"rolland-marie2" wrote in
: I searh a creator of plane for fs 98 for create a E-2C hawkeye of the french navy Je cherche un createur de d'avion pour fs98 car j'ai envie d'avoir un hawkeye de l'aeronaval francaise. mais si en mexplique je veux bien le faire ou au moin les texture I used to do repaints of FS98 helicopters for Paradise Helipad (now closed), so I should be able to handle this one. Do you have an E-2C model currently? If not, I have one originally developed for FS95 that works fine on my FS98, capable of carrier landings. Not sure where I got it. I also have a compatible set of 'adventures' for carrier landings and takeoffs. What I especially need are detailed photographs, showing as many sides as possible, Links to websites that might show more are also helpful. If you have the E-2 Hawkeye model by Terry Hill (named, I believe, "e2-fs95.zip"), then all I'd need are the photos, and I'll send back the texture files in the new colors. If you another model you'd like to use, then I'd need the photos and the entire aircraft file, or at least a place to download it. If you have neither and want to use the same one I do, then again, all I need are the photos. Registration number will be the same as in the photos, unless you specify otherwise. Let me know if I can help, Reply directly to "news[at]wading[dash]in[dot]net" - Al. -- To reply, insert dash in address to separate G and I in the domain |
I am French, does not speak English and am obliged to traduir with the
your site wanadoo.fr thanks for leaving me the temp answer you I used to do repaints of FS98 helicopters for Paradise Helipad (now closed), so I should be able to handle this one. Do you have an E-2C model currently? If not, I have one originally developed for FS95 that works fine on my FS98, capable of carrier landings. Not sure where I got it. I also have a compatible set of 'adventures' for carrier landings and takeoffs. What I especially need are detailed photographs, showing as many sides as possible, Links to websites that might show more are also helpful. If you have the E-2 Hawkeye model by Terry Hill (named, I believe, "e2-fs95.zip"), then all I'd need are the photos, and I'll send back the texture files in the new colors. If you another model you'd like to use, then I'd need the photos and the entire aircraft file, or at least a place to download it. If you have neither and want to use the same one I do, then again, all I need are the photos. Registration number will be the same as in the photos, unless you specify otherwise. Let me know if I can help, Reply directly to "news[at]wading[dash]in[dot]net" - Al. -- To reply, insert dash in address to separate G and I in the domain |
An e-mail with the photo ones had to arrive to you
62526 Mining the Web: Jacobian Matrix Constructs with eigenVectorSearching 62526 | Web Science | Home Built | 0 | November 16th 04 10:01 PM |
20385 Mining the Web :Searches with Kriging, Inverse DistanceWeighting, eigenVectors and Cross-Pollination 20385 | Web Science | Owning | 0 | November 16th 04 10:01 PM |
MiG-17 Still Missing After Nightlong Search - New Mexico | Rusty B | Military Aviation | 0 | March 26th 04 08:29 PM |
Search for missing pilot suspended | C J Campbell | Piloting | 2 | March 11th 04 02:22 AM |
Search for missing plane | C J Campbell | Piloting | 2 | March 4th 04 01:42 AM |
