The corner of my Ventus landing gear door got bent and needs to be glued back to its former shape.
What epoxy should I use (I need a very small amount) Need to clamp the piece while drying. What material to use so the clamp doesn't stay glued to the door....? Dan |
On Wednesday, March 11, 2015 at 11:23:27 AM UTC-4, wrote:
The corner of my Ventus landing gear door got bent and needs to be glued back to its former shape. What epoxy should I use (I need a very small amount) Need to clamp the piece while drying. What material to use so the clamp doesn't stay glued to the door....? Dan For this you could use a slow curing epoxy from your local hobby shop. I would not recommend 5 minute epoxy from your local hardware store. Poly film placed over the repair before clamping will allow removal and can help make the shape better. Good luck UH |
On Wed, 11 Mar 2015 08:52:51 -0700, unclhank wrote:
On Wednesday, March 11, 2015 at 11:23:27 AM UTC-4, wrote: The corner of my Ventus landing gear door got bent and needs to be glued back to its former shape. What epoxy should I use (I need a very small amount) Need to clamp the piece while drying. What material to use so the clamp doesn't stay glued to the door....? Dan For this you could use a slow curing epoxy from your local hobby shop. I would not recommend 5 minute epoxy from your local hardware store. Poly film placed over the repair before clamping will allow removal and can help make the shape better. Good luck UH The heat-shrink film used to wrap CDs, cigarettes, etc makes a good epoxy release film. IIRC clingfilm also works, but do test it before using it in anger. Epoxy: 24hour epoxy gives a tougher result than the 5 minute epoxies, which tend to be brittle when cured. However if your gear door shows signs of delamination, one of the laminating epoxies would be better because its relatively thin and so can be worked in to saturate the delaminated/fractured area. The better hobby stores will stock it in fairly small amounts: look for Z-poxy or SP113. When I bought my Libelle, the front of its gear goods were decidedly moth- eaten so I repaired the damaged front edges and corners: - made a thin (1/32") ply laminated former that matched the outside curve (a good quality cardboard lamination would also do since you'll only use it once) - covered that with release film (see above). - cleaned up the more ragged door edges with knife, Dremel and sandpaper, removing paint etc within 1/2" of the cleaned-up edges. - taped and clamped the former onto the door - used laminating epoxy/glasscloth/fibreglass mat to build up an oversized section to replace the missing door area. - let it harden thoroughly. - took off the former and put a layer of 35gsm/1 oz/ft twill weave glass cloth on the outside so it overlapped the bared area of the door and a similar layer of thicker classcloth on the inside. This vastly strengthens the join while leaving a nice surface to paint on the outside - then cut off the excess so the repaired doors were a nice fit in the fuselage. - painted the doors and refitted them. I realise your repair is different, but working laminating epoxy into the bent/damaged area, clamping it to a former to keep it straight while it cures and then putting 100gsm/3 oz/ft glass cloth on the inside of the door to cover the repaired crease should make a good job. This requires laminating epoxy. Ordinary tubes of 24 hour epoxy are far too thick and gooey for anything to do with glass-cloth: try using it with classcloth and you'll just end up with a mega-sticky, epoxy-soaked ball of glasscloth stuck to your hands. A good hobby store (either online or highstreet) should have laminating epoxy and glass cloth in fairly small quantities or, if you have a nearby sailplane repair shop, they may let you have a small amount of epoxy and some glasscloth offcuts. If all fails, try: Aerospace Composite Products http://www.acp-composites.com/ or Composite Structures Technology http://www.cstsales.com/ Both are in California and are extremely knowledgeable about composite structures, materials and how to repair them. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Agree. ACP is good stuff. They sell everything he will need from mylar to peel-n-ply, glass and excellent laminating resin. This is all aircraft grade stuff in reasonable quantity. While MGS is the best, its only available by the gallon from Aircraft Spruce. going this route, fix it once and be done.
May want to post-cure too. But with either hobby grade epoxy or CA+kicker(quick fix), likely not a lasting fix IMO. |
I've always had good luck with wax paper as the release agent. You
probably already have some in the kitchen. On 3/11/2015 4:25 PM, wrote: Agree. ACP is good stuff. They sell everything he will need from mylar to peel-n-ply, glass and excellent laminating resin. This is all aircraft grade stuff in reasonable quantity. While MGS is the best, its only available by the gallon from Aircraft Spruce. going this route, fix it once and be done. May want to post-cure too. But with either hobby grade epoxy or CA+kicker(quick fix), likely not a lasting fix IMO. -- Dan Marotta |
On Wednesday, March 11, 2015 at 8:51:33 PM UTC-4, Dan Marotta wrote:
I've always had good luck with wax paper as the release agent.* You probably already have some in the kitchen. Perfect for making finishing harder. Use the plastic wrap next to the wax paper instead. UH |
On Wed, 11 Mar 2015 15:25:24 -0700, dbraun800 wrote:
But with either hobby grade epoxy or CA+kicker(quick fix), likely not a lasting fix IMO. Some hobby laminating epoxys may be junk but I've always had good results with Z-poxy and SP113. I don't remember which one I used for my gear doors but for sure it was one of those: probably the SP113 because the repaired area is pale coloured. Z-poxy tends to be amber coloured while SP113 is water-white. That repair was done in winter 2006/7. The doors still looked great when I checked them during the glider's annual inspection on the 2nd of this month. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
A Ventus door is glass right? I am trying to understand what "bent" means in this context. Is it that the resin is fractured leaving a corner of the door attached by some glass weave or does it mean a piece has broken off? For any large fix, you need to know what you are doing. Several on the forum can help in that case like JJ.
It is exactly like that: "the resin is fractured leaving a corner of the door attached by some glass weave" .
Dan On Wednesday, March 11, 2015 at 3:04:14 PM UTC-4, wrote: A Ventus door is glass right? I am trying to understand what "bent" means in this context. Is it that the resin is fractured leaving a corner of the door attached by some glass weave or does it mean a piece has broken off? For any large fix, you need to know what you are doing. Several on the forum can help in that case like JJ. |
On Thu, 12 Mar 2015 07:30:56 -0700, crosscountryboxco wrote:
It is exactly like that: "the resin is fractured leaving a corner of the door attached by some glass weave" . To me that's a two or three stage job for laminating resin plus a few square inches of good quality glasscloth. 1) Wet out the fracture with the resin (you can thin it with methanol if you must but be aware that will weaken the bond) and clamp it to a former to hold it straight while it cures. Don't forget the release film. 2) Sand off any lumps on the inside of the door and bond on a layer of close weave cloth using laminating resin. 100 gsm/3 oz/ft cloth should do the trick. 3) If the corner was just hanging by a thread, carefully sand off the gelcoat etc on the outer surface and bond on a layer of light fine weave cloth, 35 gsm/ 1-1.25 oz/ft weight. There is lighter cloth but the thread count is low. You'll get a better finish with 35gsm cloth. Then prepare and glasscloth surface and paint the outer surface of the door. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
DISCUS B Gas Spring | Mike J. | Soaring | 1 | May 18th 14 12:52 PM |
Canopy gas spring LS4, USA | [email protected] | Soaring | 3 | October 30th 12 12:01 PM |
spring trim metrics | Brad[_2_] | Soaring | 2 | February 2nd 09 01:48 PM |
TOST Tow Spring Pad for Cub | [email protected] | Soaring | 0 | January 21st 08 04:08 AM |
Windsocks , Spring Special | GASSITT | General Aviation | 0 | April 2nd 04 03:05 PM |
