Joy stick or wheel?
Old August 4th 03, 07:33 PM
Wally Samuelson
Default Joy stick or wheel?
When I bought FS2004 I got a deal (?) which included a wingman joystick for
about $12.
This also had a rebate of $12 which made it essentially free. I am
beginning to think that it is worth what I paid for it.
It doesn't react well, the throttle setting will not advance far enough on
the 172 to give full take off power, etc. I have tried to find the
calibration page to no avail. The help file doesn't even recognize the word
calibrate.
It looks to me like an obsolete model. It has an adapter from a game port
connector to USB.
OK what should I get a stick or a wheel? I learned to fly with a stick,
but most of my time is with a wheel. I really just want to play with the J
3, the 172, 182 etc. I might fool around a little with the heavier stuff,
but no big deal.
What should I buy, and which brands etc seem to work best? I am willing to
spend $100 or so.
Wally
1st solo, 1936 in a Curtiss Robin
Old August 4th 03, 07:53 PM
Skyhawk
Wally,
I would recommend the CH Products Yoke w/ throttle,mixture, and prop
controls. If you want to spend the big bucks, get the Pro Pedals as well.
They are around $250 purchased at the same time or $130 each. I would check
out the www.pcaviator.com web site. I have purchased from them with
success, and they have competitive prices. It is hard to find the good
controls at retail. As an alternative, the Microsoft Force Feedback 2
joystick works well and it is around $100.
"Wally Samuelson" wrote in message
news:wFxXa.44929$cF.16840@rwcrnsc53...
for
about $12.
word
calibrate.
connector to USB.
J
but no big deal.
to
spend $100 or so.
Wally
Old September 30th 03, 02:34 AM
CriticalMass
"Skyhawk" wrote in message
check
While I won't argue with any of the above, I will add my comments.
I am now using CH USB rudder pedals, with no issues to report.
I *used* to own the CH Yoke with engine controls and all the buttons.
Believe it or not, the damned thing stripped the hardware-store clamp bolts
that secure it to the desktop. I could no longer attach it to my desk and
use it to fly. It boggled my mind that such a low-tech item would tank, but
it did. It went into the trash.
I will not buy from CH Products again. If they can't get an item like that
right (and, mind you, I've been using their stuff for a L O N G time), they
have lost my confidence.
So, I'm now flying the sim with the CH USB Pro pedals and a Microsoft FFB2
force feedback joystick.
I agree that flying most of the sim airplanes is best enjoyed with a yoke,
as opposed to a stick. I'm waiting for something more durable than the CH
yoke to surface on the market. I have the bucks, and I'll spend them, if
that's what's required to get *quality* flight sim controls.
Old October 5th 03, 06:17 AM
Marc
"CriticalMass" wrote in message
well.
check
bolts
but
that
they
I had two of those, and no problems with the bolts. The bolt itself is a
stainless steel standard piece of hardware -- type SBY, which can be
obtained at a hardware store. It is epoxied into the knob. The socket into
which the bolt fits is brass and pretty durable. I don't see anything poorly
made about these parts, but they are easy to replace if they should go. In
any case, I would not judge a flight yoke by the bolts that hold it to the
desk, that is a pretty minor part.
I have held off getting the rudder pedals. Are they useful? Seems like a lot
of money for something that doesn't get used too often. In a crosswind I
just land a little kilter -- unlike the real thing, there are no repair
bills for damaging the virtual main struts, at least not so far.
Question, do any of the virtual airplanes accurately simulate a forward slip
using the rudder pedal - including rapid loss of altitude, etc.?
thanks
Old October 10th 03, 12:38 AM
CriticalMass
"Marc" wrote in message
news:kPNfb.679792$YN5.538941@sccrnsc01...
poorly
It may be minor to you, but it's a major hassle when it becomes impossible
to attach the damned thing to the desk, and hardware isn't exactly rocket
science - I'll go elsewhere when a supplier can't get THAT part right.
lot
OK, now you've identified yourself. You're not a pilot, you're a gamer.
Sure, you can avoid all the hassle of control devices and just try to fly
with your keyboard. How realistic do you want it to be?
Real airplanes have rudder pedals. If you want realism, get rudder pedals.
If you don't care, check the box for autocontrol. Your choice.
slip
Yes, to varying degrees, just like the real thing
Old October 14th 03, 02:38 AM
Marc
into
poorly
In
replacing the hardware is minor. If you want to, send me your unit and I'll
do it for you.
lot
actually I'm a pilot.
pedals.
well, sims are not realistic enought to start with, so I dont see the point
in adding the expense of rudder pedals just to straighten up on the
approach. Forward slips might be interesting, but otherwise I just pretend
I'm an Ercoupe when landing.
Old October 8th 03, 06:38 AM
Dashi Toshii
well.
check
bolts
but
that
they
You want quality? Go to: http://www.flypfc.com
Dashii
Old October 10th 03, 12:47 AM
CriticalMass
"Dashi Toshii" wrote in message
Yeah, yeah, I know. I've been watching those folks. Probably good stuff, I
agree, but at those prices, and still without throttle/prop/mixture in the
console?
I don't think so.
Add up what it costs to get the added modules to make up a usable setup, and
it's time to start thinking about a real airplane. Maybe, not quite, but
the point is valid.
Note that I *own* a real airplane, and my flying experience is not limited
to my computer. So, I have a frame of reference, for performance, AND cost.
Old October 5th 03, 01:05 PM
Alex Feldstein [MVP]
On Mon, 04 Aug 2003 18:33:00 GMT, "Wally Samuelson"
spend $100 or so.
Wally
Wally
I have the MS Sidewinder 2. It has a throttle and a few buttons
already programmed (and easy to change if needed). It works very well.
It also has rudder control by rotating the handle.
As I got tired of this part, I got CH pedals in eBay, brand new at a
decent price some time ago.
The combination works well.
HTH
Alex Feldstein
_______________________________________________
There's two possible outcomes: if the result confirms the hypothesis, then you've made a discovery. If the result is contrary to the hypothesis, then you've made a discovery.
Please respond in the public groups so that everybody
can benefit from the exchange.
No email please. (Address scrambled with ROT-13)
Piper 6.00x6 Nose wheel and fork? mikem Owning 2 March 6th 04 07:23 PM
Piper 6.00x6 Nose Wheel and Fork? mikem Products 5 March 5th 04 11:34 PM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 05:22 AM
Tailwheel endorsement John Harper Piloting 58 December 12th 03 01:48 PM
The Little Wheel in Back Veeduber Home Built 6 September 8th 03 10:29 AM
