Open Class
Old February 14th 15, 12:29 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Open Class
I have been away from soaring for 12 years and have noticed the open class now has long wing and much shorter wing birds (JS-1C) competing. I am curious how do the 21 and 23 meter new ships keep up with the ASW-22BL's and Nimbus-4's. Are the new shorter wing gliders better overall (better L/D, better penetration ) or just better on strong days when wing loading counts more than the ability to stay in the air?
Old February 14th 15, 02:11 AM posted to rec.aviation.soaring
Default Open Class
I think a lot depends on where you"re flying. Strong conditions may favor higher wing loading, weaker prefers lighter wing loading/higher aspect ratio..
Old February 14th 15, 02:42 AM posted to rec.aviation.soaring
Tony[_5_]
Default Open Class
On Friday, February 13, 2015 at 8:11:29 PM UTC-6, Charlie M. (UH & 002 owner/pilot) wrote:
the JS-1C seems to have done pretty well and run with "the big boys" at both Uvalde 2012 and Leszno 2014.
http://soaringspot.com/wgc20112/resu...ay-by-day.html
http://soaringspot.com/leszno2014/re...ay-by-day.html
Old February 14th 15, 03:08 AM posted to rec.aviation.soaring
Craig Funston
Default Open Class
My (limited) understanding is that span loading is a significant factor. If you can make a lighter glider with a high aspect ratio, the span can be reduced as the weight is reduced without sacrificing un-ballasted performance. With a smaller wing area the wing loading can be increased without busting the overall weight limit for the class.
I know of at least one pilot that has passed on the Quintus or EB-29 to go with the JS-1c. As a Nimbus3 driver I can't help but be envious of the lighter empty weight, shorter span, better handling that comes with better performance to boot.
Cheers,
Craig 7Q
Old February 14th 15, 07:57 PM posted to rec.aviation.soaring
J. Nieuwenhuize
Default Open Class
The smaller the wing (area, not span), the bigger the relative drag of the fuselage becomes.
On that note, what happened to the 18 meter Diana II that was rumored to come out?
Old February 16th 15, 03:26 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Open Class
Maybe the same thing that happened when someone asked Greg Cole (Duckhawk designer) if he was going to make an 18 meter version. He said "Why would you want to make it slower?" :-)
Old February 14th 15, 05:49 AM posted to rec.aviation.soaring
Bruce Hoult
Default Open Class
On Saturday, February 14, 2015 at 1:29:03 PM UTC+13, Jonathan St. Cloud wrote:
If you look at the polars, those old long wing gliders have amazing glide angles at 55 knots, but they lose badly to the new thin airfoils at high speed.
Yes, exactly, where "strong days" means anything over 1 or 1.5 knot climbs.
Old February 21st 15, 04:09 AM posted to rec.aviation.soaring
Bob Kuykendall
Default Open Class
On Friday, February 13, 2015 at 9:49:02 PM UTC-8, Bruce Hoult wrote:
...but they lose badly to the new thin airfoils at high speed...
It's kind of a nitpick, but there's really nothing new about thin airfoils. What has changed in the last decade and a half is the cost-effectiveness of the structure required to implement them in competitive sailplanes.
Thanks, Bob K.
Old February 21st 15, 04:43 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Open Class
Thanks, Bob K.
I think there is something new about the thin airfoils in use today, though, Bob. Laminar flow over a greater percentage of chord. Laminar flow over that chord at much lower reynolds numbers. Ability to maintain low drag to higher C/L.
Chicken and egg sort of question. Did structural design philosophy dictate airfoil design in terms of thickness, or did the airfoil design encourage continued use of the same old structural design techniques?
Steve Leonard
Old February 21st 15, 06:49 AM posted to rec.aviation.soaring
Bruce Hoult
Default Open Class
Sure, carbon spars enabled them.
WGC Open Class Richard Walters Soaring 1 August 12th 12 05:14 PM
Should SSA Regional contests allow water in FAI class...15, 18, 20,Open class? Sean Fidler Soaring 25 December 16th 11 02:14 PM
Open Class Nationals [email protected] Soaring 6 July 12th 05 05:05 PM
DAY 4 U.S. Open Class Nationals [email protected] Soaring 3 July 3rd 05 03:24 PM
UK Open Class and Club Class Nationals - Lasham Steve Dutton Soaring 0 August 6th 03 10:07 PM
