I've just tried x-plane under wine and it works well except for a few
issues. 1) joystick(s) won't work. I've got a logictech USB flightstick and x-plane won't see it. The joystick works under linux as /dev/input/js0 as well as /dev/input/event0. 2) udp data output isn't going out. I've turned on 'IP adderss of data reciver (from dataoutput screen) and set its address to 192.168.0.99 but tcpdump on the machine never sees anything on port 49000. I could fix problem 1 if proble 2 didn't exist :-( 3) no sound at all. Sound card works, I run xmms just fine which has better sound than the noisy plane. I'm using ALSA drivers. 4) keyboard is screwey. Sometimes the keyboard just stops working after I switch to different windows. I'm running on a Duron 1.3 512gig ram, asus ri4800se video card with dual displays. Its interesting watching x-plane circle over Sana Barbra in the left monitor while I can type in this in in the right screen. The only glitches are when running at extreme res 1024x768x32 and where there is lots of different textures on the ground, it will cause xmms to skip one channel. The card has 128m and x-plane claims 164.91meg used. So can anyone help with any of the problems? -tim http://web.abnormal.com |
I thought that X-Plane will run native under Linux too, why use Wine?
Greg. "Tim Hogard" wrote in message ... I've just tried x-plane under wine and it works well except for a few issues. 1) joystick(s) won't work. I've got a logictech USB flightstick and x-plane won't see it. The joystick works under linux as /dev/input/js0 as well as /dev/input/event0. 2) udp data output isn't going out. I've turned on 'IP adderss of data reciver (from dataoutput screen) and set its address to 192.168.0.99 but tcpdump on the machine never sees anything on port 49000. I could fix problem 1 if proble 2 didn't exist :-( 3) no sound at all. Sound card works, I run xmms just fine which has better sound than the noisy plane. I'm using ALSA drivers. 4) keyboard is screwey. Sometimes the keyboard just stops working after I switch to different windows. I'm running on a Duron 1.3 512gig ram, asus ri4800se video card with dual displays. Its interesting watching x-plane circle over Sana Barbra in the left monitor while I can type in this in in the right screen. The only glitches are when running at extreme res 1024x768x32 and where there is lots of different textures on the ground, it will cause xmms to skip one channel. The card has 128m and x-plane claims 164.91meg used. So can anyone help with any of the problems? -tim http://web.abnormal.com |
| I need some advice on buying my own plane BEFORE training... | Anthony L | Piloting | 6 | April 23rd 04 12:13 AM |
| Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 01:06 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 08:27 AM |
