Don't know if it's been mentioned before but if you change the virtual
copilot line in the FS2004.CFG file to =1 you recieve flying tips. ie power up with out releasing brakes and he lets you know how, stuff like that. May come in handy for some new players. Scet |
Scet wrote:
Don't know if it's been mentioned before but if you change the virtual copilot line in the FS2004.CFG file to =1 you recieve flying tips. ie power up with out releasing brakes and he lets you know how, stuff like that. May come in handy for some new players. This is the same thing as Flying Tips. It can be toggled off and on with Ctrl Shift X or via the realism menu. Another thing, Ctrl X will answer the current flying tip. E.G. If the current flying tip is that the altimeter is off, typing either B or Ctrl X will correct it. If the current flying tip is that the heading indicator has drifted, typing either D or Ctrl X will correct it. These show up in the Control assignments as Flying tips on/off and Flying tips action trigger. -- If you can't speak softly, just use the stick. |
![]() "Squawk 7700" wrote in message ... Scet wrote: Don't know if it's been mentioned before but if you change the virtual copilot line in the FS2004.CFG file to =1 you recieve flying tips. ie power up with out releasing brakes and he lets you know how, stuff like that. May come in handy for some new players. This is the same thing as Flying Tips. It can be toggled off and on with Ctrl Shift X or via the realism menu. Another thing, Ctrl X will answer the current flying tip. E.G. If the current flying tip is that the altimeter is off, typing either B or Ctrl X will correct it. If the current flying tip is that the heading indicator has drifted, typing either D or Ctrl X will correct it. These show up in the Control assignments as Flying tips on/off and Flying tips action trigger. -- If you can't speak softly, just use the stick. Oh ok, I thought the flying tips was when you positioned the cursor over a cockpit item and gave you info on it. Scet |
Scet wrote:
Oh ok, I thought the flying tips was when you positioned the cursor over a cockpit item and gave you info on it. That is Settings-General-Tooltips -- Press any key to continue or any other key to quit. |
Fantastic site, so clever. I have sent the link to all my friends with
Broadband... |
Boeing B-767 Tanker case "Virtual Kryptonite" | BJ | Military Aviation | 1 | December 20th 03 05:15 AM |
virtual plane | franck jeamourra | Owning | 0 | November 3rd 03 09:21 AM |
virtual plane | franck jeamourra | General Aviation | 0 | November 3rd 03 09:21 AM |
320 airluxor virtual | franck jeamourra | Owning | 0 | November 1st 03 06:43 AM |
Default Virtual Cockpit? | Timmy Ferrell | Simulators | 0 | August 21st 03 06:05 PM |
