About to buy a new PC system to to used mainly for Flightsims, do these
perform as well at CRT monitors etc.... i.e. are frame rates & suchlike effected. What advantage does a DVI input provide? |
"Alan Cameron" wrote in message
... About to buy a new PC system to to used mainly for Flightsims, do these perform as well at CRT monitors etc.... i.e. are frame rates & suchlike effected. What advantage does a DVI input provide? You'd have to define "perform". Refresh rate isn't anywhere near that available in CRTs, but the response time of a LCD monitors is approaching 60 Hz. Refresh rate for all LCD monitors I'm aware of is 60 Hz, and the response time is close enough to the refresh rate that for most displayed graphics (including those in a flight sim), you'd be hard-pressed to notice the difference. There are extreme situations where you'll notice blurring, or even seeing scrolling text become almost invisible. But in those cases, you're not really losing that much information. You wouldn't be able to read text scrolling that fast anyway, and a little bit of blur in animation isn't necessarily a bad thing. Color reproduction is another area where LCD monitors lag behind. But as with the refresh rates and response times, one may or may not actually notice it. I know that I don't, not when I'm playing games (it's more noticeable when doing image editing, but even there doesn't typically interfere with getting good results if you know it's happening). IMHO, you should not buy an LCD monitor without a DVI input, and should not use an LCD monitor without a video card that has a DVI output. The LCD display technology is inherently digital, and it makes no sense today (given the availability) to convert a digital video signal to analog and then back to digital at the other end. The image quality using a DVI input is MUCH better. Likewise, expect to run the LCD monitor in its "native" resolution most of the time. I've run into a few games that don't support the native resolution of my LCD monitor, and obviously for programs like that you don't have a choice. But otherwise, the image is so much better when the graphics are not being stretched to fit the LCD pixels. CRTs do a much better job of handling a variety of resolutions, but the image displayed on an LCD monitor at its native resolution will be much sharper than anything even the best CRT can achieve. There have been several other threads on LCD monitors in this newsgroup, and probably many others. Google will help you fill in the blanks if the above is not satisfactory. Pete |
Thanks Pete,
that answers my main concerns. "Peter Duniho" wrote in message ... "Alan Cameron" wrote in message ... About to buy a new PC system to to used mainly for Flightsims, do these perform as well at CRT monitors etc.... i.e. are frame rates & suchlike effected. What advantage does a DVI input provide? You'd have to define "perform". Refresh rate isn't anywhere near that available in CRTs, but the response time of a LCD monitors is approaching 60 Hz. Refresh rate for all LCD monitors I'm aware of is 60 Hz, and the response time is close enough to the refresh rate that for most displayed graphics (including those in a flight sim), you'd be hard-pressed to notice the difference. snip |
The only downside to a TFT monitor is the resolution limitations. A 15" will
limit at 1024x768 & a 17" or 18" will give you 1280x1024 max. I run my Sony "18 TFT at 1280x1024x16 in FS2004 with pleasing results. However someone once told me that you cannot compare this difference directly with CRT monitors as they both opperate slightly different. "Alan Cameron" wrote in message ... Thanks Pete, that answers my main concerns. "Peter Duniho" wrote in message ... "Alan Cameron" wrote in message ... About to buy a new PC system to to used mainly for Flightsims, do these perform as well at CRT monitors etc.... i.e. are frame rates & suchlike effected. What advantage does a DVI input provide? You'd have to define "perform". Refresh rate isn't anywhere near that available in CRTs, but the response time of a LCD monitors is approaching 60 Hz. Refresh rate for all LCD monitors I'm aware of is 60 Hz, and the response time is close enough to the refresh rate that for most displayed graphics (including those in a flight sim), you'd be hard-pressed to notice the difference. snip |
I have been running FS200* on a Viewsonic VG175 at 1280x1024x32 for the
last couple years - as well as some FPS games - and I am totally happy. I cannot see any reason to buy a CRT/Space Heater ever again. Dave Blevins On Sun, 26 Oct 2003 23:17:24 -0000, "FG Phil" wrote: The only downside to a TFT monitor is the resolution limitations. A 15" will limit at 1024x768 & a 17" or 18" will give you 1280x1024 max. I run my Sony "18 TFT at 1280x1024x16 in FS2004 with pleasing results. However someone once told me that you cannot compare this difference directly with CRT monitors as they both opperate slightly different. "Alan Cameron" wrote in message ... Thanks Pete, that answers my main concerns. "Peter Duniho" wrote in message ... "Alan Cameron" wrote in message ... About to buy a new PC system to to used mainly for Flightsims, do these perform as well at CRT monitors etc.... i.e. are frame rates & suchlike effected. What advantage does a DVI input provide? You'd have to define "perform". Refresh rate isn't anywhere near that available in CRTs, but the response time of a LCD monitors is approaching 60 Hz. Refresh rate for all LCD monitors I'm aware of is 60 Hz, and the response time is close enough to the refresh rate that for most displayed graphics (including those in a flight sim), you'd be hard-pressed to notice the difference. snip |
Sorry for not quoting, but's early in the morning and my coordination
isn't such that I can selectively delete. Anyhow, on this topic...How do I find out the "native" resolution of my monitor? John |
It's normally specified with the monitor.
A point, I have come across an expensive TFT (sorry, can't remember where) with a refresh of 85Hz specified "John Penta" wrote in message ... Sorry for not quoting, but's early in the morning and my coordination isn't such that I can selectively delete. Anyhow, on this topic...How do I find out the "native" resolution of my monitor? John |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
GPS Models -- Pros and Cons | Aviv Hod | Piloting | 22 | July 22nd 03 10:35 PM |
