Oudie to Cambridge
Old March 6th 15, 03:49 PM posted to rec.aviation.soaring
HGXC[_2_]
Default Oudie to Cambridge
Anyone using an Oudie connected to a Cambridge GPS model 20? I have a few questions.
Dennis
Old March 6th 15, 06:55 PM posted to rec.aviation.soaring
Peter von Tresckow
Dennis
Yes mine is hooked up to a model 20 and s-nav.
What do you need to know?
Pete
Old March 6th 15, 08:28 PM posted to rec.aviation.soaring
HGXC[_2_]
On Friday, March 6, 2015 at 12:56:42 PM UTC-5, vontresc wrote:
Dennis
Pete
Perhaps we can private email...
But in general I am setting up the DB9 serial connect so the Oudie can talk to the Cambridge
I would like to see a photo of the pin set up on the male serial that plugs into the Cambridge. Also if you are only using 3 pins (Sending Receiving and Ground) what do you do with the rest of the wires? Does the plug only show 3 pins?
Also how can i tell of the oudie is taking GPS from the cambridge? My glider is in storage but i can plug my cambridge in to power it up and I can take the three pins and insert them into the Cambridge and plug the mini usb into the Oudie. When i do that it is saying it lost GPS signal and is going to internal GPS so i am confused.
Thanks ...obviously I don't do electronics well.
Dennis
Old March 6th 15, 11:06 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I show the connections for the RJ45 to DB-9m adapter for use with a GPS-NAV
and Oudie he
http://www.cumulus-soaring.com/seeyo...pter-RJ45-DB9m
Make sure you set the Oudie to comm port 4 and 4800 baud.
The SeeYou Mobile software can receive GPS and pressure altitude data from
the GPS-NAV. I don't think it can receive vario or airspeed data sent
through from an L-NAV.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
____________________________________
"HGXC" wrote in message
few questions.
Dennis
Pete
to the Cambridge
show 3 pins?
Dennis
Old March 6th 15, 11:17 PM posted to rec.aviation.soaring
vontresc
On Friday, March 6, 2015 at 4:06:35 PM UTC-6, Paul Remde wrote:
Hi,
and Oudie he
Best Regards,
Paul Remde
few questions.
Dennis
Pete
to the Cambridge
show 3 pins?
Dennis
Paul is spot on. I still have the original Oudie cable that had a DB9 connector instead of the RJ45. That original cable will plug rught into the DB9 on the back of the Model 20. Thena all you need to do is to connect the power connectors to the ships power and you are done.
If you have the newer version with the RJ45 then follow Paul's instructions to wire it up.
To test it you can go to the serial terminal mode under settings/hardware. Should be 4800baud 8N1
Peter
Old March 10th 15, 10:15 PM posted to rec.aviation.soaring
HGXC[_3_]
Hi,
and Oudie he
Best Regards,
Paul Remde
few questions.
Dennis
Pete
to the Cambridge
show 3 pins?
Dennis
To test it you can go to the serial terminal mode under settings/hardware.. Should be 4800baud 8N1
Peter
Peter all...its a bit frustrating as i still get a warning that I lost my primary GPS signal and going to back up. When i go to hardware i get the reading 4800 baud N 8 1. Its charging right from my 12 volt. I have tripled checked my red black and orange pins. Now i haven't clicked them in the converter yet i am just sticking the pins individually into the 2,3,and5 sockets..
Any other set up stuff i could be missing?
Dennis
Old April 17th 16, 08:38 PM posted to rec.aviation.soaring
Hi, just bought oudie 2 and would like it to talk with Cambridge 302 (and 303). Anybody have suggestions on how to connect the oudie to the 302 so i can also use the 5V from the 302? Standard cable has its own 12V cable and cant give the 5V.
Many thanks!
Thijs Paré
Old April 17th 16, 08:49 PM posted to rec.aviation.soaring
You can buy pre-made cable and converter box for this from Cumulus-Soaring.com. Look for their item Oudie-PS5a. $95.00. I happen to have one of these that I no longer need and would consider selling it for a reasonable offer.
https://www.cumulus-soaring.com/godd...m#Oudie-PS5a-1
Robert
Many thanks!
Thijs Paré
Old April 19th 16, 08:22 AM posted to rec.aviation.soaring
Surge
For those of you who are handy with a soldering iron and are on a shoe string budget like myself, eBay is a great source for electronic circuitry.
You can purchase TTL to RS232 converter boards on eBay.
They use the MAX3232 chip and you can purchase five of them for less than $2.
e.g. http://www.ebay.com/itm/5PCS-Mini-RS...-/131700206049
For 12V to 5V high efficiency, switched mode, voltage converters you can use the LM2596. Ten of them costs less than $4.
e.g. http://www.ebay.com/itm/LM2596-DC-DC...-/130729707683
I'm not affiliated with any of the above manufacturers. Paying up to $100 for a cable which costs less than $10 to manufacture is crazy.
Old April 19th 16, 05:36 PM posted to rec.aviation.soaring
Craig Funston
Surge,
Thanks for the links. Do you have any hands on experience with the electrical noise level of the voltage converters? I've tried cheap boards in the past and they broke the squelch on the radio.
Craig
Oudie 5.19 Bug Lauren Soaring 3 June 4th 14 07:57 PM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 06:31 PM
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 04:51 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 6th 04 12:22 AM
