Hi -
I assume you're using the FS2004 FLightPLanner? Just print the log/flightplan - it should show all the headings and alt's in your plan. hth, vgb "Paul" wrote in message ... Hi! I have a question about flying VFR with a VOR-to-VOR method. When I ask the simulator to plot the route frm airport A to airport B, it plots a series of straights Airp A - VOR1 - VOR2 - Airp B. Now, what I would like to know is the direction for each of the segments! I can only eyeball each one: 045 degrees. Or maybe 062 degrees? I guess, in real life when you plot route yourself on the real map and adjust for the side wind, you can find the angle by using protractor. How do I do that in simulator??? Thanks! |
The MS flightplanner will show you the headings. Just go to that tab in
the planner. Note, that you can grab a route line with the mouse and drag it to another location. Paul wrote: Hi! I have a question about flying VFR with a VOR-to-VOR method. When I ask the simulator to plot the route frm airport A to airport B, it plots a series of straights Airp A - VOR1 - VOR2 - Airp B. Now, what I would like to know is the direction for each of the segments! I can only eyeball each one: 045 degrees. Or maybe 062 degrees? I guess, in real life when you plot route yourself on the real map and adjust for the side wind, you can find the angle by using protractor. How do I do that in simulator??? Thanks! -- Brett I. Holcomb Microsoft MVP AKA Grunt Remove R777 to email |
Same way you do it in real life. Use a chart and a plotter.
![]() "Paul" wrote in message ... Hi! I have a question about flying VFR with a VOR-to-VOR method. When I ask the simulator to plot the route frm airport A to airport B, it plots a series of straights Airp A - VOR1 - VOR2 - Airp B. Now, what I would like to know is the direction for each of the segments! I can only eyeball each one: 045 degrees. Or maybe 062 degrees? I guess, in real life when you plot route yourself on the real map and adjust for the side wind, you can find the angle by using protractor. How do I do that in simulator??? Thanks! |
Don't quite understand the question. In real world, we use Flight
Computers (manual or electronic) to punch in the winds aloft at certain altitude. also factors are the difference in magnetic and true north, compass error etc. In simulator it is pretty easy to fly VOR headings: Assume that the first heading is 124 degrees at frequency 110.6: 1. Tune 110.6 on VOR1 or 2 2. On VOR receiver, set the heading 124 with "TO" indicator 3. Track the VOR 4. Make sure that Compass and heading indicators match Ishrat Not Dick Daley wrote: Same way you do it in real life. Use a chart and a plotter. ![]() "Paul" wrote in message ... Hi! I have a question about flying VFR with a VOR-to-VOR method. When I ask the simulator to plot the route frm airport A to airport B, it plots a series of straights Airp A - VOR1 - VOR2 - Airp B. Now, what I would like to know is the direction for each of the segments! I can only eyeball each one: 045 degrees. Or maybe 062 degrees? I guess, in real life when you plot route yourself on the real map and adjust for the side wind, you can find the angle by using protractor. How do I do that in simulator??? Thanks! |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Flight Planning Software Question | Flyin'8 | Piloting | 10 | January 30th 05 05:18 AM |
| IFR Flight Plan question | Snowbird | Instrument Flight Rules | 5 | August 13th 04 01:55 AM |
| WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 04:01 PM |
| Flight instructors as Charter Pilots | C J Campbell | Piloting | 6 | January 24th 04 08:51 AM |
