mention of a product called "Nav" by Tim Wright, will this do it? If so what version do we want for FS '98 and where do we obtain it? I used Nav (by Ted Wright) to display the navaids in FS98, and design flightplans. A great piece of freeware. The FS98 handbook gives you no idea how many navaids are really there. 4) Slewing. Often where I want to be is a couple miles from a ground-based navaid which I can specify easily as a lat-long. But when I type "y" for slewing, the plane just spins around and around. Doesn't seem to respond to keyboard controls specified for slewing in different directions. Anyone else have this problem and what's the cure? I've seen this happen. Most likely your joystick/yoke controls are mapped as inputs to slew mode. Go into your FS98 settings and make sure there are no joystick/yoke settings for slew mode. Tom Basically one thing all these questions might amount to is, should we upgrade? We skipped FS 2000 because we heard it was such a system hog. We have a pretty fast, large-memory system now, we just haven't bothered to upgrade. Should we invest in a newer sim and if so, which one? I'd like: 1) realistic flight modeling of a small GA plane, preferably a 4-place Grumman 2) a reasonably realistic and easy to set instrument panel (ie I want to be able to set radios while I'm flying, it's part of what I need to practice, not switch to a different view which blocks the instruments) 3) decent wind modeling 4) a good database of airports and navaids 5) the ability to analyse my ground track and flight profile after the flight. I could care less about "eye candy" scenery or flying fancy planes right now. But, I don't want to pay hundreds of bucks for an IFR sim which doesn't model a plane of similar performance and settings to mine and no chance of a shareware or freeware model, either. And I gotta admit, the spouse is more into "eye candy" and fancy planes when he has time to sit down at the sim. The eye candy is a major factor with FS2002. Make sure your machine is up to it- at least 256kbytes, 800 MHz, and a 3d graphics card. Otherwise stick with FS98. Tom We could upgrade to MSFS 2002 or 2004 but I'd hate to do it if it would mean more airports and better scenery, but the same flight model inaccuracies. The VSI (pitch excursion) aspect of the flight modeling in particular is driving me fairly wild. Thanks for any help, Sydney |
wrote: OK, your patience please. I'm a very novice simmer. [snipped many tales of woe] All your problems stem from your misconception that MSFS98 is a 'flight simulator', whereas in fact it is a 'game'. Talk to your RL instructor about purchasing a flight simulator that will count IFR hours towards your PPL. Paul --------------------------------------- Milton Keynes - twinned with Mos Eisley |
NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 05:12 AM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
