Secret Fuel Procedure FS2002
Old September 18th 03, 08:49 PM
Doug
Default Secret Fuel Procedure FS2002
A guy I work with told me you can fly over an airport at night and
look for a lit up yellow square, then land and go there and park in
the square and you will get refueled. I couldnt find out anything
about this in the help files, so I was doubtful, I always adjusted
fuel through the menus. Anyway I tried it at Vancouvers International
airport and it works!!! Ive had this software for 2 years and had no
idea you could do that, Am I the only one that didnt know about this?
Why don't they mention this in help? Does FS2004 have the same setup?
Now I he says you can open the door on the Cessna 172 by going to the
outside view and shutting off the engine. I will have to try that next
time....
Doug
Old September 18th 03, 11:30 PM
Al Denelsbeck
(Doug) wrote in
om:
time....
The fuel trick has been around since FS II, the SubLogic days, but at
least they documented it then. It was the 'proper' way to refuel - well, at
least to top off the tanks. Weight, balance, and all that hoohah wasn't
exactly taken into account.
Elevations were an interesting concept back then. The elevation was
tied to the airport, and existed for a certain radius around it. When you
crossed that line, the airport details became visible and the ground level
jumped to match the airport; no gradual transition. This wasn't a visible
effect, it simply changed how soon you would contact the ground.
One time, doing one of the experiments from an FS adventure book, I
brought the aircraft in for a 'hands-free' landing off-airport. No yoke, no
rudder, just throttle and flaps, trying to achieve a smooth touchdown. I
was successful (we won't go into what attempt this was), and as I'm rolling
out, I crossed that line where the elevation changed. With a lot of
bouncing and the repeated screeching sounds of a hard touchdown, the plane
gained 120 ft in altitude while grounded and rolling forward at 30 knots.
Took me a bit to figure out what had happened.
By the way, I often use the fuel box as a helipad. The standing pump
can give a better visual reference for sneaky things like drifting sideways
or backwards.
- Al.
To reply, insert dash in address to separate G and I in the domain
Old September 19th 03, 04:50 PM
H M
i guess that explains the strange effect i ran into: i took off from
lake tahoe (5000 ft MSL) and flew down towards oakland (sea level). i
was cruising along, thinking about nothing evil when suddenly the
altimeter and VSI went wild. they kept swinging up and down,
contradicting each other (one said i was climbing while the other
claimed i was descending). another flight produced exactly the same
result...
Old September 19th 03, 11:34 AM
Bill
long time documented feature...really no secret :-)
Bill
"Doug" wrote in message
om...
time....
Doug
Old September 19th 03, 08:08 PM
Doug
Ok, but where is it documented in FS2002? All I have is help files and
a little manual, nothing about fuel stations in there.....
Doug
"Bill" wrote in message .. .
Bill
om...
time....
Doug
Old September 20th 03, 04:06 AM
Bill
I would have to double check where in 2002, but its been known from previous
versions. I guess if one starts with 2002 and its not there, then thats an
oversight from MS.
Bill
om...
Doug
Bill
om...
time....
Doug
Old September 20th 03, 04:21 AM
Bill
You are correct Doug, I checked 2002 and could not find any reference to
refueling on the ground. That must be an oversight, and newcomers to FS
would not know about it, so I guess calling it a secret isnt way off :-)
I been around FS for more years than I care to think about, and it was
documented in previous versions.
Bill
om...
Doug
Bill
om...
time....
Doug
Old September 21st 03, 07:31 AM
Doug
Thats interesting, but not surprising, lots of oversights and bugs in
FS2002 but I sure get alot entertainment value out of it. Thanks for
checking into it.
Doug
Bill
Old September 21st 03, 09:50 PM
JasonSJbird
Since at least FS2000, you could look for the fuel pump at any medium to large
airport, and find it at the corner of a large yellow square demarkating auto
refuel area. You may do this day or night, but you must come to a stop with all
gear within the square boundaries. Refueling itself happens in the blink of an
eye at this point
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 10:20 PM
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 06:13 PM
faith in the fuel delivery infrastructure Chris Hoffmann Piloting 12 April 3rd 04 01:55 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Hot Starting Fuel Injected Engines Peter Duniho Piloting 23 October 18th 03 02:50 AM
