Is anyone successfully running FS2004 & a Radeon 9600 on Windows 98?
If you are, then I would know it can be done. I have tried everything to stop it from freezing up about 30 seconds in to the flight. At this point, unless I hear otherwise, I would warn everyone that the ATI Radeon drivers won't run FS9 on Windows 98. What is truly aggravating is how well it runs FS2002! |
I have the Radeon 9500Pro/9700 and at one point was for giving up and
selling FS2004. At the "Choose an aircraft" stage it didnt even SHOW the aircraft in the little box. I saved as much as I could from my HD and did a complete format of C drive.I then reloaded everything as carefully as I could. Something told me not to load DirectX9b so I didnt. I then loaded FS2002 and it was of course brilliant. Then I loaded FS2004 and its own DirectX. Then I used the troubleshooting thingy and it took me to the updated drivers page for the Radeon family. Frame rates varied between 20 and 38 so I locked them at 30. It was a lot of work but it payed off for me. Hope this helps. Ripa/Scotland "Worrybird" wrote in message hlink.net... Is anyone successfully running FS2004 & a Radeon 9600 on Windows 98? If you are, then I would know it can be done. I have tried everything to stop it from freezing up about 30 seconds in to the flight. At this point, unless I hear otherwise, I would warn everyone that the ATI Radeon drivers won't run FS9 on Windows 98. What is truly aggravating is how well it runs FS2002! |
hlink.net: Is anyone successfully running FS2004 & a Radeon 9600 on Windows 98? If you are, then I would know it can be done. Yes, p4 2G, 512 ram, win98se, ati 9600 cat 3.5. Too many horror stories about the cat 3.6's for me to want to "upgrade". I get the flashing when pulling up the menu's but thats it, no crashes (only bad landings ![]() Frames stay locked on 20 fps even with add on scenery, aircraft, and real world weather. My settings are backed down a bit, medium to high. I have AA turned on. Try a different driver version, otherwise I don't know why your card will not work. Derek |
Thanks Derek,
Lucky me.. the only one. I tried all the drivers, no joy. Stuck in an FX5900 with the new drivers and zoom.. no problems. Norm "Derek" wrote in message ... "Worrybird" wrote in hlink.net: Is anyone successfully running FS2004 & a Radeon 9600 on Windows 98? If you are, then I would know it can be done. Yes, p4 2G, 512 ram, win98se, ati 9600 cat 3.5. Too many horror stories about the cat 3.6's for me to want to "upgrade". I get the flashing when pulling up the menu's but thats it, no crashes (only bad landings ![]() Frames stay locked on 20 fps even with add on scenery, aircraft, and real world weather. My settings are backed down a bit, medium to high. I have AA turned on. Try a different driver version, otherwise I don't know why your card will not work. Derek |
F/A-22 Drops JDAM Successfully | Otis Willie | Military Aviation | 1 | September 15th 04 06:49 AM |
YAMAHA FZ 750 FZ750 RUNNING GENESIS ENGINE FOR SALE | Karsten | Home Built | 0 | September 3rd 04 07:34 PM |
Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 04:56 PM |
Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 03:46 AM |
Is there some way to stop the Radeon 9600 freeze-ups in FS2004? | Worrybird | Simulators | 5 | September 2nd 03 08:11 AM |
