DISCUS 2 a WT & BALANCE
Old February 20th 15, 02:06 AM posted to rec.aviation.soaring
Default DISCUS 2 a WT & BALANCE
HI
My Discus 2a manual says the ARM for Pilot & Parachute is ( -17.72 in.)
The A&P who did the WT & Balance 10 years ago used ( -15.20 in.) for the ARM.
Did he make a mistake? It's a big difference.
If you have a D2a can your check your WT & BAL for me.
If I could get a copy of your W&B that would be great.
Thanks
Glen
Old February 20th 15, 03:53 AM posted to rec.aviation.soaring
On Thursday, February 19, 2015 at 8:06:18 PM UTC-5, wrote:
HI
Thanks
Glen
See if the manual specifies different arms for light and heavy pilots.
UH
Old February 20th 15, 04:01 AM posted to rec.aviation.soaring
HI
Thanks
Glen
I don't see that, just a different Arm for a B model.
Old February 20th 15, 03:43 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
CG will vary with seat back position and thickness of parachute. Pilot CG is approximately your belly button. Climb in with chute on and measure the horizontal distance from the wing leading edge to your belly button (use a pumb-bob, then mark edge of canopy rail). If memory serves me, Discus performs best at 92% of allowable range..
:) JJ
Old February 20th 15, 04:17 PM posted to rec.aviation.soaring
Glen,
Getting ready for the Seniors... huh... I will check my information this evening when I get home. I will e-mail you. Have fun. It's -10 in upstate NY once again.
Tim Hanke
Discus 2a "H1"
HI
Thanks
Glen
Old February 20th 15, 05:12 PM posted to rec.aviation.soaring
Matt Herron Jr.
On Thursday, February 19, 2015 at 5:06:18 PM UTC-8, wrote:
HI
Thanks
Glen
you can back calculate your actual pilot/chute arm if the W&B includes the empty weight as well. SeeG makes this and other calculations for W&B very easy (shameless plug). Visit www.glideplan.com for more info.
Matt
Wanted DIscus CS or Discus B [email protected] Soaring 0 November 14th 08 02:17 PM
Discus verus Discus 2, LS8, ASW 28 Roger Soaring 45 October 31st 06 04:43 PM
Discus 3 or Super Discus? Mirek Soaring 1 June 13th 04 10:28 AM
Discus CS and Duo Discus Wing Inspections Nolaminar Soaring 0 October 24th 03 02:15 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 09:42 AM
